Question about Viking 27" Professional Select Built-in Electric Single Wall Oven
Viking oven buzzes all the time when not in use
When not in use our Viking wall oven buzzes a high pitch noise that is quite irritating It sounds like it is Coming from the clock part. As soon as you start the oven or press any of the buttons the noise stops Please help me figure out how to get this nose to end, it is driving us crazy
    President:
  • Viking Master
  • 1,922 Answers
The low voltage transformer on the ERC control is vibrating from not doing anything,when you put a load on this transformer it will quit,only fix is to possibly remove ERC and jam a piece of NON-Flammable/NON-electrical metal to keep it from vibrating and try this first,if this doesn't help,replace the noisy board with this transformer on it
Posted on Jan 13, 2013
5 Suggested Answers
  • 221 Answers
SOURCE: Elect Oven Viking - does not cycle temperature
It sounds like a weak igniter.
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Posted on Mar 05, 2008
protek480
  • 1723 Answers
SOURCE: VDSC 365-40, Suspected right
The ignitor is still sparking because the 'ring' around the burner is a bit dirty and cannot 'conduct' electric current. The ignitor will arc until the flame lights, then the current flow from the ignitor unit conducts through the flame and down through the ring on the burner. Clean around the whole burner with a SOS or steel wool pad.
You say 'elements' don't heat. Oven or burners? The top burners may be arching a bit from being jostled during repair. Push them firmly back into the receticle on top. If oven element, check to ensure tight connections on back of element and make sure the sitting on brackets that hold them in place in oven.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
  • 10865 Answers
SOURCE: Viking 27" Electric Oven Noise
Hello. The Viking does have fans which operate continuously to insure even baking. If it sounds like fans running, this is the convection fan operating. J.
Posted on Jul 01, 2010
Viking wall oven top oven light blinks, oven won't turn on
suggest calling a repair service locally . we can not test the system from here .
Apr 19, 2018 | Viking Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
When I turn on the self cleaning oven, it makes a loud buzzing noise. Is this normal? If not, what needs to be fixed and how do I do it?
The buzzing sound comes from the relays located on the control board. Remember, the oven gets very hot during self clean, so the control works at full speed to get all the elements working.
Jan 03, 2015 | Kenmore 30 in. Electric Self-Clean Single...
I'm looking at a used Viking double wall oven in gas-Viking Vgd0271SS.. Does anyone know anything about it?
This is a high end wall oven. Common break downs are oven ignitors, all ovens fo that though. Life span for an igniter is 5 to 10 years. Viking is rare to have problems..
Dec 07, 2014 | Ovens
Jul 01, 2010 | Viking 27" Professional Select Built-in...
How long to run self clean on viking professional
The "Self Clean" will run for quite a while up to 4 hours I believe, during this time, the stove heats up to about 900 degrees!! and during this time the Door is automatically closed via special locks. It will allow you to open once it is finished, it should "Signal" this event.
Feb 11, 2010 | Viking 27" Professional Select Built-in...
Display is flashing0.00 and auto. oven won't work, took out circut breaker still doesn't work. when trying to reset the clock high pitch sound comes on and have to turn oven off at wall to stop
It will not work if it is flashing, the timer needs to be reset to manual
If it will not reset, then It sounds like the timer is faulty, try a different combination of buttons when trying to reset it.
Hope this helps.
Feb 02, 2010 | Ovens
Kitchen wall oven there is a buzzing sound when in the convection bake cycle
You don't tell the age of the oven... but the convection fan motor bearing is stressed by the heat of the oven.... and over time can cause all sorts of noises.
You may want to place a small amount of WD-40 on the convection fan motor bearing... just to confirm it as the problem/
Best to replace the motor if it is the problem..
-Jim
Oct 17, 2009 | Ovens
The first time wall oven is turned on I started to see smoke in the upper and lower ovens is this normal for break in ? first time usage>
Yes, there are oils on the metal from the manufacturing process. It should not smoke after the first couple uses
Aug 04, 2009 | Viking 27" Professional Select Built-in...
Viking 27" Professional Select Built-in Electric Single Wall Oven Logo
213 people viewed this question
Top Viking Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Viking Oven Expert? Answer questions, earn points and help others
