Question about Reddy Heating & Cooling
Heater won't refire after it warms up
My heater is plugged into a thermostat that I have set at around 65 degrees my garage is appox. 30 degrees. When the heater is cold and I first plug it in it runs good after the thermostat is satisfied and the heater shuts off the temp. of course drops to where the thermostat again fires up the heater ( which is still warn ) now the heater will run blowing out lots of smoke but not fire up for anywhere between 10 secs. to the point where I have to manually unplug it. The next day or when the heater has totally cooled its initial start is fine then the problem starts all over. Any ideas ? The heater is a Ready Heater Pro 150,000 btu Thanks, Mike
    Genius:
  • 1,199 Answers
I would think the thermostat is bad and needs replaced!
(this is a most common problem with this model!)
Please rate this response and help keep this area free!
Thank You!
Posted on Jan 22, 2009
  • 92 Answers
CAD flame sensor is bad, 3$ part and easy to install.
Trying to set temp on honeywell t-stat
I believe what your experiencing is the 75 degrees is the hold temp position...the display then reverts back to the actual room temperature...it doesn't mean the set temperature changed back to 65 degrees. Try to reprogram the thermostat schedules, and try not to use the hold function...just the temporary hold. (which is bumping the programmed temperature up or down until the next programmed period)
Dec 09, 2013 | Honeywell Programmable Thermostat Heater
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
I just installed a honeywell 5-2 progammable thermostate.. Everything is hooked up fine and I have my days, hours wake, sleep, leave...etc all set, but when it goes on.. for example, I have it set for...
You didn't include a model number, so it's hard to know for sure - but I'll take a stab at this one. Many of these t-stats have a programmable offset to reduce "hunting". This can be as little as 1 degree or more than 2 degrees.
This means if you set the offset to 1 degree and the room temperature to about 65 degrees, the furnace will heat the room until the t-stat registers a rising temperature of 66 degrees. The furnace shuts off and will not turn on again until the t-stat registers a falling temperature of 64 degrees. The average is 65 degrees, and prevents the furnace from starting and stopping numerous times instead of just once with the 1 degree offset.
You can further reduce the number of furnace start and stops by increasing the offset to 2 degrees. This would work like this when the t-stat is set to 65 degrees and the room is cool:
Room Temp Furnace
63 On
64 On
65 On
66 On
67 On
68 Off
The room is now warm and heat or furnace is off. The room begins to cool like below:
67 Off
66 Off
65 Off
64 Off
63 Off
62 On
With a 1 degree offset, the room temperature varies +/-1 degree (about 2 degrees total). With a 2 degree offset, the temperature about varies +/ -2 degrees (about 4 degrees total).
Also, when the thermostat shut the heat off, the heat that was made is delivered to the space instead of wasted by sending outdoors - so the room will get a little warmer even though no fuel is being burned. The same holds true at the other end. When the t-stat turn heat on, fuel is burned, but there's little heat until the source has reached the optimum temperature and then the heat is delivered to the space.
I hope this helps & good luck! Pleas rate my reply - thanks!
Jan 24, 2011 | Honeywell Programmable Thermostat Heater
I have a Vangaurd 6E720 30 gal electric hot water heater and the water does not get very warm.
If this is a new installation, make sure the unit is feed with at least 208+ volts of electricity.
If it is an older tank, try turning up the temperature setting on both thermostats. Set the top one 10 degrees higher than the bottom. If there is now change in the water temperature after a day or two, replace both thermostats. While your at it, change both element as well. A complete universal electric water heater rebuild kit should only cost around $35.
Aug 28, 2010 | Vanguard International Vanguard BY Rheem...
Hi i have a room thermostat with 4 programs per day on it. in the book it doesn't say if program 2 & 4 are the off times and if 1 & 3 are the on times. the thermostat was bought from wolseley....
On and off is determined by what temperature you set each program for. Example: 6 am - 70 degrees, 8 am - 65 degree, 4 pm - 72 degrees, 11 pm - 65 degrees. You can set the thermostat to fit your schedule and temperature preferences.  Good luck.
Jan 08, 2010 | Heating & Cooling
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
1998 Dodge Durango no heat when using heater.
BLEND DOOR STUCK OR BROKEN. NEEDS TO REMOVE DASH AND HEATER/EVAP CORE BOS TO REPAIR REPLACE.
Jan 08, 2009 | 1993 GMC Safari
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Too Warm
The thermostat may not be made to go lower than 50 degrees or so. A new one that can may need to be substituted. Go to the local appliance parts supplier. remove the old one and tell them what range you need.
Dec 27, 2007 | Dayton G73 Utility Heater
Heating & Cooling Logo
137 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
