Question about Iomega 100MB IOMega ZIP Drive Internal IDE Beige OEM Z100ATAPI Drive
Z100ATAPI with USB adapter - Iomega 100MB IOMega ZIP Drive Internal IDE Beige OEM Z100ATAPI Drive
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
Where can I find a driver for Windows 98 USB wireless adapter
Windows 98 needs an USB driver for your adapter. A USB driver should have come with your adapter, if not got to the adapter manufacturer's WEB site and download a Windows 98 USB driver that is specific to your adapter.
Jun 18, 2012 | IBM ThinkPad 240X Notebook
I am trying to connect a Iomega Z100ATAPI Zip drive to my Windows 7 laptop.
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Mar 23, 2012 | Iomega 100MB IOMega ZIP Drive Internal IDE...
My Z100atapi Zip drive is recognized by Windows 7, but the old disks are not in a recognized file format. I need to get the old data ..
Greetings - According to Iomega your 100 MB ZIP drive media should be fine at being at least readable (the Iomega software does not work with Win 7) natively by Win 7 and Vista. Since the drive is recognized I suspect the problem is actually the discs themselves.
It turns out that the discs were not very good at long term storage and are notorious enough to have a term referring to the problem as the "Zip Burp" where:
  • A) All files on the disk disappear
  • B) Just Compressed Formats such as JPG, ZIP, CAB, ECT Disapear
  • C) "The Disk Needs To Be Reformatted" message is displayed or
  • D) files disappear as you click them
The only way that I know to find out for sure if your discs are good is if you can find someone with an XP machine that will let you temporarily install your Zip drive (including the latest drivers) and see what happens.
Good Luck,
Mikeywaf
May 27, 2011 | Iomega 100MB IOMega ZIP Drive Internal IDE...
My netgear wireless-n150 USB adapter wna1100 can't detect adapter.
First determine that the USB port isn't dead. Do other things work in that USB port? If the answer is yes we know it's not the port. Have you tried another USP port? If it doesn't work in another port (or on another computer's USB port) then it's the adapter itself.
Adapters can go bad. USB ports usually work and don't go out. The exception is that many laptops that come with several USB ports sometimes have one (or more) that never did work.
Try it on another computer. This is one last step to determine if the adapter itself is dead and that it isn't something on/with your computer.
It also could be that the computer has the old USB 1 port and the adapter needs USB 2. (USB 1 was slower).
Apr 08, 2011 | Computers & Internet
I just reformatted my computer and am trying to install Netgear WNA1100 WirelessN 150 USB Adapter, however it gets stuck at detecting adapter. I'm running Windows XP Professional and I do not have any...
As you said that you have reformatted the computer , try to reinstall your USB bus controller drivers because it seems that your USB bus controller is not detecting your USB adapter when connected.
Try this link to download USB 2.0 driver
http://www.softwarepatch.com/tips/usb2-driver.html
Feb 21, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
How to conect belkin wireless g usb net adapter to xbox 360
You can not use the Belkin Wireless G USB Adapter for the XBox 360. You must buy a USB Wifi adapter that supports the Xbox 360. (See Microsoft's USB WiFi Network Adapter)
Nov 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
Iomega zip drive Z100ATAPI returns error message: "Insert Disk into drive H:" even though there is a disk in it. It is recognized by the system and Device Manager in Windwos XP says the drive is...
Just because the device manager says the drive is working fine doesn't mean it is. If it won't recognize the ZIP disk, either the disk itself is bad or the zip drive is bad. I would try another zip disk and see if it will read a known good zip disk.
Nov 07, 2008 | Computers & Internet
Iomega 100MB IOMega ZIP Drive Internal IDE Beige OEM Z100ATAPI Drive Logo
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
