Question about Hampton Bay 36 In. San Marino in Brushed Nickel Fan
I need to reinstall a san marino 36 inch ceiling fan and cant remember which wire the blue light wire is supposed to attach to: the white or black wire running from the breaker?
  • 8,197 Answers
To the black wire. So it should be from fan black and blue to black in box. and white and white together.
Posted on Jan 22, 2009
Fan Switch Change out
Should have written that down when you took out the old one. Anyway, just because a switch looks the same on the outside doesn't mean it's the same on the inside. If you don't find the correct switch let me know. I need to know how many wires on your capacitor And which wire went into which switch opening. usually the black goes into the L.
Jun 25, 2013 | Dryers
Fan speed switch wiring
If your are replacing the fan speed switch on the Hampton Bay San Marino mfg # 67353, this is the correct wiring pattern...L-white, 1-yellow, 2- blue, 3-black. I have been searching for this answer for 2 days. Thought I'd post for others with the same problem.
on Jun 01, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Fan works, but not the lights, made electrical connections.
mcdevito75 here, The lights should work when the wall switch is turned on, You may have to remove the wall switch cover to check the color of the wires and then the cover just at the ceiling of your fan, follow the fan wires from the pull switch for the fan, since the fan works you don"t have to worry about those wires, just the others for the lights, match the color codes, from the wall switch to the light wires. You may have a RED from the wall switch and red from the fan, hook them togethet then the black or white wires. You may not have a red from the wall, rather a white and blck. Make sure wall switch is off and or fuse / circut breaker is off while working on the se wires.
Jul 27, 2010 | Hampton Bay 36 In. San Marino in Brushed...
Lights are out
The manufacturer is King of Fans. Their number is 800-330-3267.
Nov 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Hampton Bay San Marino 36" Ceiling Fan
18 gauge is a little light... should use 14. Are you sure it is a hum, or is it possibly the fan resonating due to imbalance of the blades. Watch to see if the fan is oscillating when it runs. Also, does changing the speed affect the frequency of the hum. If this is the case, you have to balance the blades using metal shims.
Sep 20, 2008 | Hampton Bay 36 In. San Marino in Brushed...
Aloha breeze 52 white ceiling fan
Is there something specific you need to know?
Kill power at the breaker for saftey. Mount the bracket to the ceiling first. there should be a small hook on the ceiling bracket that you can hang the fan motor from while you do the wiring.
The blue wire and black wire on the fan should both be connected to the black wire in your house wiring. Attach the fan blades to the motor once it is in place.
Aug 02, 2008 | Aloha Housewares (93645) Ceiling Fan
Removing fan from ceiling
If there is a bowl looking thing that is attached to the ceiling, that should be unscrewed (PLEASE NOTE WHEN DOING THIS TURN OFF THE POWER TO THE FAN VIA BREAKER!) It'll come down and you will see the wiring, un-do the wiring (it is color coded so you can put in a new one pretty easy). there will be a cup and a socket that is holding the fan in place, gently lift the fan up and out of the socket. there you go.
Nov 05, 2007 | Hampton Bay 36 In. San Marino in Brushed...
36" San Marino fan has one speed
thats the cap.the capacitor is used to jump start single phase motors.if the capacitor is shot the motor barley does anything.if you can find any # or markings on it take it to radio shack and match it up.
Aug 29, 2007 | Hampton Bay 36 In. San Marino in Brushed...
Hampton Bay 36 In. San Marino in Brushed Nickel Fan Logo
293 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
