Question about LG 47LM6200 47" Class LED 3D 1080p 120Hz HDTV with Smart TV, Buiin
Want to play sound from lg DVD receiver LH T360 which has wires to 5 speakers and scart output through lg 47LM620t " do I need scart to HDMI adaptor to do this ? I want to use sound for TV and not ju
3 Suggested Answers
  • 458 Answers
SOURCE: LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Posted on Apr 18, 2009
SOURCE: Ref LG 42PG6900. The audio from the HDD does not output to scart
The 5.1 Dolby Digital is only on the TOS link!
Same as the SKY box. God knows why!
Posted on Nov 22, 2009
I installed a HDMI cable and an Optical cable to whatch movies and shows from my LG HD LCD TV, but nothing seems to work. The stereo is also a LG LHB336 system. Which is compatible with the TV. We were...
Hi,Even though you have done some cabling already,for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to
continue f
or Helping out the Community :)
Jul 24, 2011 | LG 42LC2D 42 in. LCD HDTV
MY TV ONLY HAS SOUND WHEN IT IS HOOKEDUP TO THE DVD PLAYER AND A SURROND SOUND SPEAKER BUT NOT FROM THE TV OR WHEN HOOKED UP TO THE SPEAKER ON TV OR XBOX
Hi,here is the solution......
Since you successfully connected your
DVD /Receiver to play video on TV (one way only ) ,here is the second reverse action to listen your TV on DVD /Receiver
** you need to connect "Audio Output " as can either be : RCA jacks or "Optic cable output" or "SCART "connector " of your TV ,
** to "TV input "or "AUX input" or "Optic Cable input"
of your DVD /Receiver (whichever you want based on the necessary cables on your hand )
** than just switch to respective mode on
DVD /Receiver corresponding the connector you have used on the back of DVD /Receiver ..
There you go..Both Tv and Xbox sound are on the
DVD /Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your DVD /Receiver SURROUNDING SOUND .
continue f
Jul 03, 2011 | RCA L46WD22 Television
I have a LG LHB335 Blu-Ray home theater system, & a LG TV I can get Full surround sound when the blu-ray is play a DVD but not when just watching Reg TV. I use a HDMI, should I hook up sonething else ?...
LG documentation states:
When you use SIMPLINK function, you have to
connect to the OPTICAL IN 1 jack to enjoy TV
sound to your speaker system.
Basically you need to have the Audio go from TV to receiver and setup receiver to that Input to output surround sound to all speakers.
If you have a cable box or satellite receiver, hook that output into the receivers input and that should work.
My setup is DirectTv HDMI output goes into the LG Home Theater HDMI Input 1, and LG goes HDMI output into the TV HDMI input 1.
so to watch DirectTV, I switch LG Home theater to HDMI Input 1. and TV is on HDMI input 1 (to view LG HDMI output from DriectTV, Blu-Ray, Vudu, etc.)
Jan 11, 2011 | LG LHB335 Theater System
I want to take an audio signal from the tv to an AMP.
Hi...
this should sort you out..
http://cpc.farnell.com/_/42789/adaptor-scart-to-3-phono-s-vhs/dp/CN07056
martin
Nov 21, 2009 | Digital Audio 5-OUTPUT COMPONENT VIDEO...
Won't Show DVD Picture or Hear From Surround Sound Speakers
The lack of video in the DVD can be isolated to the DVD players output mode, if you are using the component video out on the dvd player then be sure to follow the componet out of Receiver to the tv component inputs, if you are using the HDMI from a DVD HDMI into RECEIVER HDMI then go to TV HDMI, you cannot mix component and HDMI on this model of AVR receiver and acheive results, in other words keep the COMPONENT to Component and HDMI to HDMI signal path, the results will be similiar quality audio and video UNLESS you are doing a blu-ray source which will result 1080P quality, all other video, HD results to 1080i, about the audio, if all 5.1 test tones are satifactory to speakers but on playback modes for DVD or HD tv signals all you are receiving is LR which is basically 2 channel (stereo) you need to enable a MULTI-CHANNEL capability input, this must be a option on the DVD Player Audio MENU output, be sure it is set for DOLBY DIGITAl 5.1 or DTS outputs, be sure to have the receivers digital input enabled if you are running optical cable or coaxial digital for the audio, you will be sending a multi-channel input to the receiver when the Receivers Faceplace LCD displays 5-6 speakers. If it shows only LR or two speakers it is not locking into a 5.1 audio input.
Feb 21, 2009 | Yamaha HTR-6130 Receiver
Unlock code for LG LH-T360
1. Power on the player with no disk in the drive
2. Press "PAUSE" on the remote
3. Enter "3 1 4 1 5 9" on the remote (the word COdE appears on the display)
4. Enter "0" on the remote (0 = All Regions, 1 = Region 1, 2 = Region 2, etc.)
5. Press "PAUSE" on the remote
6. Power the player off and then back on
Feb 27, 2008 | Audio Players & Recorders
LH T502SH DVD Receiver System
get a rca cable (red and white) hook one end on the audio out on the back of the tv and the other end to the audio in on the back of the receiver. then go to aux crank it up!!!
Feb 06, 2008 | LG LST-3510A DVD Player/Receiver
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Dvd region codes
Try this (for a LH-T360SE)
Open disk tray and press 0000, a two line menu appears with "Edit Region _" and "Region Code:x" put in required region (presumably 0) and press enter. Region Code:0 appears. power off and enjoy.
region code 0 is No region restrictions.
Nov 03, 2007 | Televison & Video
LG 47LM6200 47" Class LED 3D 1080p 120Hz HDTV with Smart TV, Buiin Logo
