Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
Where can I buy replacement parts for a sanipro
The waste outlet is leaking and I've had it and its connecting components out, wiped down and replaced but still leaking. Have also checked for blockage in the waste pipe and it runs clear so theres no additional pressure from that side so I'm thinking maybe the seals have gone around the outlet itself. Strange as Its only been in place a year but its all I can think of. Any advice is gratefully received.
  • 979 Answers
Hat is what I am thinking also. Check it to see.
Posted on Jan 30, 2013
  • 171 Answers
SOURCE: toilet pan installation procedure
Hi muller2012,
I'm Harvey the Master Plumber.
Your question is: the procedure to join pan to waste pipe without leaking. do i silicone around rubber seal?
In 30 years this is the first time I've heard of a toilet "pan". If you're refering to the bowl, it connects with a wax ring and a pair of bolts. You then caulk around where the bowl meets the floor to keep cleaning liquids from getting under and getting stinky. If this is not a standard toilet it would be a good idea to post pictures and give make and model.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
  • 3239 Answers
SOURCE: Replacing the seal.
Hi you could try soaking it in warm water to make it soft then it might stay on
Posted on Jan 25, 2010
heatman101
  • 43501 Answers
SOURCE: pump murmers now excessivley noisy
The best thing would be to just replace the whole pump... once they start giving trouble you will always have trouble...
the noise is either something bent or the motor has a bad spot in the windings...
heatman101
Posted on May 04, 2010
  • 33 Answers
SOURCE: macerator discharging water out of outlet pipe
sounds like a switch problem again. try descaling the unit. otherwise its time for a new pressure switch.
Posted on May 10, 2010
  • 115 Answers
SOURCE: Sanipro continuously runs,however, not pumping
There can be a blockage somewhere in the discharge pipe, the blade or impeller. Also the short discharge pipe or long elbow inside the pump casing may be split open or not attached properly and waste water is just cycling inside the pump casing. Worst case scenario could be a bad capacitor, the capacitor spins the blade and impeller, it that goes bad the unit will just hum and not pump any waste out until is replaced. You can also order parts through Saniflo if needed.
Posted on Jan 11, 2011
1998 all wheel drive mercury mountaineer rear brakes
I had something similar on my old 92 dakota
In my case it was the rear only abs hcu unit
Your rubber hose goes to either the brake tube from
the front of the truck ( rear feed) or to as you said some
other brake component.
You should be able to determine where the leak is &
if you have to replace a component unknown to us,because of rust & leaking- the dealer will be the source
The auto parts stores stopped having intellegent life about
25 years ago,they can't keep up with technology & your dealing
with young non car guys.
At the dealers parts counter they will show you on their computer
a picture of your frame & unknown part- if you even need it
Most likely you will be fabricating a rusted brake tube,hang in there
Jan 26, 2013 | 1998 Mercury Mountaineer
2003 Pontiac Vibe - 4 Cyl. 150k miles. Ignition coils keep going bad - every 4-6k miles. Coil 1 has been replaced 4 times, Coil 3 once. Coil 4 twice in the past year (20k miles). All spark plugs
Install new spark plugs, 4 new coils & replace the oxygen sensors
O2 Sensors are only good for 100,000 miles, then slow
down or quite
No idea why the coils do not last 5 or 6 years
Cylinder #1 is always at the front on a 4 cyl
Go to Rock Auto --Buy Wells Coils,NGK Double
Platinum Plugs & NTK O2 Sensor
Those parts are expensive because you have a Totota
Motor I guess
Clean MAF Sensor with CRC MAF Sensor Cleaner
Jan 08, 2013 | 2003 Pontiac Vibe
Motherboard model troubleshooting
troubleshoot motherboard
Back up everything possible on your hard drive.
If you're experiencing hardware issues, this is a luxury you might not have.
Keep backup files on an alternate data storage system to avoid data loss during hardware problems.
Notice the issue and reproduce it so you're aware of where the symptom manifests itself.
Isolate the problem.
If the system isn't getting power, make sure it's not the power cord or wall outlet before you try a different motherboard.
If everything is trying to run but not actually able to, check for loose parts on the motherboard before you replace it.
Remove all of the hardware that isn't actually necessary to make the computer function before you can narrow down the causes for your problem to the motherboard.
Ensure that all cards and memory units installed on your motherboard are securely in place and that each is making a good connection.
This can be accomplished by removing each component, blowing out the socket with compressed air and replacing the components.
Try another compatible motherboard in your machine once you've eliminated all other potential problems.
If it works with the alternate motherboard, replace the old one.
hope this helps
Oct 11, 2012 | Intel Computers & Internet
I turn on my 6505+ and after about 20 min or sometimes less it will start whistling. I've changed preamplifier tubes but no difference. This same problem happens every time I turn it on. The problem...
As you've already worked out Its more than likely a component breaking down. I'd take a good look at the circuit boards, look for a capacitor that's leaking, overheating or just the top is bulging out.
Oct 23, 2011 | Peavey 6505 Plus 120W Guitar Amp Head
HPT4254X/XAA clicking noises? Cuts itself off and continues to make clicking noises as if it is trying to turn itself on. I've had cheap tv's for 20 years and no problem. I'm not...
The tv power supply board it is the 90-95% the problems and the causes.That the board where the tv power a/c cord plug into it.Those capacitors components parts the tvs corporation put on tvs are under voltages for low heat resistance most of the times and dies very quickly, to dies as times used a lot of tv on like 3 or 4 hours a day within a year or litte bit more.U have all the tools and understanding basic electronic also can do basic soldering work too?Yes?Take the the tv aparts and check the tv power supply board carefully for dying and leakages capacitors components parts.These dying and leaking capacitors parts are alway bulges up or puffing up on to it tops.All these dying and leaking capacitors parts that are bulges up or puffing up on to it tops.All these dying and leakages capacitors components parts must have be replaced like the same Micro Fared and those voltages on the new capacitor parts u are replacing should be in higher voltgaes like 5 or 10 voltages higher than those old capacitors parts u are replacing.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.
Aug 25, 2011 | Samsung HP-R4262 42 in. Plasma Television
My screen intermittently goes blank (without lighting). I can see that there is something displayed and a connection to an external monitor shows that everything is working fine. I've disassembled the...
I've seen this problem time and time again. Replacing the inverter fixed it every time. HOWEVER it could always be the CCFL backlight as well. Both fortunately are VERY inexpensive. Changing the inverter is easy but the CCFL will be a little harder. Take your time and remember how to put it all back together and you'll save that $100. I'm sure it's either of those two that's causing the backlight issues. NO NEED to change the entire LCD.
Aug 22, 2011 | Acer TRAVELMATE 8371-944G25 LAPTOP LCD...
When I print a page black lines appear on the page making. Its like the toner is leaking or something. I don't know how to fix this issue. I've cleaned the inside of the printer several times and...
The toner is leaking. The toner cartridge has two compartments, one for new toner & another for waste toner. When the waste toner compartment is becoming full to its capacity it starts throwing extra toner outside of it. That is what is called toner leaking. If you can empty the contents of the waste toner compartment, your problem will be solved. One more thing if wiping blade for waste toner is worn out, it also leads to toner leaking.
Aug 02, 2011 | Samsung ML 2151N Laser Printer
I donnt think you can solve it the amps must be blown up and i dont think you would know
Most Amps that blow are down to failed Capacitors and ocassionally down to the Transformer or other components.
If you can have a look at the internal PCB and see if there are any Capacitors with bulges on the top or fluid leaking out of them then they've failed.
They're very cheap to replace but you'll need a soldering iron and the ability to desolder the old and resolder the new.
Jul 15, 2011 | Orange Amps Orange Sundown Rover 15 Watt...
Sanipro continuously runs,however, not pumping waste away and waste water has filled toilet bowl. Any suggestions
Dec 23, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
544 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
