Question about Toshiba Satellite L455-S5975 Series Laptop Auto Car Adapter (C1965UM3100F20BB4)
Error f3-f100-0004 Boots up starts windows ends up with errror F3-100-0004 I click OK and it shuts off. repeat.
    Master:
  • 969 Answers
Corrupted operating system Reload selecting the "repair" option.
Or restore from back thru Safe Mode if access is possible.
Posted on May 25, 2014
Panasonic toughbook cf-74 blue error screen loop
Which OS do you have? Have you tried booting to safe mode?. Restart the computer. Immediately after the BIOS post ends, start tapping the F8 key repeatedly. when Windows Advanced Options menu appears, select safe mode and see whether it boots completely without blue screen(BSOD)
Apr 22, 2014 | Tablets & eReaders
Why does this come up? There appears to be an error with your installation. Please reinstall the application. Always pop up everyone I
If this error appears every time you start the computer, then there is a program in your system start up that isn't properly installed. I can't tell you which program without more information. A quick search shows that this is a common problem with DriverCure and FileCure. Uninstall/reinstall them if you have one of these programs.
If you don't know which program it is, then you need to go through your startup programs one by one.
Press "windows key + R" to bring up the run dialog box.
Type in "msconfig" and click "OK."
If the UAC dialog box comes up, click "Continue."
Click on the "Startup" tab.
It will display a list of every program that runs when your computer boots. Uncheck the first box for the program that you think might be causing the problem and then click "OK."
A box asking if you'd like to restart your computer will appear. Click "Restart Now."
A dialog box will appear notifying you of changes to your startup, click "OK" and msconfig will reopen.
If the error reoccurs, then uncheck the next item on the startup tab and repeat until you find the one causing the error. Make note of the name of the last thing you unchecked and uninstall/reinstall that program.
To get rid of the startup notification box, simply check "Don't show this message..." before clicking "OK"
Oct 22, 2012 | Computers & Internet
How to fix Dll could no be opened
Be very careful if you follow next procedure, it can make useless your computer.
At window top it says dll's name, take note of it and:
1. Click on start2. Type REGEDIT3. Click yes on User Account Control4. At Registry Editor press F3 (single key at top of your keyboard)5. Type dll's name, including its extension (ex. dname.dll)6. Every time you find it, then erase registry field.7. Press F3 again and repeat steps 6-7 until finish.
If you doubt it, better not do it! Take it into service center.
Oct 03, 2012 | Dell Inspiron 600M Notebook
Conputer is shutting down but it does not shut down
Hold the power button until the computer shuts down.
Restart and press F8 key repeatedly until you get a start up menu.
Select safe mode from the menu.
After the computer boots up, and you are at the desktop, go to my computer and select properties of the C drive (your system drive). Select tools from the tabs, then defrag. When defrag finishes, select check drive for errors and select the box, to automatically fix errors, and then ok, and yes at next window, allowing the computer to schedule the error check at next boot.
Reboot and allow computer to scan the drive.
After it finishes, you will continue into windows. Allow windows to boot. After it finishes, attempt to shut down again.
If it works, you fixed it. If not, you have a driver or program that will not quit, and you will have to research further to find out what is running and why it won't quit.
Dec 16, 2010 | Acer Aspire 5735 Notebook
Computer boots up then shows windows 98 scrren
you may face either harddisk failure, a driver problem or virus infection:
tools: original win98-cd (or a bootable image
version of it), antivir-software on cd!
- please check whether it is possible to boot from win98-cd, with cd-rom support, not from harddisk.
(such option should be availabe after bios-load is over)
if not:
leave the setup process without fully installing
(press F3 button when asked for repair or install option)
in both cases :
type at the dos-prompt:
c:\win98/win
(command for changing to harddisk, windows-folder, booting windows from harddisk, but without loading all the drivers as usually)
win98 should come up in protected mode or give error messages.
- access cd-drive and execute vir-scan.
- delete and/or repair infected files
- turn down, attempt to reboot from hd
- if still impossible reboot from win98-cd,
run repair of installation and try once again
standard boot
problem solved? if not, take down error messages consult fixya again!
Jun 13, 2009 | Dell XPS M140 Notebook
IBM server dc can't boot due to system32\drivers\pci.sys missing
You mention on boot that the server shows a logical drive of 158GB, which obviously means the server is detecting the drives ok.
Quite often Windows doesn't have the correct drivers to support systems using RAID controllers such as IBM ServerRaid, so this is probably why the setup CD states "No HDD detected, press F3 to reboot". When the Windows Setup CD Boots, it should at some point (on the blue screen) at the bottom of the screen state something like "Press F6 to load additional drivers". If you can get the correct drivers from IBM website, and load them by pressing F6, Windows should be able to see the drives ok. Hopefully it will then be able to successfully repair the error.
May 23, 2009 | IBM eServer xSeries? 206m
Windows shut down unexpectedly, and when I rebooted, I had lost all my icons, and start tool bar. How to get them back?
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
    Windows XP to run on your computer:
    To setup Windows XP now, press ENTER.
    To repair a Windows XP installation using Recovery Console, press R.
    To quit Setup without installing Windows XP, press F3.
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" width="15" border="0" height="21" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.take care god bless
May 06, 2009 | Computers & Internet
Laptop locks up during shut down
fist of the click the start and click the run and type the recent and click.......ok and remove the all file in new windows
second method click the start and click the run and type the chkdsk and click.......ok
thard method click the start and click the run and type the temp and click.......ok remove the all file in new windows
Apr 01, 2009 | Dell Inspiron 1501 Laptop
Application Error
How to Repair this SVCHOST.EXE error
After some investigating into the 0X745f2780 SVCHOST error, it became apparent the problem is a corrupted Windows Update in Windows XP. Follow the steps below to fix this error.
Verify Windows Update Service Settings
  • Click on Start, Run and type the following command in the open box and click OK
    services.msc
  • Find the Automatic Updates service and double-click on it.
  • Click on the Log On Tab and make sure the "Local System Account" is selected as the logon account and the box for "allow service to interact with desktop" is UNCHECKED.
  • Under the Hardware Profile section in the Log On Tab, make sure the service is enabled.
  • On the General Tab, the Startup Type should be Automatic, if not, drop the box down and select Automatic.
  • Under "Service Status" on the General tab, the service should be Started, click the Start button enable it.
  • Repeat the steps above for the service "Background Intelligent Transfer Service (BITS)"
Re-Register Windows Update DLLs
  • Click on Start, Run, and type CMD and click ok
  • In the black command window type the following command and press Enter
    REGSVR32 WUAPI.DLL
  • Wait until you receive the "DllRegisterServer in WUAPI.DLL succeeded" message and click OK
  • Repeat the last two steps above for each of the following commands:
    REGSVR32 WUAUENG.DLL
    REGSVR32 WUAUENG1.DLL
    REGSVR32 ATL.DLL
    REGSVR32 WUCLTUI.DLL
    REGSVR32 WUPS.DLL
    REGSVR32 WUPS2.DLL
    REGSVR32 WUWEB.DLL
Mar 30, 2009 | Microsoft Windows XP Professional
My laptop is not switching on
  3. Press Enter to start the Windows Setup. note.gifTo Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" border="0" height="21" width="15" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
Oct 22, 2008 | Toshiba Computers & Internet
Toshiba Satellite L455-S5975 Series Laptop Auto Car Adapter (C1965UM3100F20BB4) Logo
96 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
