Question about NAD C320 2-Channel Amplifier
Nad 310 no power
My nad 310 just plain dead..no light, no sound..suspected the toroidal transformer. what is the output V of the toroidal? because i can't get the same part here, so wanted to get it from other manufacturer...or maybe will use normal type of transformer...thank u..
    Scholar:
  • 140 Answers
The output should be 24v ac. Sounds like you have a busted transformer. Did you check out the resistor in front of the transformer.
You sound like you know what your talking about so I will not bore you with suff like glass fuses and thermal couples.
Good luck, I have had a few items like this over the years. Sometimes it's just best to send them in to the manufacture. I would look for a replacement transformer. 120v ac to 24v ac around 5 amps. Test it out and see if it works... If not, send it in.
Posted on Jan 23, 2009
Completely dead NAD M15, is there an internal fuse that I can change ?
NAD M15
Problem : Dead
Possible solution : Check for Power Supply
How to Test a Transformer: 7 steps - wikiHow
If these has been done,
• Check amp power supply and low voltage regulators
These includes fuses ( many of them )
Tech Center tells you how to use a multimeter .
• There could be other electronic components but try on them first.
If the torroidal transformer is OK , then it could be a problem on the
Circuit boards.
There could be a shorted components somewhere.
Jul 29, 2012 | Audio Players & Recorders
Hi, Toroidal transformer in Sakura AV-200T input is 220v I need 110v Thanks
Hello shole135, Hi, you need a 110v to 220v step-up transformer with 200 watts power specification. you can visit your local hardware store and find one. Don't replace the toroidal transformer.
Dec 02, 2010 | Audio Players & Recorders
Tv wont come on lights up green the power button then goes out then flahes once more and there is a alarm sound coming from the back of the tv. thanks for any help
i suspect the sound your hearing is a whooping sound. this is a dead give away. i suspect you have a shorted horizontal output transistor do to a bad flyback transformer. they will need to be replaced.
Oct 07, 2010 | RCA HD52W59 HDTV Projection Television
NAD C352 turns on but no sound
The first and easiest things would be to check all connections.
Speaker wires
RCA Cables !!
If you are getting a green light you are getting proper power and ground connection.
Other than that the other possibility's would be internal components, capacitors ect.
I would be willing to bet something has come jarred loose. Post back after you have checked and double checked all connections.
Aug 12, 2009 | American Pro VS-2043 Car Audio Amplifier
Nad c350 no power at all
check your output stage for bad speakers cable or bare wire of cable touch the body of amp----short circuit speaker cable----bad speaker it self------ bad input cable or defective input device .
disconnect all and check if it is ok---start to connect one by one from input to outputs------if all above failed you must contact service center for help.
Aug 22, 2008 | NAD C320 2-Channel Amplifier
Nad 218 thx power amp keeps blowing ac plug fuse
Hi there. From memory they had bridge rectifier problems with them going short circuit. Check them first. Sometimes the toroidal transformer can go a shorted turn, in turn blowing primary fuses. try to soft start it whilst it is blowing fuses, Best bet is to make up a special lead that has a 60w light bulb wired in series with the mains power supply(or across the fuse holdwer that is blowing:). Limits the power in the circuit to ... well you guessed it 60 watts.
check em out and let me know.
regards
Graeme
Apr 27, 2008 | Audio Players & Recorders
Replacement Toroid Transformer
If you are refering to the DC +- 65 Volts the AC side will be different. What you need to find out is the average loaded AC volts on the secondary side of the transformer.
Below is the link to one of the biggest transformer companies in the world. I go to them all the time for transformers and power supplies for high end audio equipment and especialy for custom design and construction. I am sure they can wind you a new transformer once they know the exact specs you need.
http://www.hammondmfg.com/
If you do a Google search, there are a fair number of companies that do custom transformer winding.
Jerry G.
Apr 26, 2008 | Audio Players & Recorders
NAD C541i CD Player won't turn on
Hi John,
Coincidentally enough, I have a customer's C541i on my bench right now!
At this point, you will need to open the cover and check the fuses. With the cover off, looking from the front, all four fuses are in the back left corner of the player, next to the toroidal (round) power transformer. If any of them have blown, replace that fuse with exactly its type and rating. DO NOT jumper over the fuse, or wrap foil around it. It is EXTREMELY rare for a CD player to blow a fuse unless there is a very serious failure someplace.
If the player blows the new fuse/fuses immediately it will need to be serviced. If the fuses hold, and the player plays, it was just one of those random things.
Now, IF all the fuses are good when you first check it, you have a mechanical failure in the power switch, or a broken solder joint on the board where it's attached. Luckily, a replacement switch is easy to find.
Apr 24, 2008 | NAD C541 CD Player
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
No power
The inverter boards for the backlights fail on these HP F series monitors. Sometimes it is cold solder joints on toroidal coils. Sometimes the transistors that drive the output transformers (4). It is not difficult to repair if you have good soldering skills. I usually resolder the toroids and replace the transistors regardless of culprit. You may see the heating effects of bad components (discoloration) on the board.
Dec 28, 2007 | HP Pavilion F1703 17" LCD Monitor
NAD C320 2-Channel Amplifier Logo
379 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
