Question about Craftsman Gas Brush Cutter BushWacker 27cc 2-Cycle Straight Shaft
Craftsman 636 brushwacker - Craftsman Gas Brush Cutter BushWacker 27cc 2-Cycle Straight Shaft
2 Suggested Answers
  • 279 Answers
SOURCE: 32cc Craftsman Brushwacker
You have to take the machine apart. The first thing is to separate the shaft from the engine. Then take off the shaft driver. There is a screw in the end. It takes a #15 TORX screwdriver. Once that is off, you have to spin off the clutch. To do that, hold the engine somehow and remove the clutch counter-clockwise. With that off, you can then remove the engine from the molding at the other end. The spool will be sitting on the rewind spring so BE CAREFUL. If the spring comes out it will be a big pain! Just lift the spool off, replace the rope and attach as the old one was. Now, you have the rope connected. Place the spool on the spring. Place the rope in the notch at the edge of the spool and slowly wind the spool on the spring. When you have it wound as far as you want, take the rope from the notch and into the spool. Allow the rope to rewind onto the spool. Put everything back as it was before you started and you have finished...Good luck...Lee
Posted on Sep 09, 2009
Testimonial: "thanks so much."
Need operators manual to remove brushcutter blade
Hi mine has a hole behind the blade that you put a screwdriver in then turn the blade till it goes in to an aligning hole then it's screws off
Sep 27, 2017 | Craftsman Garden
Replace the oscillating fork in a fein msxe 636
beware of the materials that are used are usually very soft witch used by Fein in his budget machine class.
puler
Only a dutch version but the same parts positions.
MSxe 636 II 50Hz 230V
Jan 05, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
I put a new carburetor on my craftsman model 358.795200 brushwacker; it idles ok but when i pull the throttle lever it stalls?
you will need to adjust the carburetor, I would use a 1/8 of a turn at a time, I am assuming the spark is new,also. Hope this helped Tim
May 22, 2011 | Garden
When replacing purge bulb on my 32cc craftsman brushwacker I found 3 fuel lines off carb, two were connected to bulb, what's the third? I assume it goes to the other hole on the bottom of my fuel tank but...
the inlet line has the filter on the end in the tank
that goes to the bottom nlet of the carby
the return line goes from under the primer bulb back to the tank
some units run a 3rd line with a filter on the end ( outside of the tank0as that is used to vent the fuel tank as the cap is sealed
the fuel flow is this
through the carby through the pump back to the tank and is only used to prime the float bowl ( needle and seat and diaphragm with fresh fuel and to remove any air in that chamber
Aug 08, 2017 | Craftsman Garden
My Brushwacker has a broken pull start rope (model 358.795800). I figure that it shouldn't be too hard to repair it, but I would like to find a manual for repair.
Good luck on finding a manual. You can get the exploded parts drawing off of the sears parts website! I have a 32cc model 358.791580 and the pull rope broke. The pull rope assembly is located inside of the motor housing. I am having trouble removing the clutch assembly since there is no key way or screw holding it to the shaft. Does anyone know if it is threaded on?
Feb 20, 2010 | Craftsman Garden
Sep 08, 2009 | Craftsman 25cc Gas Line Trimmer
Carb not working
Dont need new carb!!!! Just need to clean that one with solvent. the floats are sticking up allowing fuel to flow. Pull it off then pull it apart and clean it with solvent for an hour. Or spray and wipe it several times with carb cleaner.
Jun 23, 2009 | Craftsman 25cc Gas Line Trimmer
Engine swap 04 zx10r on a 06 zx 636 f
The frame mounting points are completely different. A zx 636 frame wraps around the motor where as a zx10r frame goes directly over the motor. That's how they keep the zx10r nimble enough to feel like a 600cc sport bike. But in this day and age if you have enough time and money you can accomplish anything. Honestly it's just easier to sell your 6 and buy a 1 liter.
May 31, 2009 | 2006 kawasaki ZZR 600
Craftsman Gas Brush Cutter BushWacker 27cc 2-Cycle Straight Shaft Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
