Question about Toro 52" 27hp Z Master Zero Turn Lawn Mower
My battery wont charge even after i replaced the starter and voltiage regulater what else could it be
    Sergeant:
  • 322 Answers
You need to check the actual alternator. The starter has nothing to do with the charging system so replacing that wouldn't solve a charging issue. Also make sure the battery is good
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Posted on Jan 16, 2013
Car wont start has charged battery lights and radio come on new starter. drainging battery even though the battery is fully charged its reading its not tempature gauge reading hot but its not runn
If the problem began when (or soon after) installing the new starter, start checking there. Ensure that all cables to the starter are tight. As a second possibility, if the new starter was actually a rebuilt replacement, the solenoid could be faulty. (I went through three rebuilt starters on my son's truck until we got one that worked properly.)
Mar 06, 2014 | 2004 Ford Mustang GT
Hyosung GV 650 wont start. Battery is fully charged and starter don't even click when trying to start?
This will be either the starter solenoid is faulty or the starter motor needs replacing.Have the solenoid checked before removing the starter motor.
Mar 21, 2012 | Hyosung GV 650 Aquila Motorcycles
Kawasaki kz750 spectre...loses charge quickly even on a new battery...what is the problem?
Hi,,you need to replace the regulater/rectifier,,,as even a new battery is not holding a charge.
you will find it in a side panel,or under the tank it is square shaped with fins on it.
Aug 30, 2011 | kawasaki Z 750 Motorcycles
The new battery cannot be charged. is it charger problem?? i try unhook the battery wire after engine start, and it die. when u unhook the battery wire it should still running right. the engine should be...
eigther the voltage regulater went bad or there is a short draing the battery but it seems like the voltage regulater some bikes like my iron head sportster charges off the starter not sure on yours but have a shop check the regulater
Jul 05, 2011 | 2011 Modenas Jaguh
Hi,my 1982 suzuki gs1100 is not charging the battery.With the bike running at 2000-3000 rpm the voltage does not go higher then 12.5.I used a voltmeter across the battery terminals.The battery was fully...
Hi if battery is fully charged the charging system wont put in more than it needs so 12.5 volts is adequate try putting the lights on and raising the revs and checking the output at the battery if its still the same or lower then you could have a problem usual faults are with the voltage regulater rectifier breaking down if you follow the wires back from the alternater/generator should be three yellow wires to an aluminium finned block under the sidepanel check the output to this unit from the alternater and see if its the same or similar output if your only getting 12.5 volts from the alternater then your problem is with your alternater and it may need replacing but if voltage is good 13.5+
then you either have broken wires to the regulater rectifier or a faulty regulater rectifier a good swop
if a genuine regulater rectifier isnt available and the fact that they were allways a bit trashy any way is to fit one from a honda cb250 superdream as they were much easier to find and cheaper to buy second hand from a breakers yard
Nov 22, 2010 | 1984 Suzuki GSX 1100 E
Ever since I bought my 2008 softail I had problems with the battery it seems to keep draining I had it in several times.and the charging system seems to be fine but every once in a while it seems to not...
Check the battery connections. 95% of the problems I have had with electrical problems are at the battery connections because a small amount of corrosion has built up. This will not allow the charging system to charge the battery properly and is the most often overlooked problem, even by trained shops. Remove the terminals and clean then thoroughly with a terminal wire brush. Its a cone shaped wite brush you can get and any NAPA or equivilant store. Clean both the battery side and the wire side. Forget useing thos goofy grean and red corrosion resistant discs.
Replace the terminals and charge the battery. I think that should fix your issue.
Aug 26, 2010 | Harley Davidson FLSTN- FLSTNI Softail...
Wont start turns over and clicks even with battery charger on jump start mode
Sounds like a bad starter. Even though the battery is charged the starter is to week to turn the motor over. Try replacing the starter and see it that helps. If that does not work. Go to a dealership mechanic. Thanks for asking!
Jun 29, 2010 | 2000 Volvo S80
Alternator wont charge the battery put a new one on still wont
When replacing Alternator on This Vehicle Voltage Regulater Must Be Replaced Also.
Jun 02, 2009 | 1990 Chrysler New Yorker
1981 ford fairmont electrical
Looks like you have replaced all of the key parts, and then some. At this point I would verify that the alternator is charging the battery. With engine off, check battery voltage. Start the engine and check thre voltage again. It should climb to charging voltage, around 13.0 to 13.5 volts. If it doesn't, check all connections. On a vehicle this old, I would start with the ground circuits.
Good luck.
Buzzy
Dec 21, 2008 | 1983 Ford Fairmont
F250 NEED HELP!!!
The only thing I could suggest is that if you bought a remanufactured alternater you may have gotten a bad one. It tends to be hit or miss with any remanufactured part.
Oct 31, 2008 | 1987 Ford F 250
Toro 52" 27hp Z Master Zero Turn Lawn Mower Logo
89 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
