Question about HP Officejet 5610 All-In-One InkJet Printer
L7680 will not print in b/w
Thi printer is just out of the box and will not print in b/w .It however prints in color without any black text.
Mike.
    Scholar:
  • 97 Answers
Please click on setup button and scroll down to tools and allign and print heads and catridges. it should resolve the issue.............
Regards,  raj_p5983
Posted on Jan 22, 2009
Will not print black but prints all other colors cahnged black cart but not working still
What if you print color with black? Can you notice the black on the prints? First of all, check your print settings from the "printing preference". You might have selected the "high quality" you should set it to "black ink only" as shown below; cc9d506.jpg
Apply the changes and check the prints. If this doesn't help, do let me know.
Good luck.
Thanks for using FixYa.
Jun 19, 2010 | HP Officejet Pro L7680 All-In-One Printer
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can i print in black if my printer has run out of coloured ink?
Hi judysimeon
Goto the printer settings page and change the settings to print in black . Normally it is set for color - when color and black will print - You will find the question Print in Color Or Black Each has a check box. Check the box for black. With this setting, everything will print in black including the color text and graphics.
Most printers let you do this. However, some printers keep telling you to replace the color cartridge.
Hope this will work for you.
Good Luck
luciana44
Apr 10, 2010 | Brother DCP 130C All-In-One InkJet Printer
My canon MP145 three-in-one printer cannot print because the coloured ink has finished. How can i continue to print using black ink only?
Hi joyce2020
Some printers do print even if one cartridge is empty.
This is what you have to do. Goto the print setting page. you will find check boxes for Print in Color OR Black& White.
Usually, the color box is checked. When you check the box for color, you can print in black and white as well provided the text is written in B&W. If you check the B&W, the printer will print everything in black including color text and graphics.
Good Luck
luciana44
Apr 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
How to print in black and white only
Goto Control Panel > Printer and Faxes > Right Click > Printer Prefernces
(on your desired Printer)
A dialogue box will appear, now from here every printer got a bit different tabs.
Even though its too easy to find somthing like "color".
Under such tab you will find options like
  • Color Printing
  • Gray Scale
  • Black Ink Only
  • Toner Saver mode (For Lasers)
So select the Black & White option, and its done.
Do Rate Me!, If helpful.
Jul 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
Printing without color?
Im sorry to inform but yes, Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
HP Officejet L7680
i say change the print head an the cartrige an that should be find
couse i did an my printer is perfect
by andrew
Feb 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
