Question about Zanussi Dryers
Zanussi zdc 67550w tumble dryer stopping after 10-30 seconds of the cycle
The start/pause light flashes red and the machine beeps every 30 seconds
    Sergeant:
  • 211 Answers
See if it is overloaded or the clothes are excessively wet... Take out 1/2 the clothes and try again.
Posted on Jan 12, 2013
SOURCE: Dryer quit running in mid cycle
It's the thermal fuse and it's easy to install if you have a front loader just take the kick panel off in front, make sure you remove the lint filter and the cover that goes up to the lint collector and you will see the thermal fuse. Make sure you unplug before doing this. Take the two screws out of the bottom of kick panel and than use a putty knife and push down and the panel will come right off. Hope this helps you out.
Posted on Jan 16, 2008
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
  • 306 Answers
SOURCE: Zanussi zdc46130w Fault.
I think you should read the instruction manual . 3 beeps means some information to begin a solutin.
Posted on May 04, 2009
bomark2002
  • 160 Answers
SOURCE: Broken Zanussi tce 7127 w dryer
the dryer is telling you a trouble code like in a car when something is malfunctioning with it, try to call your manufacturer and ask them to tell you what that code means.
Posted on Nov 06, 2009
Testimonial: "That's a great starting point - thanks! I rang the manufacturer and they didn't know what the code meant..."
SOURCE: I have a bosch WTE86304GB/03 tumble dryer red
Hi the problems is not a sensor its the codenser unit. Above the water collector should be a panel on the front of your machine, open the panel and you will see the condeser.covered in fluff, simply remove the condeser and clean it under an outside tap after removing as much fluff as possible by hand. Push back into place when clean and hey presto back to new again.
Posted on Aug 11, 2010
Zanussi tumble dryer zdc 77570w
Sounds like the condenser is your problem but, not positive because I have never dealt with these types of dryers.
Aug 27, 2014 | Washing Machines
Washing machine humming but nothing else :(
if you watch carefully, the end light flashes and then stops, and then flashes again... how many times flashes?
Dec 22, 2013 | Zanussi FS1455W Front Load Washer
Zanussi ZWF580- after the wash cycle I press the red button to rinse & spin but it just tumbles & rinses again, then the red button comes on again. This could go on all day. I find that to finish...
If the START / PAUSE button lights up red, the washing machine detects a malfunction. Now you should count how many times the START / PAUSE button lights up red and tell to us what kind of malfunction is being done.
Try to rapid reading of alarm codes when the appliance is in normal operating mode (e.g. during the execution of the washing
programme):
Press and hold down START/PAUSE and the nearest option button for at least two seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
LED indicator START / PAUSE with red light = indicates the first digit of the alarm code (family)
• LED indicator START / PAUSE with green light = indicates the second digit of the alarm code (internal number of the family)
Dado
Jan 21, 2018 | Zanussi FS1155W Front Load Washer
Feb 15, 2009 | Zanussi TC7114W Electric Dryer
How to fix a belt on zanussi tumble dryer model number zdc 46130s
heat elemet works, drum will not tumble. Help. Little odl aldy, Rosemarie
Jan 25, 2009 | Dryers
Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Oct 17, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Dryers Logo
505 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
