Question about Sony CDX-GT300 CD Player
Sony cdx-200 wont work
I have a sony cdx-200 installed in my 1998 dodge ram.It worked fine till yesterday then i had to unhook battery to clean battery posts. after i hooked battery cables back up it wont work. it has came on twice while driving down road but when i go to adjust it the power goes off and wont come back on. what can i do?
    Scholar:
  • 116 Answers
I would remove the CD player and chek the connectons inside. Check the power wires (pink and Red/white Dodge colors) to make sure you have power. I know for a fact that the number one cause for Dodges to do this is because while the harness you bought to cnnect to the factory plugs HAS a black wire for ground, there IS NO Oposing wire. It's usually a braided silver wire or a thick black attached to te stock deck. Make sure you are not getting a ground through the antenna.
Let me know what you found out,
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Installing a distributor in a 1998 dodge ram 1500 5.9 LT
Replacing Distributors: 1998 to 2005 models
  • Trace the spark plug wires to the distributor; it will be at the back of the engine block, in a cramped space.
  • Disconnect the negative battery cable to the distributor and unhook the air cleaner tube. Unscrew or unhook the clamps holding the distributor cap in place, and unscrew the Camshaft Position (CMP) sensor connector with a screwdriver.
  • Matchmark the distributor housing and the rotor for later realignment, as well as the distributor housing and the intake manifold. Unbolt the holding clamp and remove the distributor.
  • Set the engine at Top Dead Center (TDC) mark of the No. 1 cylinder compression stroke with a socket with breaker bar (long-handled ratchet).
  • Install the Ram distributor, replace the clamp and lightly tighten the bolt. The distributor part number is A1303801 from Parts Train, but numbers differ from different manufacturers. Order using the model, year and engine size.
  • Turn the distributor in its seating so the rotor lines up with the No. 1 cylinder mark on the Camshaft Position (CMP) sensor. Bolt the clamp bolt to 200 foot pounds (22.5 Nm).
  • Reattach the CMP sensor connector and use the screws or clamps to replace the distributor cap. Connect the air cleaner tube and the negative battery cable
Aug 19, 2016 | Dodge Cars & Trucks
Why doesnt truck show trouble code or engine light and not start aftr sitting all day?
I would have a load test done on the battery/s as you may have a failing cell. Remove battery terminals and clean both posts and terminals with sandpaper until you see shiny metal. The black coating is lead sulphate which has a high resistance to
current flow both into and out of the battery.
Apr 07, 2013 | 2001 Dodge Ram - 1500, Quad cab, short...
1998 dodge ram 1500 dash lights wont work
Walker Muffler - Aluminized Steel Direct OE Replacement 1998-2001 Dodge Ram 1500.-------------------------------------------------------------------------------------
SLIM HID XENON light
Jan 10, 2013 | 1998 Dodge Ram 1500 4WD
1998 Dodge 1500 with 4.7L engine starts fine but won't idle. Yesterday it ran fine.
This symptom is classic for a dead/dying battery. Have the battery load tested. If it shows the least bit flakey, replace it.
If it is more than 5 years old I would replace it as a preventative measure.
I believe you will find the battery is your problem.
Don
Apr 15, 2010 | 1998 Dodge Ram 1500 4WD
My 1998 dodge ram 1500 heater wont blow hot air I replaced water pump ,thermostat and radiator blower works fine just no heat.
check to see if both heater hoses are same temp when engine is at normal running temp if not heater core not flowing coolant may need to flush also make sure it does reach normal temp around 200
Jan 31, 2010 | 1998 Dodge Ram 1500 4WD
Sony CDX-F5700 no longer sees Sony 10-disc changer
face plate is going bad lcd is fading solution--replace face
Jun 21, 2009 | Sony CDX-F5700 CD Player
2003 Dodge Ram 1500 Fuel Gauge drops to empty while driving.
I have the same problem on my 2003 Dodge Ram 2500 5.7 Hemi. Also the gauge is sometimesslow to register after filling. Maybe 5 minutes.My neighbor has the same poblem with his 1999 Durango? I think this is a job for a recall.
Mar 23, 2009 | 1998 Dodge Ram 2500 2WD
Cdx-gt520 wont turn on
Pull the radio out and check the ground has a good conection. I had to run a new ground wire on one of my cars and make sure the hot lines are gitting a good curent.
Jan 20, 2009 | Sony CDX-GT520 FM / AM Receiver
Sony CDX-GT300 CD Player Logo
189 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
