How to fix f1 code on maytag epic z dryer - Washing Machines
  • 409 Answers
SOURCE: maytag epic
hi there,
the FH error means it's either you have a drain problem if there is water in it or if if there is now water in it, make sure that both water inlets are turned all the way up. check to make sure that you don't have any water leaks anywhere visible.
Posted on Oct 03, 2008
CMV9
  • 594 Answers
SOURCE: I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Posted on Apr 16, 2009
  • 410 Answers
SOURCE: my maytag epic z front load washer has fault codes
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the washer or dryer ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and found that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video which showed me how to take my machine apart. This video made it possible for me to do my own repair. If you are repairing a dryer or a front load washer I suggest you
go to www.applianceaid.com where they have very good step by step trouble shooting and repair information on both washers and dryers as well as other appliances. If you have a direct drive top load washer and need help taking it apart this video is an early christmas present. I was so impressed with it that when I saw all these people needing help, I wanted to tell them about it. If you look at the back of your washer and the panel is solid (no small inspection plate to remove which would indicate you have a v-belt drive) chances are you have a direct drive and this video is just what you need. You can see it at www.acmehowto.com You will probably still need help in determining what the trouble is and how to fix it. After viewing the video or if you have a v-belt drive rather than a direct drive, I suggest you go to www.applianceaid.com where they have very good
trouble shooting and repair nformation on most
washers and dryers. I think you'll find what you need
there. Don't worry about the timer, they hardly ever
go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 30, 2009
SOURCE: Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Posted on Jan 26, 2010
sodeep
  • 3267 Answers
SOURCE: how much it cost to fix maytag washer epic z After I push Power, My Maytag epic z front load washer is turning itself off as soon as I press the Start button!
Press the button on the far right next to the Off button and hold for 3 seconds. I think it's the "Cycle End Signal" button.
Posted on Dec 02, 2011
Error code f 01 epic z maytag dryer
advanfagesupplyfl.com implies that you have a primary control failure. Check it out and see what you think. If it's right it might be rather expensive to fix. Also discuss with local appliance engineers.
Jun 28, 2015 | Maytag Washing Machines
Maytag dryer epic z flashes error F1
bad thermister part number 8577274 and it's around 30 dollars.go here and see the part
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MED9700SQ0/3048/0151200/W0802068/00003?blt=06&prst=&shdMod= number 42 on the diagram.hope this helps.also there should be a tech sheet with info and error codes on it.don't loose this paper in case you ever have to call someone in to service it
Jan 06, 2013 | Maytag MED9700S Electric Dryer
My Maytag Epic Z Electric Dryer has an OE service code, quit working after the interior drum light burnt out. What does that code mean?
Refer to your service manual it will tell you what the code means. I would recommend to remove the bulb from the housing inside the dryer which is located next to the drum. That should fix the problem.
Aug 09, 2010 | Dryers
F 21 error code? Maytag epic z washer
The F21 code on the Maytag EPIC is indicative of a pump problem. The pump impellers should be checked, there should be four of them. Sometimes the impeller blades can be broken by coins, or other items. Make sure that the pump is clear of debris, then remove the discharge hose, and blow through it.
If after clearing the initial slug of water, the hose doesn't blow free and clear, you have something stuck in there.
Nov 28, 2009 | Maytag EPICz Electric Dryer
"Maytag Epic z washer flashes f 24 error code"
I have a maytag epic z dryer and it wont turn on. it worked fine the last load, now nothing? help.
Apr 25, 2009 | Maytag EPICz Electric Dryer
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My Maytag Epic Z Dryer is showing a code of F-22. It will not work. What does this mean?
If U R comfortable doing so, I suggest that U go to the Breaker Panel, and find the Dryer Breaker, turn it off for a min. then turn it back on.. By doing this, it Might re-set the Dryer... Once U turn it back on, and the Dryer comes on, I would watch it, to see if it flash's anymore Codes. If this doesn't Help, I suggest calling your Certified Maytag Repairman.. Hope this Helps U...
Oct 26, 2008 | Maytag Dryers
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Washing Machines Logo
123 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
