Question about Rockford Fosgate P3001 Car Audio Amplifier
Fuse blowing My Rockford Fosgate P3001 stopped working and it keeps blowing fuses when the power wire is hooked to it. I dont believe it have ever smoked before. When the fuse touches the slot it goes in it blowes. i am not very electronically inclined so please tell me what i can do.
    New Friend:
  • 83 Answers
Send it off for repair
Posted on Jul 06, 2007
SOURCE:
Where's the fuse located in a Fosgate p300-1 amp?
It is just to the right on the rear of the amp next to the 12 V + - RTO +
Here is a link to a picture:
http://www.crutchfield.com/S-mj0Klw5sfLm/p_575P3001/Rockford-Fosgate-Punch-P3001.html
Feb 14, 2012 | Rockford Fosgate Car Audio & Video
I have a rockford fosgate punch P325.1 subwoofer mono amp that blows a fuse every time i start the car. I have a second pioneer amp but that works with no problems. How can i fix this?
Is it the correct size fuse ? Is it the power fuse or remote ? Either way check your connections going into the amp . Try this hook your other amp to the set of wires for the rockford if that amp has a problem its a wireing problem if not chances are its an interal problem on the rockford . Hope this helps !
Aug 19, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
I have an spl gorilla series 1250watt amp that blows fuses
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL BLOWS THE FUSE, THEN IT WILL NEED TO BE SERVICED. IF IT BLOWS THE FUSE BEFORE TURNING IT ON, THEN YOUR PROBLEM IS IN THE POWER SUPPLY SECTION. IF IT BLOWS THE FUSE AFTER ATTEMPTING TO TURN IT ON, THEN YOUR PROBLEM IS PROBABLY IN THE OUTPUT SECTION. ALSO KEEP IN MIND THAT THE P1'S ARE REALLY NOT RATED FOR THAT MUCH POWER AND YOU MAY HAVE DAMAGED THE VOICECOILS. BEFORE REINSTALLING THE AMPLIFIER, MAKE SURE TO CHECK THE SPEAKERS FOR SHORTED VOICECOILS OR YOU WILL POSSIBLY DAMAGE THE AMPLIFIER AGAIN. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 19, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
BLOWS FUSES
If it blows fuses only after the remote voltage is applied, the amplifier likely has shorted output transistors.
Let me know if you have any other questions.
Aug 30, 2008 | Rockford Fosgate RF2002 Car Audio...
Rockfordfosgate amp 750s car problem
Disconnect all speaker wires and RCA cables from the amp. Replace the fuse with a 30 amp fuse and power up the amp. If the fuse blows, the amplifier probably has shorted/leaking output transistors.
Jan 02, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Fuse
Seems to me like there is a short somewhere, check all of your wiring. If it is still blowing fuses when it is wired so that all it has is power and ground, then you have something shorting internally, most likely a capacitor.
Nov 27, 2007 | Rockford Fosgate P3001 Car Audio Amplifier
P3001 amp may be fried
Check this out: http://www.techlore.com/article/14696/
Aug 06, 2006 | Rockford Fosgate P3001 Car Audio Amplifier
Rockford Fosgate P3001 Car Audio Amplifier Logo
378 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Professor_V
Professor_V
Mike Duncan
Mike Duncan
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
