Question about Liebherr Refrigerators
Freeze not working - Liebherr Refrigerators
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Not enough info
Posted on Jan 12, 2013
Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Jun 13, 2015 | Faby Cab S.p.a Faby CAB Frozen Drink...
Coils freezing up..is this normal? Not sure how this is supposed to work. Could it be that it freezes the water, then turns off and empties into the pan?
The coils should not freeze up. If the fan is working, try lowering the setpoint to just below actual humidity. This will allow the dehumidifier to run and shut so water can drip off without freezing. If that works, slowly lower the setpoint over the next day or so. If the setpoint is too low, the unit runs continuously until it freezes, then never shuts down.
Gary
Aug 30, 2011 | Kenmore Dehumidifiers
The freeze protection just quit qorking when it dropped to freezing i turned the dial to 45 and it still will not come on has been working non stop for about 4 days. i am in the dfw area
You can replaced the freeze control without buying entire timer:
Google: "Intermatic thermostat freeze control" to see cross selection of choices.
For example Smarthome sells PF1103 for $80: works for 120 or 240
http://www.smarthome.com/42699/Intermatic-PF1103M-120-240V-Freeze-Protection-Control-Timer-Mechanism/p.aspx
To prevent freezing right now, the pump should run full time, so pull trippers off the timer dial, and mover override lever to ON position. This will keep the pump running.
When the temperature rises, put trippers back on dial, and then order new part.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 06, 2011 | Intermatic Timer PF1202T Multi Circuit...
Are there freeze plugs on a 2005 Chevy Equinox? We had a hard freeze last night and now the heater doesn't work.
Freeze plugs are actually Core plugs for the block to get the sand out when casting the engine block from cast iron. They actually have nothing to do with freezing, or the heater. What do you mean by "doesnt work" ??? doesnt blow at all? doesnt blow hot?
Dec 14, 2010 | 1992 Chevrolet C1500
Ice maker stopped working. can hear motor whirring, but no ice
dear sir/madam
please make sure first freeze,s compressor and fan is working if both are working and it,s not getting freeze then there possible any leak in your freeze so please contact to your maintenance personnel for find out this leak and make brazing it. and then refill the gas in your freezing system, i hope after that it will work well.
hope answer the question
thank you
please vote!
Aug 27, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Dehumidfier freezing up
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
Oct 21, 2009 | Frigidaire FDL60P1 Dehumidifier
Freeze panes doesn't work in mac excel
HOW TO FREEZE THE TOP ROW OF EXCEL FOR MAC:
Wow - using the above ideas I figured out how to freeze the top row!!! Thanks guys!! Here's how:
1.) Use 'Normal' View (i.e. look up at tool bar, hover over 'View' and make sure 'Normal' is checked)
2.) Select cell B2 (only the cell, not the row or the column)
3.) Click 'Window' (from the tool bar at the top of your screen)
4.) Click 'Freeze Panes'
...et voila! :-)
Apr 09, 2009 | Apple Mac Pro Desktop
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Water dispensor is not working, ice dispensor is work fine
It depends on where it is freezing. Can you determine where the freezing is? These things don't usually clog. They can develop what is called a vapor lock in the water dispenser behind the meat drawer in the refer. For freezing let me know where it is freezing.
Nov 18, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerators Logo
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
