Question about Gateway 500XL PC Desktop
500XL will not shutdown properly!
I own a CZZ 500XL Gateway Desktop. There is currently no support for this model on Gateway's website. The problem is that ~95% of my attempts to shutdown my computer via the start menu, it will go through the entire process with seemingly no difficulty but then restart instead of shutting down. There is no "freezing" or "locking up" that occurs, it simply just almost always restarts rather then shuts down. What's odd is that there is an extremely rare occurrence of the Gateway to actually shut down but it happens so rarely that I haven't had a chance to figure out whats different. The only information I was able to find that "may" be somehow related to this problem is some gateway owners reported a hardware issue with the actual power button that would cause a similar issue. I also read that certain software like Roxio CD DVD creator may create this problem (although I have tried updating my drivers for this software with no luck). Any Ideas?
Re: 500XL will not shutdown properly!
The above Solution did not seem to change my problem with the shut down, however, after making the change to my BIOS several drivers that were not working properly including DirectX now function perfectly! For instance, several programs that use directX were not detecting that I use a wide-screen monitor and would not offer wide-screen resolutions. This has been fixed =)
Posted on Jul 24, 2007
  • 2,961 Answers
Firstly you need to get into the bios by pressing f2 or Del on start up and when in the bios look in the advanced menu for ACPI and meke sure that it is enabled, this allows the motherboard to recognise the auto shutdown through windows, then save settings and exit for a re boot. Next click start>control panel>power options and check in the power schemes and other tabs, to make sure that the settings are correct for shutting the system down.
Posted on Jul 06, 2007
0 characters
3 Points
Need memory for Gateway Desktop Model (GM) MFATXPNT MDW500X computer made in the fall of 2003. Where can I find memory for a model this old?
Go to Crucial.
It is very easy to use, just select the manufacturer and model number from the drop down list, and it'll tell you everything you need to know, AND offer you some pretty good deals on memory direct from them.
Aug 24, 2011 | Gateway 500XL PC Desktop
Need ethernet controller driver for gateway 500xl....
Here is the Gateway Drivers & Downloads Support link. Just click on the link, and when the page comes up choose the "look up my serial number for me" or type the serial # in the box. That will bring you to Your Models Current Updates for it's Drivers & Software.
Sep 21, 2010 | Gateway 500XL PC Desktop
My gateway 500xl won't power on
The first thing I would try is connecting a new power supply. If you can borrow one from a friend/neighbor/family member/whatever that would be the easiest/cheapest thing to try first. Also make sure all the wires are connected to the right places and securely connected.
Jun 04, 2010 | Gateway 500 XL PC Desktop
In all likelyness your motherboard at a minimum is dead. Take it to a technician to check and submit a claim through your house insurance
Jun 27, 2009 | Gateway 500XL PC Desktop
I am upgrading memory to my gateway 500xl desktop, how do I open the case?
Find your computer on the Gateway website and download a manual which will show you how to open the case.
Jan 29, 2009 | Gateway 500XL PC Desktop
Need to replace video card
It would be the card that your monitor plugs into. If the monitor plugs straight into the motherboard, then all you need to do is add a video card and it should automatically bypass the built in one on the motherboard. Thanks and please take a moment to rate this solution with a fixya rating. :c)
Jan 27, 2009 | Gateway 500XL PC Desktop
Gateway desktop 500xl stuck in power saver mode
click start, run and type in msconfig
the menu that appears allows you to start in NORMAL MODE
Jan 04, 2009 | Gateway 500XL PC Desktop
Gateway 500XL PC Desktop Logo
134 people viewed this question
Top Gateway PC Desktops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a Gateway PC Desktop Expert? Answer questions, earn points and help others
