Question about Whirlpool Accubake RF362LXTT Electric Kitchen Range
Gr450lxhq2 whirlpool accubake electric range
Putting door back together after replacing inside glass
jsrock516
  • 5911 Answers
SOURCE: REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Posted on Jan 29, 2009
  • 4 Answers
SOURCE: Whirlpool Accubake Duo System electric range fault coes E4 F3
F3 code correlates to oven temperature. Either the oven temperature sensor is malfunctioning or the over-limit switch is open. This is usually the result of using the self-clean mode and the over-limit switch gets stuck open. It has to be replaced...not too bad of a job if you have some mechanical/electrical knowledge. Ask parts supplier for a schematic so location can be visualized (inside top cavity on oven wall with a couple of wires. Also, Sears carries parts for these ovens. Hope this helps.
Posted on Mar 12, 2009
Maytag317
  • 1136 Answers
SOURCE: Whirlpool 465 accubake gas range stuck in the "lock" mode.
Hi, Try setting it to clean, then cancel the clean cycle right away. Sometimes this helps. Please let me know.
Thanks
Vic
Posted on May 17, 2009
  • 132 Answers
SOURCE: timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
Posted on Jan 14, 2010
venexcsd
  • 1185 Answers
SOURCE: Worried about coming in contact with the insulation inside door.
Unless you have an oven with a production date pre 1970 then the answer is no.
There are heat resistant materials available which do not contain asbestos fibres . (Nomex being one of them)
If you are really concerned go buy a simple 3m dust mask and wear gloves
Posted on Mar 26, 2010
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
May 05, 2016 | Whirlpool RBD245PRB 24-inch Double Wall...
Hot burner indicator light won't go off
It sounds like the heat sensor which is next to the hotplate beneath the glass is faulty. The contacts of the sensor sound like they are stuck together.
Feb 15, 2011 | Whirlpool Accubake RF362LXTT Electric...
I'm trying to put the oven door back together and it won't fit properly. any ideas? This is a whirlpool electric range mod# RF364PXPQ.
I had mine apart to clean and could not figure out how it went back together. The side strips I thought helped hold the glass in but they dont. I then discovered the side plastic strips go back in on the flip side-inner oven side. Grrrrrrrrr...wasted half a day trying to figure this out.
Nov 20, 2010 | Whirlpool RF364 Electric Kitchen Range
I have a flat top stove I spilt some type of liquid down between the glass of the oven door and the door it self How do I remove the glass panel
take the door off and put on table. remove screws noting were they go door should "split" apart. clean glass. put back together and use hand tool not screw driver gun
Apr 21, 2010 | Whirlpool RF378 Electric Kitchen Range
How do I replace a Whirlpool RF362LXTT cook top?
Read through the link provided and let me know if you have any questions. This is not a difficult repair, but can be tedious. I hope you find this information helpful.
NOTE: There should be a wiring diagram included with the range that you can also use for reference. It will either be located on the back of the range, or inside the control panel.
Aug 16, 2009 | Whirlpool Accubake RF362LXTT Electric...
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Whirlpool under counter oven, inside glass door broke.
To get to the glass on the inside of the door you need to do the steps listed.
1. Open door 4" and pull straight up at that angle
2. Lay door on flat surface with the handle down to surface.
3. Remove all screws that you see .
4. The inner housing should be removable now.
Then you should see the glass. Reverse the steps to put back together.
Good Luck with the fix.
Dec 17, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
91 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
