Bosch WFL 2450 keeps going back to ready status mid programme
When the machine is operating, the cycle keeps dropping out of the active status and lapsing to ready. We have to keep pressing the start button to keep it going.
  • 4 Answers
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
ginko
  • 19396 Answers
SOURCE: Will not start
To start unplug the machine power cord for ten minutes or longer, this will drain power from the machine and reset the electronic controls.
If this does not fix the problem check the following:
Check that the water supply at the back are opened and taking water into the machine.
Check that the door latch sensor is not stuck, and that door is well closed that is a frequent problem.
Check the drain hose and the drain lines, ensure that there is no blockage in there.
If this still does not work, then the machine has a faulty part that must be replaced, and must be tested by a qualified technician.
Use the phone number listed on the owner manual if you need to contact the repair service.
Posted on Dec 01, 2008
SOURCE: bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Posted on Jun 04, 2009
  • 57 Answers
SOURCE: My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Posted on Dec 08, 2009
  • 523 Answers
SOURCE: It is a Bosch WFF2000. The programme stopped mid
circle at bottom right take it off there is a filter there remove it and look of obstructions.WATER WILL POURE OUT!
Posted on Jun 23, 2010
How to remove *** wire from bosch wfl 2450?
Here you go....
http://www.scribd.com/doc/187416757/Bosch-Maxx-Wfl-2450
Aug 21, 2014 | Bosch Washing Machines
The water does not cutoff during rinse cycles on the rinse plus and normal wash programmes on my Bosch Maxx WFL 2060 but works fine on quick wash programme
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
Feb 14, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
May 17, 2009 | Bosch Washing Machines
Bosch classixx 1200 washing machine stalling mid-cycle
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Changing brushes on motor of Bosch WFL 2450 washing machine
Remove rear panel of washer, and undo 2 screws that secure the motor, lever motor back with a screwdriver or similar, and unplug motor lead.
Be sure to keep hold of the motor so it does not drop on the floor.
You will see the brushes at the terminal end of motor, remove and replace.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Washing Machines
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFL 2872 washing machine has just started beeping (3 beeps) at approx 1 minute intervals at end of program until I turn machine off. washer is 3 years old & has never done this before - does it...
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
Jul 24, 2008 | Washing Machines
Bosch wfl 2450
Jun 01, 2008 | Bosch Classixx WFL 2462 Front Load Washer
2nd Bosch washing machine same problem
Since you faced the same problems with two new machine's, it sound like a manufacturer problem and you should ask for another new washer or to get your money back !!!! Good luck !!!
Aug 18, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
69 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
