My Tcl washing machine model is TWM-55AS/C, the probelem is the spinner came out and we re fixed it also now its not working properly and iam not getting clean washed clothes , i dont know what 2 do..
I want to know how to fix it and i need it soon plz
  • 188 Answers
SOURCE: cleaning washing machine filter
There is no filter on this machine. The gray gooey substance is sludge (dirt) build up inside the tub. This can be caused from using too much detergent or a detergent that is not HE (high efficiency).
You can try running an empty cycle using the hottest water available with products such as "washer fresh", "affresh" or a cup of bleach to remove the build up.
Remember to use a HE detergent and you only need about 2 tablespoons per regular load.
Posted on Mar 01, 2009
SOURCE: old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Posted on May 07, 2009
  • 653 Answers
SOURCE: My washing machine does not clean properly.
Let's start with the detergent and the water temperature. If they are the same as what you use at home,
then I have to assume the machine may be overloaded. Back off on the load by about 1/3 and see what happens. In the worst case scenario, you could let the jeans soak in the detergent/water mix over-night
Posted on Jun 17, 2009
venexcsd
  • 1185 Answers
SOURCE: White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
Posted on Jun 18, 2009
SOURCE: Ariston "Margarita 2000" Model AL129X [front load washing machine] - Clean sludge from door seal.
Ariston "Margarita 2000 cpu map photo
Posted on Nov 20, 2009
CANT FIX SPRING OF SPINNER
as there is no make /model listed what do what us to do. if you can not fix then it will be a replace the unit .
Oct 25, 2015 | Washing Machines
Tcl reset twm-55as/c washing machine?
Try up pluging the washer for 30 mins or so and see if it resets. Also check the owners book to see if there is any information on resetting the washer
Apr 30, 2014 | Washing Machines
Spinner is not working E3 error appear
You may have to check your motor brushes; if worn out your spin will not function properly. Go to youtube with your model, make,etc; it is a very easy fix. Hope your filter is clean and your wall drain is not blocked.
Pl click if helped.
Apr 25, 2013 | Washing Machines
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
New drive motor (if necessary).
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
5
6
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
I was trying to clean the washer and i took out the Augger and can't figure how to put it back together.
by auger do you mean the agitator here is a schematic of your machine of how the agiator installs into the machine if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future with similar situations
here is your schematic http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fM0606007-00007.png
Thanks Rick
Feb 03, 2011 | Maytag PAV2300 Top Load Washer
My washer had stopped spinning about two weeks ago, we replaced thecoupler and it worked fine but today it stopped spinning again
5
6
Feb 03, 2011 | Washing Machines
WASHER SPINNER DOES NOT WORKING PROPERLY
normal operation of a two piece washer agitator is the bottom section goes back and forth and the top section goes in one direction like a ratchet.(slips one way and locks the other way)
Jun 13, 2009 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
