Question about Kensington Wireless Presentation Remote Control
Wireless Presenter with Laser Pointer not working
How to connect a dodocool clicker?
in a usb port of a computer
Adapter for the PC lights up and stows away in the battery compartment
2.4GHz Wireless Cordless Presenter with Red Laser Pointer--Remote Control Range: 15m: Amazon.co.uk: Computers & Accessories
Long Conncetion Distance 2.4GHz Wireless Presenter Laser Pointer Pen with USB Receiver Remote Page Controla528b105-a9fe-4729-a857-20fc64e6268d.jpg
Nov 10, 2016 | Video Game Consoles & Games
High Power Laser Pointer will damage my camera ?
The light from my laser pointer on a screen will not damage the camera a direct shine into the lens of the camera may well burn the electric of the eye out the camera may not be able to handle the intense light and it may bring out the circuits.
Nov 25, 2014 | Logitech 2.4 ghz cordless presenter
August LP102R presenter will not work
You obviously need a driver. Where did you get the presenter?
Apr 11, 2014 | August LP102R Wireless Presenter with Red...
Lost usb receiver
The wireless demonstration device and USB receiver has an exclusive code. You should replacement codes. If it doesn't work, you only rebuy it.
Aug 23, 2011 | Kensington Wireless Presenter with Laser...
How to set up and use HP RF 2.4G Presenter ? T.K. balaji
Press the receiver button until it flashing, then press the "right button mouse" on your transmitter for about 5 seconds. Both action should be done in 8 seconds time frame.
Oct 08, 2010 | SIIG 2.4G Rf Wireless Presenter with Laser...
Targuss Wireless presenter not recognized
The first thing that I would advise you to do is,
Make sure you are connecting it to your system through a USB 2.0 Port, and not 1.0 USB Port.
Next, uninstall the Wireless presenter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wireless presenter).
After this, ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you don't know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Nov 24, 2009 | Targus wireless presenter with laser...
I've lost my manual and I can't get the laser pointer part to work.
Press and hold Fn button and Laser button until the light turns red.
Aug 30, 2009 | Honeywell PP4IN1 PP4IN1 4-in-1 Wireless...
Won't advance slides
IF IT JUST DOESN'T WORK... (But the laser pointer is still working when in 'presentation' mode) You need to 'Sync' the presenter and the reciever... as follows: Turn the presenter on, and turn it over so you're looking at the back of it. See the button in the middle? Press that button, and the button on the USB reciever stick, simultaneously, while holding the two of them quite close together. Problem should be solved. If you turn it on and the display isn't working, or if the laser pointer doesn't work when in 'presentation' mode, you need to change the batteries. I thought I had a dud unit until I found out about the 'Sync' function!!! Definitely on the 'need to add to documentation' list!
Aug 21, 2007 | Microsoft Presenter 3000 Mouse
Wireless presenter dont work
Did you press the right button on the remote? To 'sync' the sender and reciever, and thus start it working, you've got to turn the handheld OVER and press the mysterious little button in the middle at the same time as the button on the USB stick. Also helps if you have them right next to each other when you do this. You should see a green light on the USB stick, and the laser pointer should work on the handpiece if the batteries are good. Mine was working fine for heaps of presentations then suddenly stopped one day and only the laser pointer would work. Batteries were fine, as is the common story. Then I found out that if you turn the presenter over and press the 'reset' button in the middle simultaneously with the USB reciever stick, the two 'sync' and it starts working again, hey presto. I've always found it a breeze to use once I figured this out. If that doesn't work take it back, you need a new one.
Jun 29, 2007 | Microsoft Presenter 3000 Mouse
Kensington Wireless Presentation Remote Control Logo
358 people viewed this question
Top Kensington Office Equipment & Supplies Experts
k24674
Are you a Kensington Office Equipment and Supply Expert? Answer questions, earn points and help others
