Question about Elektra Mini Verticale A1 Coffee Maker
Elektra Mini Verticale is leaking around the steam/water spout
I think it's a gasket, but there a chart that shows me where it is, and how to replace it?
Antifreeze leaking from gasket under engine
Probaly your water pump is leaking and it's leaking to where it makes you think it's coming from somewhere else,wip up good,then drive around the block,and check it out and follow leak.Here's a link in case your water pump sprung a leak in fall.http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?fromSearchPage=true&pageId=0996b43f8036e84f&partName=Removal+%26+Installation&partId=0996b43f8036e84f
Oct 29, 2012 | Cars & Trucks
Water leaking from the left side
Hi
There are a few things that will leak on the left side
1. The boiler can leak if not descaled regularly or properly.
2. The steam boiler can start leaking around the o-ring gaskets or tubes.
3. The steam valve o-ring can wear out and leak.
Boiler will show whitish scale between the halves and will need to be replaced. The others are just replacing the seals or tubes.
May 16, 2011 | Saeco Magic Comfort Plus Espresso Machine
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Steam wand sprays hot water and very little steam. Cannot get a good frothed milk. Machine is also leaning forward by about 5degrees. Is this normal?
The boiler lever sensor is dirty, full of scale or bent so more water getting in the boiler than it should be. Try to remove the lever sensor clean it with a brush and put it back.
Please remebr to vote for this answer thanks
Oct 23, 2009 | Elektra Mini Verticale A1 Coffee Maker
No water coming out
Sounds like the gaskets need replacing.
A faulty steam solenoid can cause no water from the group head too
Oct 18, 2009 | Gaggia Classic Espresso Machine
Leaking water/steam
If it is leaking around the lid, then it certainly sounds like a bad gasket -- the water vapor sould only come out the valve on the lid.
Apr 28, 2009 | Kitchen Ranges
My chest type freezer ice up around the top but does not freeze except in the bottom portion
Check the gasket. Sounds like you have a leak somewhere causing the ice formations on the bottom. Easy way to check this is to have a steamer or a small pot of boiling water (steaming hot) while the frezzer is runing hold the pot of steaming water and watch the steam. You will see the steam going into the frezzer. BINGO leaking gasket. May need to replace the gasket or may beable to fix. You will see and know what to do. Keep me posted. Good luck.
Apr 06, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
I'm looking for Elektra S1 Owner.s manual
if you have 2 gauges, one shows from 0 up to 3 bar second from 0 up to 16 bar.
  1. the gauge o - 3 shows steam pressure and it should be from 1.1 up to 1.5 bar
  2. if you have second gauge you look it during brewing coffee, it should be from 7 up to 9 bar(it shows the pressure of pump.
anyway becouse it is old machine you should compare the gauge with new one(ehamle for the steam attach to steam pipe one gauge and live valve open) than you will know if it is showing true values.
Nov 23, 2008 | Elektra Microcasa S1 Coffee Maker,...
Water Spout Leaks after Brewing Coffee
You have to replace the gasket in your steam valve, if you have a steam valve in plastic i recomend you to replace it with a steam valve in metal.
Best regards
/Mirran
Sep 04, 2008 | Saeco Incanto Classic Espresso Machine
Leaks at the hot water spout during coffee brew
I had the same problem. I ended up taking the coffee machine apart and found that the reason coffee trickles out around the hot water spout is that the two coffee nozzles were partially plugged. Since I Had parts of the coffee machine apart I was able to clean it easily. It may also be possible to clean the assembly using a pick of some sort and clean out the holes of the two normal coffee spouts. Inside it is just a open cavity so gentle poking around and using some steaming hot water may do the trick.
If you want to take the machine apart you need to do the following: 1) take of the warmer plate on the top - 2 storz screws but an allen key works as well 2) take off the top plate of the machine - another 4 or 5 screws - make sure you empty the beans first otherwise you will have a mess 3) remove one screw from the right hand side of the removable coffee ground tray. Once this screw is removed the front panel is free to swing open except for the pipes connecting the front 4) unclip the steam assembly - there are a couple of plastic catches on the top. this will free the steam assembly from the front panel and also free a pipe connections. The steam dispenser pipe will also come free from the steam assembly. 5) remove the coffee pipes from the up and down sliding coffee dispenser. This is a small whitish color clip with 2 pipes connecting into it. The white clip has a little plastic catch on the top that frees it. The front panel should now swing open freely. 6) remove the sliding coffee dispenser from the front door. There are 4 plastic catches, 2 on either side. the whole front sliding coffee displenser now comes free 7) Take the sliding dispenser apart by release the 4 plastic catches on the front curved planel. 8) Inside the sliding dispenser is a white plastic piece that connected to the piping released in step 5. There is a small plastic catch that needs to be pressed while pulling fairly hard on the plastic piece and bending the whole piece. 9) You will now see the plugged spouts. It goes back together really easily.
Aug 13, 2008 | Jura Capresso Impressa S8 Coffee Maker,...
Elektra Mini Verticale A1 Coffee Maker Logo
23 people viewed this question
Top Elektra Coffee Makers & Espresso Machines Experts
Jaime Hernandez
Shehu Pro
Shehu Pro
Shrikant Shinde
Shrikant Shinde
Level 1 Expert
Are you an Elektra Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
