Question about Synology Disk Station DS-106e (DS106E) 500 GB
Disk does not get power - Synology Disk Station DS-106e (DS106E) 500 GB
My ldhd up 2 don't power on
All HD detection problems should be tackled by 1. Changing the power supply. 2. Changing the SATA data cable. 3. Changing the SATA power cable. 4. Changing the disk, even a new disk without Windows will do. My BIOS tries 3 times to discover the disk. My problem disappeared after using WD40 on the contacts of the disk; it was oxydation.
Jan 11, 2015 | Power Computers & Internet
External hard drive
take out the hard disk,install it directly on your pc's sata interface.
Dec 08, 2013 | Acer Computers & Internet
Everything has been working okay on this compaq until this morning. Upon powering up a Red and White HP screen pops up that turns into a black screen which reads quite simply: "Disk Boot...
The computer could not read your copy of Windows from your disk-drive.
Either:
* there is no electrical power getting to the disk-drive (check the power cable)
* the "data" cable between the motherboard and the disk-drive is faulty or not-connected (check it)
* the power-supply in your computer is not supplying power to the disk-drive (try different power-supply)
* the disk-drive itself has "failed" (maybe, the motor that spins the disk-drive has failed)
Take your computer to a professional technician for trouble-shooting.
Jun 12, 2011 | Compaq Presario S6300NX PC Desktop
Por que me sale an internal error in the initialization stage
Initialing stage is indication that the computer is undergoing restore to system default. First, at which stage where the computer stops performing restore is indication that disk is either scatched or dusty requiring cleaning. Power shut the computer completely from the shut off button because attempting to press the disk button instantly would cause impact that may damage the restore disk. Power on the computer from the power on button area. Immediately press the disk button to before the computer attempts to capture the media in disk driver. The computer disk driver should pop open immediately to make available the disk. At which point, inspect the restore disk for scratches or dust by simply cleaning with clean tissue paper. Also, observe the disk for compartibility with the computer systems. For example a computer performing on windows XP would least require update restore with disks that are Windows 7. Discontinue restore if realised that the computer is inconpartible to the disk attempting to derive restoration from. If the condition was due to dusty or scratches, simply cleaning the disk should make commenceable the restore process.
Feb 08, 2011 | HP Pavilion dv6000z Notebook
My aspire l310 won't boot. It keeps telling me media cable test failure and disk boot failure. Help daniel
sounds like hard disk related. turn it off and disconnect the power cord, remove and reconnect both the power and data cables to the hard disk, disconnect any external USB storage and remove any floppy disk, if any. If you get the same result, try to connect the har disk using different power & data cables (IDE/SATA), and test it on another SATA channel if available. If same error, you may need to reformat the hard disk and reinstall WIndows, or you may have to get a new Hard Disk if it fails even when tried on another computer.
Aug 31, 2010 | Computers & Internet
Cannot detect inserted disks
I would try the simple things first. Ejecting the disk and putting it back in, Turning off the power for at least 1 minute then turn it back on, Check all Power cables. If this does not work i hope someone else can help with it internally.
Dec 25, 2009 | Nintendo Wii Console
HItachi deskstar Hard disk 80gb 7200 rpm
check the power cord of your hard disk. It should be tight not loose, if not solve then change the power cord.
Nov 25, 2009 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
HARD DISK IS NOT DETECTED
check the data cable and power cable connectors of the harddisk, otherwise the hard disk check on other computer.
Feb 14, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Sony VAIO VGN-FJ3M/W does not boot.
Possible hard disk failure or hard disk controller failure.
if you feel confident remove the hard disk and replace - obviosuly make sure that there is not power running and remove the battery - replace hard disk then battery then power and try again.
Do you get any beeps? is the hard disk clicking? listen carefully to it and post your findings.
Jan 10, 2009 | Sony VAIO VGN-FJ270/B Notebook
Computer freezes cause of WDexternal hard disk
does your wd external hard disk use external power or bus power.... if it uses external power this effect could be due to feeding of power from the external power to the usb port...
Nov 07, 2008 | Western Digital My Book Essential Edition...
Synology Disk Station DS-106e (DS106E) 500 GB Logo
18 people viewed this question
Top Synology Computers & Internet Experts
David Payne
David Payne
Are you a Synology Computer and Internet Expert? Answer questions, earn points and help others
