Question about Canon imageRUNNER C3200 Copier
Facsimile Can not get the fax settings to appear in Additional functions under fax settings.
  • Ian  Auret
    Ian Auret May 11, 2010
    Hi
    What do you want to change under fax settings?
  • Canon Expert
  • 1,326 Answers
Are you sure you have both the correct PCB's installed? And are they wired correctly?
Posted on Apr 06, 2009
I have a Canon CFX-L4000 plain paper facsimile with no manual. How do I set up date and time?
Download the manual from here:
CANON CFX-LX4000 Plain Paper Facsimile User's Guide (this is a temporary link)
The manual was posted to and should be available from FixYa soon
Oct 01, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
I lost the manual to the Canon LaserCLASS 510 and need to delete one of the fax numbers already programmed. I know it's a simple step, but everything I've tried hasn't worked. All I want to do is edit the...
If you still need the manual I have the electronic version of the Reference and Facsimile guides
You may want to print the list of the speed dial numbers before so you know which one(s) you want to edit and to have a backup list in case something bad happens -> Additional Functions button then press arrow keys until 8. Print Lists appears then press Set button. Press arrow keys until Print Lists appears then hit Set button then use arrow buttons until Speed Dial List appears then press Set then select the list you want to print (1-Touch, Coded Dial or Group List)
Additional Functions -> press arrow keys (or plus/minus) until 5. Add. Registration appears then Set button
Presss arrow keys until 2. Coded spd dial appears then press Set button
Press Coded Dial then enter the 3 digit code for the number you want to edit (or use plus/minus) then press Set button
Press arros keys until 1. Tel number entry appears then press Set button
Jun 09, 2010 | Canon LaserCLASS 510 Printer
Lanier MPC 3000 copier won't print faxes
Try opening up your web browser and type in the ip address of your lanier.
You should to access the facsimile function located on the left side. Once youre in the facsimile function, you should see a thumbnail view of the faxes stored in your lanier. Simply click on the faxes and delete them.
Sep 22, 2009 | Lanier Office Equipment & Supplies
Cannot find confirmation page "on off switch" Ricoh Afico 2035esp
User Tools/Fax/Parameter Settings. Personally I wouldn't mess with those, it's to easy to totally mess up the fax system if you flip the wrong bit switch setting. I threw my 450 programing guides away some time ago being that there's just a hand full of these things left in the hole country. I believe if you go to Ricoh's web site and go to the download page, you can download the fax user manual which if memory serves me (and it often doesn't), you'll find how to change the fax parameter settings.
Jul 29, 2009 | Ricoh Aficio 450 Copier
How to lower volume of the fax dialler
Press the additional settings button(star head), I think it's in communications settings, fa settings. There is are two volumes, one for alarm and one for dial tone.
Jul 10, 2009 | Canon imageRUNNER C3200 Copier
Incoming faxes do not show time or date
function-7-4-start-9-start-2-start-stop
this should print the time and date on the paper
Jan 22, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
When i put it in fax mode it turns off
Press User Tools/counter button;
Select System settings;
Select General Features;
Press the down arrow button to find Function Priority and press OK;
Select Facsimile and press OK.
Then switch off and on the machine.
Now at switch on you you will notice that it is in Fax mode.
Good luck and please rate me, thanks.
Jan 13, 2009 | Gestetner DSm415pf Digital Imaging Sytem
Faxing Long Distance
To my knowledge, if the unit can send a fax message to another fax machine then it is safe to assume that there is nothing wrong with the fax.
Perhaps your problem may be more related to the type of phone subscription that you may have. Some phone providers have subscription for local calls only and restricted long distance. Alternately, there are some phones that would need a series of numbers to be pre-dialed before long distance access is granted.
Pls check with your local phone company. Additionally, you can try by calling long distance using your regular phone and see if it works. If it does, then long distance restrictions has been imposed/enabled in your Canon 3300. The procedures are better explained in the users manual. A copy of the user's manual for Mac users is here, all other downloads including those for Windows, is here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Sf 1110
Press Function>start,This should print the help list.
Samir
Mar 09, 2008 | Office Equipment & Supplies
Fax Header
Press "User Tools" Press "Facsimile Features" Press "Gen/Settings Adjust" Press "Program Fax Information" Press "Own Fax Number" Press "For G3-1" add your number That's it!
Oct 19, 2007 | Ricoh Aficio 1022 All-In-One Laser Printer
Canon imageRUNNER C3200 Copier Logo
old marine
old marine
