Direct wifi to tablet via routers - Computers & Internet
  • 2,072 Answers
  • Enable wireless on tablet
  • Select your wireless network on tablet
  • Enter security password if applicable.
  • Browse away.
Posted on Jan 12, 2013
Can never get a tablet to hook to my wifi with this router DO NOT know password
if router is rented call your provider they can help you determine the password (hint : most times its the serial number on its case )
every item with connection via wifi should/allways require a password
Dec 01, 2015 | Tablets & eReaders
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
Tip
Samsung ML-2525W printer & Mac OS X 10.6
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable (3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch (4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless) (5) WiFi to router, with Mac/PC via Ethernet to router/switch (6) WiFi to router, with Mac/PC also via WiFi
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Also required different driver for wireless config (as opposed to USB).
How to move files from tablet to sd card
Hi ,
I don't use the samsung Galaxy : is the SD card part of the Tablet ? Otherwise , any tablet or smartphone can be connected to a pc, via usb , bluetooth , wifi ... and any sd card can also be connected to a pc , directly or via a card reader . The pc'OS ( Windows , Mac , Linux ) will easily copy all files from one to another .
Regards .
Aug 20, 2014 | Samsung Galaxy Tab 8.9 WiFi 16GB Tablet
THERS IS NO INTERNET SERVICE ON MY TABLET
What is the tablet? Are you able to connect to the wireless gateway via your pc/laptop?
Check in the tablets settings and make sure "Data/Cell" services are OFF and that the "Wifi" or wifi adapter is turned ON.
Let me know how you make out.
Jan 26, 2014 | 3Com OfficeConnect Wireless 11g Cable/DSL...
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
I am getting "Authentication Problem" with WiFi on 2 tablets - excellent signal. Accepts the security code and will hold for a minute or so.
I see three points:
1. check if the password of the router is the same you have signed in the wifi-account of your tablets - it's typical that a wrong password is prompted with no error message.
2. check if the wifi-protection of your router has the same type (WPA, WPA2) as your tablets use
3. check if the router accepts new wifi-devices, sometimes there is a checkbox "only known devices can access via wifi"
greetings, bernd-steffen
Oct 12, 2013 | Android Tablet PC
Why can't i connect to wifi
not to be mean but often times with those little cheap tablets (I have had a few) the wifi is picky due to cheep part and software(the device).here are some common problems.Does it support the type of network your trying to connect to?is your network key too long? some device dont like itis you network name too long? is your router blocking access?(firewalls, filters,port forwarding, client limits)are you with in 10 feet of the router, wifi on tablet can be limiteddo other device connect to the internet via this methoddo you even have a wireless network of you own?make sure wifi is powered on?hard reset devicethe list of what the issue could be is infinite-Good Luck.
Jan 27, 2013 | Coby Kyros MID70154G 7 Tablet Computer...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
