Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do i set the travel limits on my craftsman garage door opener 139.53919
I need to change the travel limits on my garage door opener, the arm hits the plastic lens on the opener body when raised
  • Open the garage doorhow do i set the travel limits on my craftsman gar - icon1.png fully by pressing the wall control button. The bottom section of the door should be right at the header in the "full open" position. If it is too far back, the door cable can become misaligned. If it is not back far enough, you may not be able to get your vehicle in and out of the garage.
  • 2
    Position a stepladder behind the garage door openericon1.png motor. Locate the limit adjusting screws on the left side of the motor housing. Have a friend stand by the wall control button.
  • Sponsored Links
  • 3
    Insert a screwdriver into the slot for the "up limit" adjustment screw. Turn it to the right to decrease the door travelicon1.png and turn it to the left to increase it. Turn the screw in small increments.
  • 4
    Close the garage door by having your helper push the wall control button. Notice the seal between the door and the floor--there should not be any light coming through. Adjust the "down limit" screw in the same way if necessary.
  • 5
    Operate the door by the pressing the wall button and check your adjustments.
  • Read more: How to Adjust a Craftsman Garage Door Opener ' eHow.com http://www.ehow.com/how_5419011_adjust-craftsman-garage-door-opener.html#ixzz2Hm1tx0a0
    Posted on Jan 12, 2013
    Garage door loses travel settings after a day or two.Door closes then reopens after hitting the floor.I made the proper travel adjustments on the side of the unit then after 1 or 2 days the door hits the...
    I have been having almost the same problem. My up limit setting is changing. I intend to replace the limit switch assembly. I know of nothing else that can cause this problem.
    Dec 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
    HBW077 Craftsman: door travels downward only 10"
    Sounds like you have a bad RPM sensor board. This is a small printed circuit board just in front of the motor. It's job is to reverse the door when it hits an obstacle but will act as you describe when they go bad. The part number is 41C4398A and is available at Sears or any good door service company.
    Dec 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
    I have Craftsman ½ HP Garage Door Opener Model 139.18458D. It reopens immediately after closing. Sometimes it works normally, and sometimes gives this problem. I have tried adjusting the close force,...
    It sounds like the door is traveling too far in the down direction. When it hits the floor the safety causes it to reverse to the open position. You need to adjust the 'down limit' not the force.
    Sep 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
    My Craftsman garage door opener opens fine. It
    It could be closing too far or the sensitivity could be set too sensitive.
    Lube the springs, wd-40 rust may be the whole problem.
    If the door hits and the opener continues to move until the rail flexes upward and then reverses - probably the travel adjustment.
    Does the door close and stay closed if you hold the wall button down constant until it closes? - this would indicate a safety eye problem.
    If the door reverses before it hits the floor or just as it hits the floor it could be the sensitivity or if the safety eyes are mounted to the track they could be flexing enough to move the eyes out of alignment.
    Hope this helps.
    Jul 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Craftsman garage door opener #139.53985 The door reverses in the fully closed position. I can not decrease the down travel limit by turning the adjustment screw clockwise. Please comment regarding a...
    TAKE OFF THE COVER & SEE IF THE LIMITS ARE WORKING CORRECTLY.
    IF THEY ARE AND THERE IS JUST NOT ENOUGH TRAVEL YOU MAY NEED TO REMOVE THE CHAIN AND REINSTALL IT 4 OR 5 LINKS OVER THIS WILL INCREASE THE LIMIT.
    HOPE THIS HELPS
    Jun 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
    My garage door opener travels settings out of wack ??
    The 'up and down limit' adjustments are on the side of the motor unit.
    Aug 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Door will not stay closed
    Remove the cover and take a look at the limit switch assembly. It pretty much snaps together and it sounds like a part has come loose.
    Jun 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
    My door opener is new, Chamberlain, mod cg40cd, the drive will hit both limits. will not let me set the up and down limits, doesn't seem to matter whether I set the up and down to max either way??????
    THE TRAVEL ADJUSTMENT IS ON THE SIDE.
    YOU MAY BE ADJUSTING THE SENSITIVITY (TRAVEL LIMIT HAS NO MAX ADJ.)
    BE SURE TO RESET THE SENSITIVITY ADJUSTMENT TO ABOUT 1/4
    HOPE THIS HELPS
    Mar 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Craftsman door opener
    Does the door touch the floor? If so your down limit needs to be decreased.
    Does it open back up mid-travel? If so your down pressure needs to be increased.
    Read your manual about setting the safety reverse system if you change any settings.
    Nov 04, 2008 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    745 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
