Question about Linksys Wireless-G Broadband Router
I need to creat ip from my router for my friend that will have starting time and ending time.
    Scholar:
  • 60 Answers
Navigate in your browser to the control panel of your router ( typically http://192.168.1.1 ). Leave user blank and enter your password. Then navigate to tab Access Restrictions, create a policy with the times you want, click the Edit List of PCs button to assign policy to your friends computer, then click Save Settings button.
Posted on Jan 22, 2009
Blocked facebook site
Create an IPSEC tunnel between you and your friends computer. Your friends computer should act as the gateway. Allow your packet information will be encapsulated within the tunnel and the router will not see the IP Header. This should work for you.
Nov 11, 2010 | Computers & Internet
Where are nat settings
Hi Friend,
As per your query regarding the NAt setings, please follow the steps:
1. Open the router page
2. Once the page is open, click "LAN IP Setup" which is in the left pane under "Advanced".
3. Check the box "Use Router as DHCP server" and define the Starting and Ending IP Address.
This way you will be able to configure the NAT settings of your router.
I hope this will resolve the issue.
Regards
Chiranjeet
May 20, 2010 | NetGear WGR614 Router
Game server and my IP address
First option is to forward ports where your friends can connect to. The second option is to put your computer in DMZ. These options can be found on the router settings.
Jun 17, 2009 | Apple AirPort Extreme Wireless-N Wireless...
How do you unblock your computer with a D-Link DIR-628 router? My brother blocks me and I'm trying to play some team fortress 2. My connection just dies cause he blocked the router at the worst times. Is...
You can do a port forwarding first, remember, to configure router you have to log in as an administrator.
Type in this in your browser's address bar.
http://192.168.0.1
Log in.
These are the ports
Steamclient1: 27000 - 27020
Steamclient2: 27020 - 27050
SteamServ: 27015
Do like this(at your own risk-port forwarding may be vulnerable)
This will allow you to open a single port or a range of ports.
Port Forwarding
Enter a name for the rule or select an application from the drop-down menu. Select an application and click << to populate the fields.
Enter the IP address of the computer on your local network that you want to allow the incoming service to. If your computer is receiving an IP address automatically from the router (DHCP), you computer will be listed in the “Computer Name” drop-down menu. Select your computer and click <<.
Enter the TCP and/or UDP port or ports that you want to open. You can enter a single port or a range of ports. Seperate ports with a common.
Example: 24,1009,3000-4000
Select Allow All (most common) or a created Inbound filter. You may create your own inbound filters in the Advanced > Inbound Filter page.
The schedule of time when the Virtual Server Rule will be enabled. The schedule may be set to Always, which will allow the particular service to always be enabled. You can create your own times in the Tools > Schedules section.
You can also add application rules
Name: Enter a name for the rule. You may select a pre-defined application from the drop-down menu and click <<.
This is the port used to trigger the application. It can be either a single port or a range of ports.
Select the protocol of the trigger port (TCP, UDP, or Both).
This is the port number on the Internet side that will be used to access the application. You may define a single port or a range of ports. You can use a comma to add multiple ports or port ranges.
Select the protocol of the firewall port (TCP, UDP, or Both).
The schedule of time when the Application Rule will be enabled. The schedule may be set to Always, which will allow the particular service to always be enabled. You can create your own times in the Tools > Schedules section.
Your brother may be filtering your mac address(network card address)
Check from Advanced->MAC address filtering
Turn it off.
You can set a policy also to prevent this.
Here's how
Go to Advanced-> Add policy of your router configuration page.
Do the following
Click the Add Policy button to start the Access Control Wizard.
Click Next to continue with the wizard.
Enter a name for the policy and then click Next to continue.
Select a schedule (I.E. Always) from the drop-down menu and then click Next to continue.
Enter the following information and then click Next to continue.
• Address Type - Select IP address, MAC address, or Other Machines.
• IP Address - Enter the IP address of the computer you want to apply the rule to.
(To find the MAC address
(click Start, then Run, then type cmd in the text box.)
Type in ipconfig/all in the Command Prompt Windows.
The 12-digit Physical Address is the same as MAC address
Select the filtering method and then click Next to continue.
Access Control Wizard (continued)
Enter the rule:
Enable - Check to enable the rule.
Name - Enter a name for your rule.
Dest IP Start - Enter the starting IP address.
Dest IP End - Enter the ending IP address.
Protocol - Select the protocol.
Dest Port Start - Enter the starting port number.
Dest Port End - Enter the ending port number.
To enable web logging, click Enable.
Click Save to save the access control rule.
Go to tools-> syslog to create a new user. you can create an admin account here.
You can download the manual of the router from here.
If this is helpful to you, please rate this :)
Thanks :) Wish You Luck
Jun 16, 2009 | D-Link DIR-625 (790069292637) Wireless...
Asus wl-500w and modem
your sub net mask is wrong you have to put 255.255.255.0 and make 192.168.1.1 to modem and 192.168.2.1 to router
Apr 11, 2009 | ASUS WL-500W Router (WL500W)
Friend cannot conect to me while im the host server.
 Each computer on the router is assigned an ip if DHCP is enabled in the router. This is known as your inhouse IP and you will need these to forward ports.
On each computer connected to the router open cmd (command prompt) and type
ipconfig /all
Make note of the ip assigned for each machine.
Open your router setup and enable DHCP if is isn't already. Save changes.
Locate Port Forwarding or Advanced Routing.
Create a rule for each machine. You can name them anything you like, such as machine1, machine2...
Select TCP for the protocol. You can select a port range in the ports boxes. In the IP box you will type the ip for each machine and select enable. Save Changes.
Reboot everything, machines, router and modem.
Also note some routers have a gaming tab which will make this easier to setup.
Good luck
Mar 30, 2009 | Belkin Computers & Internet
Router/Modem IP
Try 192.168.1.1 or 172.16.1.1
Mar 14, 2009 | Apple AirPort Extreme Base Station
Trying to configure zyxel nbg334w router
If the router will not connect to the internet, you will need to create the PPPOE internet connection with the username and password that your ISP provided. BPCS
Dec 28, 2007 | Zyxel Prestige 334 Router
How do I configure DHCP server on my wireless router?
Step 1 Open a web browser and type the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click on DHCP to the left. Note: If you are connecting to a DHCP server, the DHCP server on the wireless router should be set to Disabled. Step 4 By default, DHCP Server is set to Enabled. To disable it, click the Disabled radio button. To enable it, click the Enabled radio button. Step 5 Enter the Starting IP Address and Ending IP Address. To change the lease time, select a value from the drop-down list next to Lease Time. Note: The value for Starting IP Address must be less than the value for Ending IP Address. Step 6 Click on Apply then click Continue to save the settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
