Question about Sharp R-1514 Microwave Oven
LCD Display only partially working
I have not disassembled te unit yet. I am trying to find the part but have not had any luck. Is the dispaly only available with the main control board? If that is the case is there any work around?
Mahalo and Aloha
Joe
  • 68 Answers
I had the same problem with the same model. Died about 6 mths after the purchase but I couldn't return it. It looks like conductive rubber between motherboard and display goes bad and there is no replacement. I leared to 'live with it'.
Just make sure you press clear every time before entering cooking tim. (Beeper still works so I know that I pressed a button)
Posted on Jan 22, 2009
Microwave LED only displays partial numbers
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee.
We have the full service manual at our site, which contains the specific safety & disassembly information you'll need here.
We really need the front door panel assembly (which contains the keypad, display board and connecting cable) as well as the power board to which the cable connects, as shown in the attached photos.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 10, 2009 | Hotpoint JE740WY/GY Microwave Oven
No display on LCD panel on my whirlpool microwave
I do not know what procedure you used to replace the door, but if the buttons and display were working fine before you replaced the door then it seems that there is a plug not plugged into the control display panel. Other than that the low voltage power supply may not be providing the needed voltage for the display and only for the logic circuits which are a different voltage. With the microwave unplugged, take the cover off and look at all the connectors and make sure that they are plugged into something and none that are not plugged in. They should all go somewhere. To answer your original question, there is only one main fuse to the microwave. The circuitry in the control panel operates on low voltages +/- 5 volts or +/-12v so that part is not fused. What I recommend also is to go back mentally through the procedure you used to replace the door and that may give you a clue as to what you unplugged, although you should not have to unplug anything.
Feb 11, 2009 | Westinghouse Microwave Ovens
GE JVM1860WD001 microwave
CONTROL BOARD HAD FAILED your magntron is starting but the cooling fan for it is not , the control relays that control them enegerize at the same time . if not this is what happens . repair is very costly . ge has had probles with there microwaves for years , when you replace think about another brand . good luck
Jan 18, 2009 | GE JVM1650 1000 Watts Microwave Oven
Sharp R1210 LCD display
Actually there are two good options for you.
First, we repair these for customers nationwide with our guaranteed $39.95 service.
We have full details, plus critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa.
Or you can order a modified control unit from us which has our proprietary fixes designed to repair and prevent these common display failures.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
prototech@usa.net
Jul 08, 2008 | Sharp R-1210 Microwave Oven
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
Microwave Display
Have you tried unplugging the unit for several minutes and then plugging it back in?
The oven's microprocessor receives the input commands from the front panel switches and it also drives the digital display.
Since the switches work and the oven works, the microprocessor appears to be functioning fine. I would say you have a defective display or a power supply issue that powers the display.
Unfortunately, you'll need to take it to be serviced.
Please let me know if I can be of further service to you.
- Jim
Feb 17, 2008 | Sharp R-1405 / R-140 Microwave Oven
Microwave display - digits have become dim / partialy missing
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
Full details and *critical* safety, disassembly, and troubleshooting info is at Web our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 09, 2007 | Microwave Ovens
Display and heating problems
Problem #2 is a bad door switch or door switch mount.
Problem #1 is a trouble with the control unit / display.
The avergae do-it-yourselfer can replace a door switch if he follows the proper safety and repair advice.
We repair control units on a regular basis for customers nationwide with our guaranteed $39.95 service.
We have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
When you get to our site, do a Ctrl-F search for R630.
We also have the entrie service manual for these on our site.
Oct 31, 2007 | Sharp R-630D Microwave Oven
LCD display is working but very dim and hard to see
This is a common failure of the control panel assemblies of these and similar microwaves. We repair these control panbel assemblies nationwide for only $32.50. If you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Feb 18, 2007 | Sharp R-326FS 1100 Watts Microwave Oven
Sharp R-1514 Microwave Oven Logo
208 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
