Question about Janome Memory Craft 9000 Computerized Sewing Machine
Blown fuse in a janome 11000 sewing machine - Janome Memory Craft 9000 Computerized Sewing Machine
  • Dave Ramsey Jan 14, 2013
    More details: the machine has some issues in the software that come to light when it constantly cites "rethread" as the solution to stoppage. The blown-fuse issue manifested itself when the monitor window would not respond, although the machine would still sew. The local sewing center said it was a blown fuse. The question is not only how to replace the fuse but what it caused it. That is the big question.
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 8 Answers
SOURCE: LED display on Janome Sewing Machine reads SP
SP means Spool Pin. It is currently in position to wind a bobbin. Move the bobbin winder pin to the left and SP should disappear.
Posted on May 20, 2008
mallow1
  • 35 Answers
SOURCE: lost manual to Hello Kitty sewing machine made by Janome
I've always been able to get a free PDF downloadable manual from Janome. They are happy to send you a manual for your specific machine via email, and they've always been very helpful to me. Here's a link tothem:
http://www.janome.com/index.cfm/ContactUs/Machine_Support
Hope this helps!
Posted on Aug 16, 2008
lavon82931
  • 17 Answers
SOURCE: owners manual for sewing machine Janome JF1004
Try this web site for sewing machine manuals http://sewing.about.com/od/beginner1/ig/Sewing-Tools/Sewing-Machine-Manuals.htm
Posted on Jan 25, 2009
  • 19 Answers
SOURCE: manual for Janome Harmony 2049 sewing machine
www.janomestuff.com answer it all
Posted on Sep 16, 2009
Where can I buy a Janome 11000 programme for my machine
Search for:
Make Model manual
If you're lucky, you may find one for free.
Mar 20, 2018 | Janome Sewing Machines
Janome 11000 skipped stitches if any are even made at all
Skipped stitches sometimes occur if the machine is incorrectly threaded. Remove the thread and re-thread from the beginning (first RAISE the presser foot so the thread will seat in the tension disk).
Confirm that the thread follows the correct pathway (consult manual).
Try installing a brand-new needle.
Make sure the needle, thread, and fabric are compatible.
All About Needles
If it continues to not pull up the bobbin thread, the needle/hook could be out of time. May require service.
Sewing machine won pick up bobbin thread hook timing fix
Mar 05, 2016 | Janome 11000 Memory Craft Special Edition...
I have no power going to my Janome memory craft 11000 it's as if a fuse has blown
The Janome Memory Craft 11000 does indeed have fuses on the main circuit board. Often, if one of the motors becomes overloaded, as is occasionally the case if thread gets bound up in the hook/bobbin area, it will blow one of the fuses, to prevent serious damage to the motors or mechanical parts.
They are not easily removed at home, and doing so would not be advised as you would be dealing with delicate electronics on a very expensive machine. I would recommend taking your machine to a Janome dealer to have it fixed. There are a few other possible problems, thought the fuse is most common, and it would be better to have it diagnosed by a technician.
Mar 11, 2015 | Janome Memory Craft 10000
My Janome 11000 freezes up
you said it has been in the shop twice do you think that may be they did not check the circuit board out I think it might be in the timing or the board
Feb 07, 2015 | Janome 11000 Memory Craft Special Edition...
My bobbin thread is part of my embroidery on my memory craft 11000
you may have the fabric not tight enough in the hoop or try using the same colour thread in the bobbin
Nov 02, 2014 | Janome 11000 Memory Craft Special Edition...
Janome customizer 11000
Have you tried customer service for the software of your machine?
sometime it depends on the window your using you might have to keep using your old laptop. I had to revert back to an older model computer in order to continue with my machine but it was a different sewing machine. Check with the cs of you software im sure its cost you a lot. Hope that helps
Aug 24, 2014 | Janome Memory Craft 9500 Computerized...
Blue screen on janome 11000
screen is digital? may need new battery for screen power
Feb 25, 2014 | Janome America Inc 11000 Memory Craft...
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Jan 20, 2013 | Janome Memory Craft 9000 Computerized...
Attempting to find Janome customizer 10000 plus software
Simply contact your nearest Janome dealer, or the Head office in your country and they will be pleased to assist and outline the options available.
May 29, 2008 | Janome Memory Craft 10000
Janome Memory Craft 9000 Computerized Sewing Machine Logo
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
