Question about GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS
Ge profile PFSS6PKXCSS
ICE CHUTE
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
aasc
  • 1606 Answers
SOURCE: I have a GE profile Artica side by side. I am
The ice door flap is not closing completely, or, your using a lot of crushed ice .
Posted on Jul 19, 2009
aasc
  • 1606 Answers
SOURCE: GE profile Artica side by side. I am getting a frost build up
Sounds like the dispensor flap is not closing completely , pulling outside air in . Using a flashlight on the outside of the flap , look inside to see if any light is visible . If so , then the ice flap plunger and solenoid will have to be replaced . Also , excessive crushed ice can also cause frosting .
Sea Breeze
  • 4654 Answers
SOURCE: ge profile artica ice dispenser and chute frosing.
This may be because the chute door is not all the way shut when off. If yes the warm moist air is being pulled through the opening and causing this. Sea Breeze
Posted on Oct 21, 2009
Testimonial: "new here--did not mean to rate you low..sorry!"
  • 6 Answers
SOURCE: GE Profile PFSS6PKXCSS leaks under crisper
i have a ge thats doing the same thing ine has a live running on back dont know if i unhook on back or tahe off control box hey go 2 http://www.partselect.com/ they have diagras and a help solution page let e know when u find solution
Posted on Dec 29, 2012
Ice maker freezing up at water chute.
It's probably the water fill valve seeping which requires replacing that valve on the back of the refrigerator.
Jul 21, 2013 | GE Profile PSW26P Stainless Steel Side by...
Ice chute cloggs with solid chunk of ice over time
Have you had high humidity over the last few months where you live?
This could be normal under those conditions.
BUT.....make sure the door is closing FULLY at the ice dispenser outlet.
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Jul 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile 26.6 cu. ft. side by side is frosting in the shoot
Oddly enough, the problem is with your ice dispenser. What happens is that the door at the bottom of the ice chute is probably not sealed. This is likely because there is a solenoid that is supposed to hold that door open when you push your cup against the dispenser arm, and THEN, close it again when you release. If the chute door is not sealed, warmer, moist air from outside the refridgerator will be canstantly drawn up the chute where the moisture will freeze as frost. Gradually, this frost builds up in the chute until there is no longer enough room foir the ice to fall. You can usually look up at the chute from outside and see that the door is not sealed. In my case, I left it unsealed because the door would not open to let the ice out. It took me about 3 months to figure out that this was causing my frost-clogging problem. The solution is to replace the solenoid that is supposed to open and close the chuite door. If you remove the despenser panel, you will see that this solenoid is probably all rusted up and not working. The following link will allow you to enter you model number and see a diagram of the offending area. http://www.pcappliancerepair.com/model-display.php
Jun 10, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
I have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the...
Hello azcowgirl19
Welcome to fixya,
You said, You have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the same room. Is there anyway that this clattering can be cushioned?
Also, the ice seems to clump up into a large ball and when it tries to go threw the coils, it shakes and rattles the entire appliance. Other than removing the lg clump of ice is there anyway to prevent this?
Yes I do recognize the problem.
The ice maker has a couple of defective parts in it!
Lucky for you you still have a warranty for this GE Profile fridge and did not waste anytime looking into it!
In the USA, Call GE at 1(800) GE CARES , and tell them the ice maker has multiple problems so they can service it while you still have your full parts and labor warranty!
Let me know how it goes!
Please remember to leave a rating at our site before you leave!
Thank You, Huuum
Sep 30, 2008 | GE Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Oct 02, 2007 | GE 17.2 cu. ft. Top Freezer Refrigerator...
Ice Falls Into Freezer Compartment
Yes i Believe there is Post the entire model # and I can find a part # or even ship it to you. Was the refrig an open box item??
Sep 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Stainless Bottom-Freezer Refrigerator with Internal Dispenser 22.2 Cu. Ft. - PFS22SIS Logo
32 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
