Question about Hitachi CP-X201 Projector
Hitachi multimedia video projector CP-X201 compatibility problem
Recently I bought a Hitachi Video projector. I went through the manual where it is written that this product will work with PC/Laptop having OS Windows 98/Windows XP or higher. My laptop has dual OS - WinXP_SE & WinVista. I mostly use Vista, so I first tried the projector with WinVista but it didn't work i,e, I didn't get any display from the Laptop. Then I tried with WinXP_SE and it worked quite satisfactorily. I thought probably I did some mistakes while using vista. So, keeping the same connection setting, I just restarted the Laptop and selected WinVista again but the result is same i,e, no display. Thus, I wanna know whether this projector is non-compatible with vista or there are special settings or selections in Vista for which it didn't work?
simplemitch
  • 752 Answers
SOURCE: No input detected on projector
it sounds like the A/V reciever does not upconvert the component signal to HDMI. Not many do. The Marantz recievers will (SR6001, SR8001, etc..). Also bear in mind that HDMI cables are finicky and may require amplification over a few meters long.
Posted on Dec 04, 2007
Marrie
  • 563 Answers
SOURCE: Hitachi CP R555 Multimedia LCD Projector
Hi there
In your Menu options there is a subfolder where it either reads lamp or lamp timer.
Scroll down to it and hold down you right or left arrow key on the Projector for a couple of seconds.
Posted on Mar 26, 2008
SOURCE: Hitachi CP-X445W Multi. Projector
I have the same problem with a Hitachi CP-X345 Multimedia Projector. My Acer Aspire 3630 Laptop cannot be detected but it works without incident with a Dell Vostro 1500; just plug and play. Desktop settings to second screen doesn’t seem to help.
Posted on Oct 23, 2008
mastertech48
  • 149 Answers
SOURCE: problem with hitachi cp-RS55 multimedia projector sir
There is a menu item which has both the lamp hour reset and check air flow, etc. You must go into the menu and reset the air flow item. MAKE SURE YOU CLEAN THE DUST FILTER!! Heat is the number one killer of projectors and Hitachi's run "hot". I clean my projector once a week--Hey, I'm not rich. lol! Also, excessive heat will cause the lcd panels to fail prematurely and cause lots of other components to do the same.--Rick
Posted on Sep 07, 2009
fathitkf
  • 1871 Answers
SOURCE: My Hitachi CP-X201 has a flashing red lamp light
Hello :
Did you replace the lamp correctly ? If not , then i'll tell you how to do that :
Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
2:In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
3:Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
Please note that in some projectors a small inside filter should also be replaced.
4:Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
5:Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
new projector lamp
screwdriver
micro fiber duster
Warning:
avoid touching the bare projector lamp.
I hope this will help .
rate please !
If that wasn't helpful , then contact again please !
Posted on Mar 24, 2010
How to open the cabinet
On the bottom of the projector should be screws recessed about 3 inches down. There will also be some screws that are visible and some inside of the lamp compartment.
Aug 13, 2014 | Hitachi CP-X201 Projector
Video input not recognized
Will it work if you change the input to manual and select the correct imput source?
Mar 18, 2008 | Hitachi CP-X275 Multimedia Projector
Epson ex 7200 projects yellow
RGB Single not work. Check rgb cable
Nov 22, 2013 | Hitachi CP-X201 Projector
CPX 201 - everything projects with a purple tint.
check your cable connection attached to your computer...
Apr 27, 2011 | Hitachi CP-X201 Projector
My projector will not come on. the power light blinks green, then goes to red. the "lamp" light looks like it is coming on dimmly (red)
you need a new lamp:
http://www.shopvsc.com/Replacement-Lamps-for-Hitachi-Projectors-s/291.htm?searching=Y&sort=9&cat=291&show=50&page=1&f-CP-X201=105087
Oct 27, 2010 | Hitachi CP-X201 Projector
How do you set the closed captioning on the projector?
Its not usually the projector, but the video source (computer, DVD player, VCR etc...) that sets the closed captioning options - "the projector just projects what its given".
Here's the user manual - no mention of closed captioning
http://safemanuals.com/user-guide-instructions-owner-manual/HITACHI/CP-S210W-_E
Hope this helps
Mar 01, 2010 | Hitachi CP-S210W Multimedia Projector
Colour picture just went off
Hi biga63
I trust that you used the normal Video ( Composite ) Cable while viewing movies ?
Have you tried using another Composite cable ?
When using the S-Video - press the Source button on either your remote or Projector - untill you get to S-video.
If it still doesn't respond I'm afraid your Mainboard has a fault on it and will have to be repaired by a technician.
May 28, 2008 | Hitachi Performa CP-RS55 Multimedia...
Hitachi CP-X201 Projector Logo
66 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Chris Goulet
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
