Question about Sony Playstation 3 (PS3) Console
I cant setup my new playstadion 3.
I cant setup my playstadion 3. I turn it on, and plug in the wireless controller, but it cant find it, what do i do?
You need to use the usb that came with it to sync first then I will work find.
Posted on Jan 12, 2013
I cant add roku as a new device to my laptop and the microsoft will not let me updated
1. Enter your wireless router setup page using a computer that is hardwired to your router.
2. Go to your Wi-fi protected setup options and disable Wi-fi protected setup (WPS). Apply this change.
3. Go to your wireless security settings and select your desired WPA or WPA2 security mode and your desired password (psk). Apply this change.
4. Go to your Channel and SSID settings tab and RENAME YOUR SSID. Apply this change.
5. Now view your wireless networks on your upgraded Windows 7 machine.
6. Select the newly named network.
7. Select "connect" and enter your new passkey/password.
Let me know if this works for you.
tony
Feb 10, 2013 | HP Pavilion dv7-1240us Notebook
Cant find passphrase
If you cant find it then you will need to set a new one.
Plug the router in using Ethernet cable. In internet explorer type 192.168.0.1 Username: admin Password: *blank*
On the left click Wireless Setup > Manual Wireless Connection Setup. Changed Network Key
Apr 25, 2011 | D-Link Computers & Internet
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
Security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I cant connect to the internet
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Jun 10, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
My router cant connect to the internet through the modem and i cant acces my rfouter setting cause cant install it
2. Step 2
3. Step 3
4. Step 4
5. Step 5
or folow the link you will get all your solution
http://www.google.co.in/images?hl=en&rlz=1R2SKPB_en&q=linksys+router+setup&um=1&ie=UTF-8&source=univ&ei=PzPPS_e-I4a1rAeYxryFAQ&sa=X&oi=image_result_group&ct=title&resnum=4&ved=0CCEQsAQwAw
Apr 21, 2010 | Linksys WRT300N Wireless Router
How do i set up the Technika TA-709 Wireless Headphones to my tv. Have lost the manual and am not getting any sound only static on all 3 channel selections.
You should have all the necessary cables to do this with the package you bought, the wire which has a headphone style plug on each end should be plugged into the headphone jack on your tv.
If they dont work then there are two further things that could be at fault:
A: The headphone audio volume controls and the actual speaker volume controls on tvs are totally different and if the actual headphone volume is turned down then you will get an interference type noise thru your headphones as no sound is being detected by the reciever and therefore they go into kind of a standby mode. !!!!!!!!!!Try looking in your TV settings menu to make sure your headphone volume is turned up!!!!
B: being an owner of a pair of these headphones I know how audio the cable can easily turn faulty from prolonged use us. The wires can easily break inside but look fine from the outside so get a new one. Headphone jack to Headphone jack cable.
I use these along with my xbox 360 wireless earpiece (fits nicely under the headphones) and I think they're far superior to the Turtle beach headphones +++ My setup is 100% wireless which also makes it better than any turtle beach setup on the market.
Jan 07, 2010 | Audio Players & Recorders
Hi, i just cant get online wireless, i have to pass my belkin and plug straight into my laptop.
You need to configure the Belkin wireless settings and the configure the wireless card in the laptop with the router's wireless settings.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 13, 2009 | Belkin (F5D7230-4) Router (587009)
I cannot connect wirelessy to internet on my compaq pressario v6000. The orange wireless light is on and the internet connectivity icons in the task bar have a red cross on them. I have tried all options...
Part 1: Before You Start loadTOCNode(2, 'summary'); You need the following: • A broadband connection to the Internet and the appropriate hardware. For example, cable-based Internet access that uses a cable modem that is provided by your ISP. • The Microsoft Broadband Networking Setup CD-ROM. • The Microsoft MN-500 Wireless Base Station. • The Ethernet cable that came with your base station. • The AC power supply. • The blank floppy disk.Check the following: • On computers that are running Microsoft Windows 2000 or Microsoft Windows XP, you must be a member of the Administrators group to set up a network. If you cannot run Setup, click Log Off on the Start menu, press CTRL+ALT+DELETE, and then log on with as an administrator. • Turn off any firewall or Internet connection sharing software on your computers. Your base station replaces these functions. The Setup Wizard cannot continue if they are enabled. • Do you have a Point-to-Point Protocol over Ethernet (PPPoE) Internet connection or a static Internet Protocol (IP) address? The Setup Wizard prompts you to type your user name, password, and service name for a PPPoE connection. For a static IP address, you must have the IP, subnet, and ISP gateway addresses. If you have one of these types of connections, gather this information from your ISP.
Part 2: Install the Software and Connect the Hardware loadTOCNode(2, 'summary'); 1. Insert the wireless base station Setup CD-ROM into the CD-ROM drive. If the Setup Wizard does not start automatically, click Start, click My Computer, double-click the CD-ROM icon, and then double-click Setup or Setup.exe. 2. Follow the on-screen instructions to install the software. 3. In the second part of the installation, select the option to set up the wireless base station, and then continue through the rest of the Setup Wizard. 4. When the Setup Wizard instructs you to connect your wireless base station, position the wireless base station close to your modem and computer, and near the center of your intended network area. If you want to set up the wireless base station vertically, attach the included stand. 5. On the back of your computer, unplug the Ethernet cable that connects your computer to your broadband modem. Leave the other end of the cable plugged in to the modem. 6. Plug the cable in to the "To Modem" port on the back of the base station. The base station is now connected to your modem. 7. Plug one end of the blue Ethernet cable that came with your base station in to the Ethernet port that is labeled 1 on the back of the base station. Plug the other end into the Ethernet port on the back of your computer. This is the same port from which you just disconnected the modem cable.
Important The modem must use its original Ethernet cable or one of the same type to connect to the base station. 8. Plug one end of the power supply that came with your base station into the power jack on the back of the base station. Plug the other end into an electrical outlet. The power indicator light on the front of the base station should turn on. 9. Return to the Setup Wizard, click Next, and then go to Part 3 of this article.
Part 3: Configure the Base Station and Network Settings loadTOCNode(2, 'summary'); Continue to follow the instructions on the screen to configure your wireless network settings: 1. Setup prompts you to enable wireless security (WEP). Microsoft recommends that you enable WEP. 2. Setup prompts you to save your network settings to a floppy disk for use in later installations. A blank floppy disk is provided for this purpose. If you do not save to a disk, you receive a list of network settings to print or write down. 3. Click Finish to exit Setup, and then remove the Setup CD-ROM from the CD-ROM drive and the floppy disk from the floppy disk drive. You can use the same CD-ROM and floppy disk to set up additional computers on your network.
Part 4: Test Your Network loadTOCNode(2, 'summary'); 1. View the status of your network in the Broadband Network Utility (BNU). Make sure that you can see your base station and the computer that is connected to it in the BNU status screen: a. Click Start, point to All Programs, and then double-click Microsoft Broadband Network Utility. b. View the information on the Network Status screen. 2. If your broadband Internet connection is being shared through your wireless network, start your Web browser program, and then try to visit a Web site. If your network is working properly, you have access to the Internet from the computer you just set up.
Aug 21, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
