Question about Reebok Exercise & Fitness
I can't unfold Reebok Z9 treadmill. I press the latch at the back on the bottom, but nothing happens.
The latch on Reebok z9 doesn't unfold the treadmill when I press it where indicated. Please not I haven't connected the treadmill to power as I understand unfolding is a mechanical process and doesn't need power.
SOURCE: unfolding the deck on treadmill
From the owners manual:
HOW TO LOWER THE TREADMILL FOR USE
1. Hold the upper end of the treadmill with your right hand.
Pull the latch knob to the left and hold it. It may be necessary
to push the frame forward as you pull the knob to
the left. Pivot the frame downward and release the latch
knob.
2. Hold the metal frame firmly with both hands and lower
it to the floor. CAUTION: Do not grip only the plastic
foot rails or drop the frame to the floor. Bend your legs
and keep your back straight.
Posted on Jan 11, 2009
SOURCE: I need to unfold my treadmill I move it to a
Ijust purchased a used treadmill. how do I unfold it?
Posted on Jan 18, 2010
  • 103 Answers
SOURCE: How do I unfold my Reebok 8700 i fit? I folded it
Hello there, If you stand behind the machine you should see the safety latch mechanism (round knob on the long section in the middle when the unit is raised) You will need to push up slightly on the walking belt section while pulling out the knob located on the safety rod. While pulling out the knob lower the unit about 3 inches and then release the knob. If you release the knob too soon it will catch back in the hole again. This should release the unit.
Good Luck! Tim
Posted on Feb 13, 2010
SOURCE: how do i unfold the reebok 8700 es treadmill? Just
We have a Reebok 8700 treadmill and need to get it downstairs-what is the easiest way to take a small amount apart ?
Posted on Mar 04, 2010
maxtreadmill
  • 832 Answers
SOURCE: describe how to unfold a treadmill, pro form ex
Hold the upper end of the treadmill with your right hand on the back end of the unit. Using your left hand, pull the lock knob to the left and hold it. Pivot the treadmill down until the frame is past the pin on the lock knob. Note: You may need to push the handrail to the side slightly. 2. Move in front of the back end and hold the treadmill firmly with both hands, and lower the treadmill to the floor. CAUTION: To decrease the possibility of injury, bend your legs and keep your back straight
Posted on May 31, 2010
Reebok z9 treadmill beeping with error e01,this happened once before then went ok,driving me mad any help please
Try to check the Speed sensor. Check for its aliment also check is there is any dust accumulated on it .
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 13, 2016 | Reebok Exercise & Fitness
Knocking sound on Reebok z9 treadmill. Why does it happen? Did i ovover tighten the belt? Its brand new but knocking starts as it gets quicker. Also is suppose to go to 16kph but only goes to 10kpm. Any...
What is the frequency of the knock? Is it every second, few seconds, or very fast? This can tell if it has something to do with the track or the motor.
Feb 01, 2015 | Reebok Exercise & Fitness
My Z9 treadmill will not turn on... i've flicked on the power swtich and the switch on the machine but it wont sstill come on. what can i do?
Our Z9 has just done the same, switched on the power but it doesn't turn on. Was just wondering if you managed to fix yours and if so how?
Thanks.
Sep 12, 2013 | Reebok Exercise & Fitness
E2 appeared in monitor of reebok z9
adjust the speed sensor, clean it, tight the plug very well, see the diagram
adjust the reed switch, clean it, tight the plug very well, see the diagram
test the input voltage motor, if there are the motor need repair
4) test the output board, for input voltage motor, if there are NOT the board is faulty. see the diagram
.God bless you
Oct 10, 2012 | Reebok Exercise & Fitness
Good Luck! Tim
Feb 12, 2010 | Reebok 8700 ES Treadmill - Silver Service...
I am trying to pair my z9 with my nokia n95
  1. Delete the old Z9 pairing
  2. With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes
  3. Enter Passkey "0000" when your phone prompts you. The phone and Z9 will now Pair
I hope that helped.
Feb 28, 2009 | Blueant Z9 Wireless Headset
Pairing z9
Pairing Procedure
This is an example only and may differ from your phone, but the process will be the same.
With the Z9 OFF, Press and Hold the MFB for about 6 seconds. The LED will appear a solid Blue, and then will start flashing. The Z9 is now in Pairing mode and ready to be found in searches by other Bluetooth devices. Pairing mode will be active for 2 minutes.
Perform a Bluetooth device discovery on your mobile phone to add a new device.
Jan 29, 2009 | Blueant Z9 Wireless Headset
Exercise & Fitness Logo
333 people viewed this question
Top Reebok Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Shehu Pro
Shehu Pro
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
