Question about Garden
I have taken the blades off of the support bar and sharpened them when i bolted them back on they wont fully tighten is that normal? Ade.
  • Ade King
    Ade King Jan 14, 2013
    I think the blades are meant to stay loose to flick back if they hit a rock etc but i wanted to be sure. Ade.
    Sergeant:
  • 322 Answers
There should be a block that the blades bolt too with something that will hold the blades stationary. The block is there to "break" when the blades encounter a sudden stop to help prevent engine damage. A couple of type of blocks are a star pattern that goes into the center of the blade or 2 pins that go on either side of the center hole
Posted on Jan 16, 2013
rwvanlue
  • 486 Answers
SOURCE: how do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Posted on Nov 12, 2009
co7196
  • 3433 Answers
SOURCE: Cannot tighten blad for 18" Electric B&D Mulching Mower
You may be missing a couple of washers, 2 flat and one lock waasherAre all the pieces there. Sometimes it calls for a spCER
Posted on May 26, 2010
al_kupchella
  • 843 Answers
SOURCE: How do I remove the blade from my Toro GTS 6.0hp
Yes, the bolt turns in the normal direction, and is usually pretty darn tight. Two little tricks that might help you--- use a block of wood (like a short piece of 2x4) to restrict the motion of the blade. Put the block between the end of the blade and the housing where the housing has a bump out or in. The other trick is to put the wrench handle and the blade very near each other. If the blade points to 12 and 6 o'clock, put the wrench handle at 7 (or even closer). Put a heavy rag on the blade and squeeze the 7 and 6 together. I hope this is helpful. Good luck. Al K
Posted on Jun 17, 2010
philwalker78
  • 608 Answers
SOURCE: I have a used Cub
Have you tried running it with the blade back on? It may be ok as there is a braking system built into the pto clutch that makes the blades hard to turn by hand. Regards Phil
Posted on Apr 16, 2011
SOURCE: Hi, I have a Craftsman C935
There are two philips screws on top. I got them with a screw extractor as they were rusted. You won't be able to fasten the blade from the motor side though.
Posted on Jun 26, 2011
Testimonial: "thank you"
How do you change cutting blade on a Sears Craftsman Mower?
Hi Bill:
Changing blades is pretty straightforward but does involve some Safety Hazards.
- Blades can have sharp bits - WEAR GLOVES
- Running engines can make the blade BITE - BAD
ALWAYS disconnect spark plug lead whaen changing blade.
Easy Part:
- Raise deck to maximum height
- If possible, park with front wheels on a ramp to get better access under deck.
- Use socket wrench to remove bolt from centre of blade. Here's where the gloves help as you hold the end of the blade to prevent it from turning when you apply force to remove the bolt.
TA DA! The blade will come off.
- To install new or sharpened blade (I use an angle grinder to sharpen mine) tuck it in place, install the bolt, snug it up, make sure any notches or splines line up, protect your hands (gloves) while you tighten the bolt. and you're back to cutting grass.
Cheerfuls.
Oct 19, 2015 | Craftsman Garden
I am replacing the blades. Which way does the bolt thats holding them in place unscrew?
All blade retaining bolts are typically standard thread, that is, turn them clockwise to tighten them, and COUNTER-CLOCKWISE TO UNSCREW them. Safety Tips! There are sharp bits under the deck so wear gloves. NEVER mess with the mower while the motor is running. Seriously, there are some people (usually with missing fingers) that have tried this. Also, when you put the new or sharpened blades back on, the sharp edge goes closest to the ground. Stay safe.
Mar 03, 2015 | Husqvarna Garden
How do I change blades on a toro 42 in zero turn
Lift front of machine and secure,
Use a pipe wrench over top of blade and against deck, to keep blade from turning,
Use 1/2 " breaker bar to loosen bottom bolt,
Remove blade,
If the bottom bolt doesn't loosen, you may need a wrench at top of deck, above the bottom bolt, to loosen the bottom bolt.
Replace, or sharpen blades, install in reverse order.
GOOD LUCK FRIEND.
Sep 16, 2014 | Toro 42 In 22 Hp Kawasaki Vtwin...
Flymo tines
What are you referring to as tines, it sounds like you are working on a roto-tiller. I will need more info as well. Model# Unit type-ie. lawnmower. Are talking about the blades? If so the there is a large nut that bolts the blade to the lawnmower. Remove bolt by holding blade with gloved hand and long breaker bar. You can strike the breaker bar with a three pound hand sledge to break it loose. Replace or sharpen blade as necessary. Apply grease or never-seize ti threads on crankshaft, spin on the bolt and tighten with long breaker bar. Good luck!!!!! If this is a tiller, then let us know, ok?
Mar 26, 2014 | Garden
How do I adjust the blade height yo cut at it's best performance. I am having problems with the cutting and it feels like it's ripping the grass instead of cutting it. It is fairly new so the blades are...
The blades on you rotary lawn mower could well be dull. I does not take to long for them to become dull. Figure about 8 hours of cutting. They are quite easy to sharpen. The blades can sometimes be sharpened on the machine, but it is much easier to remove the blade. 1 pull the wire going to the spark plug off the spark plug (this is so it won't start with your hands in the way. then tip it to one side. but make sure you do not spill gas everywhere. Then remove the blade there is generally a bolt in the center holding it on - -this bolt of quite often reverse threaded- - your manual will have any specific information on removing the blade. then using a file, bench grinder, or a purpose built sharpener sharpen the blade. It generally is only beveled on one side. don't take off very much material from the blade and make sure it balances before you put it back. Make sure it is on correctly, and that the bolt is properly tightened. No way do you want that geting loose
Dec 09, 2010 | Garden
The brand new blade rolls off the pulleys, thus not cutting. help!
You need to pull the bar out to tighten up the chain. The chain will stretch a lot the first day, And it will come right off. Check out the adj screw on there and loosen up the lock bolt/s, tighten up the bar, tighten up the lock bolts, Make sure the chain moves, not so tight it gets hot and freezes up. You should be all set. If the chain is stretched beyond the adj, you will need a new chain or get a link taken out of the old one, the hardware store, saw shop can do this for you.
Nov 28, 2010 | Garden
How do you put a chain saw chain back on and how do you determine the proper tension?
You obviously have taken the chain and bar off the saw. Start by meticulaously cleaning the oil port/s. At the front of the bar on the engine side, you should find a screw that moves the blade back and forth. Turn this screw counter-clockwise to allow placing chain loop on the bar and drive gear. Make sure that the sharp portion of the tooth of the chain is facing toward the engine of the saw, then the cogs will fit correctly. At the back end of the screw that you turned, is a nib that fits into the blade of the saw. Once you start assembling it,you can tighten the screw. Tighten the two bolts holding the blade and chain just enough so that you can still adjust the screw. Now, tighten that screw to a point where the chain can still be moved freely, but does not have a droop on the under side of the blade. Tighten,run the saw a bit, readjust if necassary and you are ready to go.
Oct 16, 2010 | Garden
Need to sharpen my blades.not sure exactly how to
there should be a bolt in the meddle of each
blade 9/16 or 5/8 headed bolt remove the bolt sharpen
blade w/grinder and replace same as removal
Jun 20, 2009 | Garden
Reassembly of trimmer blades to motor body
Put the ware plate on the support bar.
On top of that install one blade facing up.
Then install the other blade facing down.
Put the bolts up through the support bar
Install the little rubbing blocks on bolts in slots in blades.
Place top stiff plate on top and install nuts.
Replace grease in gear box with stihl hedge trimmer grease onyy
Mar 19, 2009 | Garden
How can i change the blades
If it looks like a bolt holding the blade on then you'll have to put a wrench on the nut on top of the pulley top side of deck and use an impact or breaker bar on the bolt were the blade is. When putting the blades back on when the bolt bottoms out just tighten up on the nut a little more (with impact) or as much as you can (with breaker bar) also wedge a block of wood in the blade (blade turning counter clockwise to remove- clockwise to tighten) just in case the blade tries to turn on you. To sharpen put the blade in a vise and use a hand grinder and basically follow how it looks keeping the same pitch that is there and the cutting edge to look kinda like the edge of a knife but don't sharpen the back side of the blade just try to clean up any burrs on the back edge by useing a wire wheel on a bench grinder.Also while sharpening don't push to hard or stay in one spot so that you don't leave bluing on the blade (it cuases week spotson the cutting edge)
Dec 21, 2008 | Husqvarna 19.5hp 46" Yard Tractor
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
