Nobo wall heater won't come on
Hi have a nobo N4EU wall panel heater. the fuse is okay, and the timer is okay, but the red light won't come on, even when i turn the thermostat dial up to full. it used to be just the one in the bedroom which intermittently refused to work; now the one in the living room does the same. completely resetting the timer using the reset button doesn't help. can you help?
3 Suggested Answers
SOURCE: nobo heater
the nobo heater cant keep opening for long time, i just turn it on then secound its turn off by self, i dont know if there have time contorl or not? the one im sure its not broken , just dont know how to fix this out,please help.thanks!
Posted on Oct 20, 2010
SOURCE: i have some nobo e4eu electric panel heaters with
The instrusctions are available in english on the australian site: http://www.nobo.com.au/Brochures/Shared/NOBO%20Timer%20Operational%20Instructions.pdf
Other useful documents available here too.
Posted on Jan 09, 2011
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get instructions on how to replace and swap over for a new one?
There are not even photographs of the product online...
That tells me that nobo might be using generic timers made by various manufacturers.
And they might not use the same timer one year to the next... preferring to sell whatever they can buy with lowest price.
A lot of companies re-brand generic products and sell them under their brand name, and folks assume the company made the product.. and the company has manuals... but they don't manufacture anything... they just sell stuff.
First Alert, Timex, Kingshield, Stanley, ... are examples... I suggest not buying products from companies that do not post manuals
maybe you can find a manual by doing a google image search for timers, heater timers, or Nobo ... and seeing if you can find similar timer.
Nobo timer manual below is also sold under Sunlight and Timex brands.
http://www.e-tradecounter.co.uk/PDF/p-1125.pdf
Gene
Oct 08, 2014 | Hardware & Accessories
Nobo Heater - Power not constant
You do know that these kinds of heaters "cycle".?? They turn on and off, as a control regulator (thermostat) tells them to. You should have an adjustment that will control how frequently it cycles on and off... You should also have some kind of switch that shuts the heater down if it gets tipped over. However, I tend to assume you know most of this.. If it was simply "cycling", though, I'd think that there would still be some light on full-time to show it really was plugged in and working... So, if I had to bet my money, I'd bet that there's some built in safety switch inside that heats up and kicks the whole thing off quite soon after you start it going. I'd guess that by unplugging it, it eventually resets itself so that you can try it all over again. It could be one of those cases where it might be easier and cheaper to junk it and buy a new one.
Nov 14, 2013 | Heating & Cooling
Wall light switch timer inline with Extension cord GE 15313
Black to black (hot), Green to green (ground) and the only one left is of course white to blue. The (neutral) white wire can be many different flavors (blue, red, orange, brown, etc.).
If the outlet your plugging into (or controlled by the service panel breaker) is 15 Amps use a minimum of 14 gage wire (or 12 gage is even better), if its a 20 Amp outlet use 12 gage wires (or 10 gage). Don't use a 16 or 18 gage wire because it may get hot and start a fire because its undersize for the Amps.
Nov 13, 2012 | Hardware & Accessories
I returned from vacation last night and noticed all four of my coach lights were off. I thought...the timer needs to be reprogrammed due to a power outage while I was away. The red indicator light was...
1) You performed correct troubleshoot steps down the line.
Last thing would be to install defect timer on another light circuit in house, and see if problem is the timer or wire going to coach lights.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
2) EJ351C has 1 year limited warranty.
Buy new EJ351c and install single pole light switch until timer replacement is available.
Timer has easy 2-wire installation. Turn off power. Connect new timer just like old one was connected. Either timer black wire connects to either wire in switch box.
http://www.smarthome.com/25077/Intermatic-EJ351C-24-Hour-Mechanical-In-Wall-Timer/p.aspx
http://www.amazon.com/Intermatic-EJ351C-Programmable-Mechanical-Security/dp/B000Q9YUGU
Aug 08, 2011 | Intermatic Hardware & Accessories
Words on fuse box diagram faded. whats the appropriate fuses?
Please review this article: Where's The Fuse?
1. 5 Amp (Tan) - Instrument panel lights and lights-on reminder
2. 20 Amp (Yellow) - Choke heater
3. 30 Amp - Circuit Breaker. Power windows and sunroof
4. 10 Amp (Red) - Electronic control module
5. 25 Amp (White) - Heater and air conditioning
6. 20 Amp (Yellow - Stop and hazard lights
7. 25 Amp (white) - Windshield wipers
8. 10 Amp (Red) - Radio and cruise control
9. 30 Amp - Circuit Breaker. - Power door locks, seats and rear window defogger
10. 20 Amp (Yellow) - Courtesy lights, key warning chime, power antenna, horns, cigar lighter and clock
11. 20 Amp (Yellow) - Turn signals and back-up lamps
12. 20 Amp (Yellow) - Parking, side marker, license plate and tail lamps
13. 10 Amp (Red) - Warning lamps and buzzers, trunk release, torque converter clutch and vehicle
speed sensor
14. Not Used
Jun 08, 2011 | 1983 Chevrolet Monte Carlo
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get programming instructions or just how to get them to work? I have tried google but nothing yet ...
Oct 16, 2010 | Heating & Cooling
Williams debonair wall heater + pilot light problems
THE flame from the pilot should shoot past the thermo-couple and heat this up and make a small amount of mili- amps to prove the pilot light is lit. ..So if the flame doesn,t go past the thermo-couple it won, make mili-amps or its tme to change out the thermo-couple, They only cost lest than $8:00 and you can change it!
Dec 22, 2009 | Williams 3003622 Ceramic Wall Mounted...
Nobo heater
Feb 20, 2008 | Heating & Cooling
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
