Question about Nokia 3120 classic Black GSM UNLOCKED
Mah mbl z shwn d cam z stand on aftr clickin continue it z too shwn dis so wat 2 do??
What does the abbreviation mAh stands for
milliampere-hours.
1 Ah = 1000 mAh
It is a unit of electrical charge, often used when quoting battery capacity.
1,120 mAh implies that the supply give 1120 mA for 1 hour, or 560 mA for 2 hours, etc, It also implies that a 560mAh battery would have half the lifetime of an 1,120 mAh one over one discharge cycle.
These numbers are produced in a laboratory with instruments designed to measure that parameter and your batteries will often not perform as well as you might expect, because eg, when partially discharged, their voltage can drop slightly, and even when 'empty' they will in fact have some residual charge (unless they have been 'on' for a very long time)
11.August.2014
Aug 12, 2014 | Sony USB Portable Power Supply with One...
My nokia 5233 fell in water,its just black
put it in a bag of rice, Raw rice not cooked, for a few days. that will absorb all the moisture. Don't try to turn it on until you dry it. or you will short it out
Jul 22, 2017 | Nokia Cell Phones
I lost all my laptop's audio n video cd's..... n now aftr frmattin m facing problem regardin audio, video n graphics.... nw wat to do....?????
download a online driver finder & installer, it will find all needed drivers for your laptop and then download it through this software and install it.
Oct 14, 2012 | MSI Ultra Ms-6837d Ms-1637 15.4" Notebook...
Whenever i connect my cam to my lappy it gets shut down,it was never happened before wen i was using my cam,but now it shows some message like " some serious problem occured with ur hardware usb...
As your message suggested, you have a hardware fault which means your camera is possibly faulty.
I would book it into a repair shop and get it fixed.
Hope that helps.
Jan 23, 2011 | HP Compaq 6720s Laptop
Micromax mobile password
Gsm micromax x1i keypad not working
pls solution
Dec 27, 2009 | Cell Phones
Old version of java flash player
yes, dis happens 2 all psps. wat u need 2 do is get program called ultimate psp tube. this program allows u 2 wach all u tube vidz on ur psp without having 2 update ur java and stuff. http://www.youtube.com/subscription_center?add_user=xxanolifexx dis is da download link. i hope dis helped =)
Mar 18, 2009 | Sony PSP (Piano Black)
Using tata indicom usb modem in Ubuntu
linux connectn
1st log in the root user
connect the usb modem
run terminal in linux
type following command
wvdialconf /etc/wvdial.conf
wvdialconf will detect the modem
nano /etc/wvdial,conf
jus replace dis wid defaulf setting
modem-/dev/ttyusb0
baud=115200
dial command=atdt
baud=115200
dial command=atdt
init1=atz
init 2=at+crm=1
flow control=hardware
username=internet
password=internet
phone=#777
stupid mode=1
aftr dis open terminal type wvdial &press enter
if u want to disconnect den press clt +c
Dec 09, 2008 | Canonical Ltd. Ubuntu
Hiii
Version 8 of YM is still more reliable.
Mar 12, 2008 | Microsoft Windows Vista Ultimate Edition
Nokia 3120 classic Black GSM UNLOCKED Logo
20 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
