Question about Reddy Heater-30-55,000 BTU Variable
Cad flame sensor
Where can I find a cad flame sensor? thanks
  • 92 Answers
Go to Mr.heater.com and get a CAD flame sensor for any heater with the same btu output. They are all basically the same. The wires will be a different color so just splice them to you old wire harness, there is no wrong way to connect them. I just did the same thing with my dyna glo and it works perfectly. Most heater parts ar interchangeable they just have different wireing.
Posted on Jan 23, 2009
What is a cad cell and what does it do
A cad cell is a photo-electric device that reads the UV rays given off by flame after it has ignited. If it does not 'see' the flame, due to a flame failure OR a cad cell failure, the control circuit is locked out.
Make sure there is no carbon on the front (window)of the cell and make sure its adjustment is in perfect alignment to the flame.
Feb 19, 2015 | All-Pro Kerosene Garage Shop Heaters - All...
Keeps on tripping out
check the right value tripper. kindly check the earth connection are proper
GKM
Jan 01, 2014 | Honeywell "R8184G4074 Oil Burner Control,...
I have a reddy 55......it comes on for about a minute then shuts off....it had a thermostat but that has been bypassed.
there is a cad cell that see's a flame or operates the shut down circuit. Try cleaning the cad cell.
Dennis
Nov 06, 2012 | Reddy Heater-30-55,000 BTU Variable
CAD CELL e-1 code
A cad cell is normally related to an oil furnace and the cad cell is there to make sure that there is a flame. The cad cell is in a close proximity to the flame and can become covered in soot. Try cleaning it if this is unsuccessfull then you may have to replace it. Being close to the flame they do burn out.
Dennis
Oct 31, 2012 | Heating & Cooling
We have a model TS210KT kerosene heater and it runs for 15 sec. and then E1 CAD Cell Shutdown code comes up and the heater shuts down
  1. 1) Check wiring to Cad Cell (per wiring schematic in manual). Test heater.
  2. 2) Clean Cad Cell photo cell.
    a) Slide Cad Cell out of Cad Cell holder.
    b) Push the photo cell out of the white rubber Cad Cell housing by
    pushing on the blue and white wires.
    c) Clean the photo cell with a soft cloth and rubbing alcohol.
    d) Pull the photo cell back into the Cad Cell housing and reinstall into
    holder.
    e) Test heater.
  3. 3) If the heater still does not operate, replace Cad Cell. Test heater.
  4. 4) Replace oil flame control assembly. Test heater.
    Owners Manual with full details here.
Dec 08, 2011 | Mr. Heater Heating & Cooling
My boiler keeps going off and we have to reset the red button
Tripping on the flame sensor sounds like the problem. Try bleeding out the air from the bleeder screw and cleaning the cad cell eye which senses the flame and is located under the ignitor.
Dec 14, 2009 | Heating & Cooling
Heater won't refire after it warms up
If you go to mrheater.com and click on the forced air kerosene heater parts tab you need part #26865 cad cell/flame sensor, it's $2.23 the wires will be a different color and also the plug ends so just clip the wires of the old and new one and splice it to the old wires, there is no wrong way to hook them up, no hot or ground it just completes a circuit. Most parts from this company will work with any heater of comparible btu's. you can also call 800-251-0001 Hope this does it for you. I checked reddy heater and the same part lists for $18.08
Jan 22, 2009 | Heating & Cooling
Reddy Heater-30-55,000 BTU Variable Logo
189 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
