Question about Gateway Computers & Internet
Gateway 2000 PS-120 - opening the case
How do I open the case? It looks like it should just slide out after all the screws are removed, but it won't budge. There is the lock mechanism on the front, which is in the unlock position (no key for it; I used a screwdriver) but it still won't budge. Ideas? Thanks.
tweaks4u
  • 27 Answers
SOURCE: Opening the case of SR1403WM Computer
Please refer to the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00595250&cc=us&lc=en&dlc=en&product=501310&dlc=en&lang=en
Hope this helps!
Pat
Posted on Mar 11, 2008
SOURCE: OPEN CASE
This is called a micro tower case.
Facing front, turn unit on its rubber feet. (right side down) Push in cover release handle. (located on front panel to left of cd drive, in black area) Lift cover gently upward, tilting back and away from case. To replace, reverse procedure, first making sure wiring is clear.
Posted on Aug 08, 2008
repustech
SOURCE: Open Gateway ES2 300X case
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Posted on Sep 23, 2008
  • 2692 Answers
SOURCE: Open case
Here is the Gateway download site to obtain your manual which should show you how to open the case.
http://support.gateway.com/support/drivers/search.asp?param=gateway+500+SE+&x=12&y=10&st=kw
Posted on Dec 19, 2008
  • 21 Answers
SOURCE: Opening a Compaq Presario S4020WM side panel
Check here : http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=39140&lc=en&dlc=en&cc=au〈=en&os=228&product=326832
Click on HP Home on taskbar to find full menu of services.
Cheers.
Posted on Dec 29, 2008
How to remove hard drive from gateway tower
Unplug system.
remove screws from case so case opens.
remove screws from drive.
remove plugs from drive.
slide out.
done.
Sep 02, 2014 | Gateway Computers & Internet
How to open the back of a model m 6332 laptop
Get a philip's head (star) screwdriver and remove all screws from the bottom of the laptop. Remove the battery and any screws revealed under the battery.
Next look for a thin straight-edge and -very gently- pry the keyboard loose; if you have trouble at this step, look underneath again for any small holes in the metal casing directly under the keyboard.
Also look for any removable rubber or plastic bumpers as these often have structural screws underneath them.
Finally, with the keyboard removed, you should see a few more screws which will at last allow the case to come apart and get to the boards underneath.
Feb 07, 2014 | Gateway M-6332 Notebook
Hard drive bay opening
Take the screws out of the panel labeled 3. You'll find the hard drive in there. Usually, the drive will be secured with 2 or 3 screws - undo those and slide it out to remove/replace. I tried to look for a service manual but no dice. Best of luck!
Feb 04, 2014 | Gateway NV77H19U Laptops
I need to replace my Gateway W6501 CD DVD RW Drive
power down unplug, open case, might need to open both sides, undo screws, pull plugs off, slide out replace, close up power up
Mar 14, 2013 | Gateway Computers & Internet
How do I open the case on a compaq presario 7478
you can browse to the internet for dismanteling manual for you compaq.
Jun 30, 2011 | Compaq Computers & Internet
How to open gateway FPD 1765 LCD CASE OR BACK COVER
At Last! Okay this is how you open a Gateway FPD 1765 monitor. This Monitor open from the front first to reveal 4 screw under the black trim. Lay the screen face up, NOT FACE Down. So that the GATEWAY LOGO is looking at you. Carefully, lift up the black plastic trim slide a knife or slim tool, or your fingers will do,lifting the trim up a off. BE CAREFUL NOT TO BREAK THE POWER BUTTON WIRES, near the power on button. Then remove the 4 screw holding the back cover on. When you remove these screw the monitor is free, but careful there are 2 set of thin short wires that need to be un plug. You should be able to go for there.
Jan 30, 2011 | Gateway FPD1765 17" Flat Panel LCD Monitor
How do I remove the outside case on my Gateway DX4300-03U computer?
There should be some screws on the back side of the computer. If you look close you can see that there are either separate panels or one and a L shape panel. Take the screw out of the single panel, or all if ness. and slide toward the back of the computer. and then it should be very easy to pull it open. DO NOT FORCE IT. Look closely for Latches or Hinges
Nov 04, 2010 | Computers & Internet
How to open DX4200 case
Hi, Here is the manual for it: http://support.gateway.com/s/Manuals/Desktops/8513027.pdf But as a quick reference, simply unscrew the two thumbscrews on the back of the left hand side and slide the case away from the PC. This will expose the components etc....
Jan 04, 2010 | Gateway DX4200-09 PC Desktop
How to open the case safely (without damaging it)?
Remove all screws from the enclosure, and then slide a then metal (non magnetic) slide to pop the clips off of the sides of the enclosure, lengthwise. You can do it without breaking the plastic
Jul 13, 2008 | Buffalo Technology MiniStation Turbo 120...
Opening a Gateway Solo 2150 laptop
I found the answer on another wed site. I tried it on my Gateway Solo 1500 and it works! The extra screws are hidden on top. You carefully remove the small face plate around the power button. I used a very small screw drive to lift it off.
Opening Gateway Solo 1400
by Aelanna - 2/3/05 11:04 AM In reply to: Gateway SOLO 1400 by hunjibunji
I'm also an A+ certified tech, but I've done notebook service for a lot of years. I just finished opening up a Gateway Solo 1400 and it was NOT easy! There are no screws holding the keyboard on the bottom of the machine. You can get the case open about 95% and there will be one area stuck, in the back near where the screen cable goes into the unit. There is a hidden screw on the top of the case next to the hinge. To get to it, you have to remove the two screws that hold the plastic hinge cover and pry off the cover. I only managed to find it after removing the keyboard, the display, and the panel with the LEDs and power button. (The screws holding the keyboard are on the top of the machine, underneath the cover with the power button on it.)
May 02, 2008 | Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
