Question about Toys
Assembly instructions for blue mountain quarry
Imaginarium Mountain Rock Train Table assembly
None of these are for the Mountain Rock Train Table. Instead they are for other sets. I'm also looking for the Mountain Rock Train Table instructions. Not the Mountain Pass set. They are different.
Dec 29, 2013 | Toys
Do you have the assembly instructions for the Imaginext T-Rex Mountain? Thank You.
Hello Bread
Push the raised tabs on the backs of the upper and lower skull pieces into the fitting holes on the frame piece. Insert the screws into the back of the frame and tighten with a Phillips screwdriver. Stop turning the screws as soon as the heads meet the frame to avoid cracking the plastic pieces.Loosen the screw holding the battery compartment door on the inside of the upper skull piece. Install three AAA batteries to power the sounds and lights for the T-rex mountain set. Replace the door and tighten the screw.Work with your child to snap together the pieces of the mountain setting for the initial assembly. Follow the pictorial directions inside the Imaginext building toy to assemble the configuration shown on the label of the box. Step in to aid your child only when necessary to follow the instructional diagrams.Reach in under the upper jaw of the skull piece and slide the switch to the on position marked by a black filled in circle to activate the lights and sounds on the Imaginext play set.Push one button on the top of the skull to light the eyes and make jaws move. Push the button next to it make the eyes glow and sound the chomping noises. Push the claw button at the base of the mountain to make the claw drop and trap action figures. Push the button next to the tree to make it fall over.
Mar 19, 2011 | Fisher Price Toys
I am needing assembly directions to the imaginarium mountain pass train set; we lost our directions in the move and we are wanting to set it up again. Thanks!
I've published a copy of the assembly instructions, graciously provided by Olivia, for all to refer to/download as needed for the Imaginarium Mountain Pass railroad set. It is a pdf file and hosted at issuu. Link below...
http://issuu.com/sweetcheet/docs/imaginarium_mountain_pass_railroad_instructions?mode=window&viewMode=singlePage&backgroundColor=%23222222
Oct 06, 2010 | Toys
ASSEMBLY INSTRUCTIONS FOR IMAGINARIUM TRAIN TABLE
My kids shredded it, so the part where the mountain is missing. But there is enough of the schematic to put together this train. Unbelievable that these instructions are so hard to find. Very happy to be of help to everyone!
Thanks.
Aug 10, 2010 | Thomas and Friends Imaginarium...
Looking for assembly directions for Huffy blackwater men's bike
Go to parktool.com/repair for information on bike assembly, disassembly, repair and tuning. The assembly of any bike is more or less the exact same as any other, so this website will give adequate instruction for your bike.
Dec 25, 2009 | Huffy Blackwater Men's 26-Inch Mountain...
Instructions to replace the glove box light assembly on a 2000 mercury mountaineer
give these websites a try www.alldatadiy.com and www.autozone.com for the most part if you have a autozone near you and you get the blub from them they will help you install it wish you the best of luck Michigan Man.
Oct 31, 2009 | 1997 Mercury Mountaineer
Need instructions on assemble of the Moose Mountain Kawasaki Ninj
you should have to use hammer to tap on the small metal caps onto the axle! to hold wheels in place!
Cheers Rob.
Jul 28, 2009 | Moose Mountain Marketing Kawasaki Ninja...
1998 Mercury Mountaineer Plastic Fan
yes this sounds correct but if you want to get a diagram and step by step instructions try "autozone.com"
Mar 08, 2009 | 1998 Mercury Mountaineer
Toys Logo
492 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
