Question about HP Pavilion dv6000z Notebook
Cannot connect 2nd laptop to wireless internet.
Recently reformatted the Acer laptop and when I tried to connect to wireless router I
SMC, Iwas unable to connect. I saw a similar problem on this site and followed the instru
instructions and was able to connect the Acer laptop to wireless. But when I went to
the HP laptop that was connected to the wireless via router I keep getting the
message''The settings saved on this computer for the network do not match
the requirements of the network.''
any help would be appreciated
Ed
    Problem Solver:
  • 12 Answers
Go to your acer and go to net work then net work again and in the tabs above choose add device to net work click on that and put a usb flash drive in and download to flash drive and put the drive in hp and it should automatically run the set up and start to work
Posted on Jan 22, 2009
Bought a new acer 5750 laptop (i5 2nd Gen, 6GB RAM) which connected intermittently to my router. PC World phone help worked through network adapter enable/disable and then eventually a full default...
I would try:
1. updating driver
2. try connecting via Ethernet, if the issue is only wireless connectivity, try using a USB wireless network adapter, if that works means your lappy has a bad built in network adapter.
3. Are you locating laptop too far from router?
Good luck.
Mar 09, 2017 | Acer Computers & Internet
I used to have a simple cable modem (coax cable in, network cable out) connected to a separate Linksys wireless router, model WRT400N. This worked beatifully. To improve download speed, I recently...
Welcome to FixYa!
For you to be able to do that, you will need to set the SMC router to bridge mode, you will not be able to do that by yourself because only tech from your ISP have the capability of doing that since they have this tool that can operate on the router setting it to bridgemode. Basically, you will need to call your ISP to set the router to bridgemode and from there, you will be able to configure the linksys router.
Hope this information will help.
Your response is very much appreciated. Thank you for using FixYa!
Jun 24, 2011 | Linksys WRT400N Router
My internet service is with Suddenlink, I have a SMC wireless router, but I can't connect my Acer Aspire computer to it wirelessly.
Hi - My name is Tina and I am with Suddenlink. Are you leasing the SMC Router from Suddenlink? I'd be happy to help resolve this issue for you -- please contact me directly via email at tina@suddenlink.com. Thanks!
Apr 05, 2011 | Computers & Internet
At&t wireless router and magic jack setup
It could be the router which is giving you issue. Press and hold the reset button for 30 second and this makes the configuration to go back to its previous settings. The reconfigure the router with a new SSID and security key. Try connecting to the wireless network, the computers will consider it as a new network and will connect without any issues
Apr 09, 2010 | 2wire 1800HG Router (RG1800HG00)
No connection, cant install the software
You said that when you connect the computer to the modem, you get limited or no connectivity. make sure that your computer will be able to go online when you connect it the modem directly.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Feb 07, 2010 | SMC Barricade 7004VWBR Wireless Router
Can't get wireless connection
try locating the wireless switch of your new Acer. It might be accidentally turned off thats why no available wireless network found in range
Jun 11, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
My router wont hook back to my laptop and i forgot the password
Go to your control panle then select network connections, if you see your wireless icon, right click it and try selecting repair first.
Also, if the wireless icon is in the lower right of the monitor, right click it and view wireless networks, look for you router, then select it. Then select connect.
Apr 22, 2009 | SMC Barricade Turbo Router
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Can't connect 2nd laptop to wireless network
Did you run the setup wireless network wizard on both computers? If not try this first & see if it fixes the problem. You will find this wizard in the control panel of your windows o/s. Hope this helps.
Jan 22, 2009 | HP Pavilion dv6000z Notebook
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
HP Pavilion dv6000z Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
