When I turn off my television my vip722k powers off
Turning off the master TV results in a total shut-down of the satellite receiver, thus preventing me from watching tv in my other room. When I turn the master TV back on the receiver box goes through a rest, signal reacquisition, etc. Every time. How can I prevent the receiver from shutting down everytime I turn off the TV?
    Genius:
  • 1,669 Answers
There should be 2 buttons on the remote control that turn on power. One should be for all devices controlled by it and the other for devices you press first and then press that power button.
Posted on Jan 12, 2013
  • 3 Answers
SOURCE: Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Posted on Jul 19, 2008
  • 374 Answers
SOURCE: combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Posted on Sep 23, 2008
SOURCE: Motorola DCT6412 Cable box
Ive seen this before...that may be indicative of an upgrade of the software in the cable box that comes from your cable provider. The best thing to do is plug it back in, let it get the "yellow ring" for a bit, and wait for the upgrade (it make take 10 - 15 minutes). Then things should return to normal... If the condition persists, try to call the cable company.
Posted on Feb 05, 2009
  • 56 Answers
SOURCE: TV ''Dish'' not working on second TV
check sat in cable, if cracks or breaks in line can cause sfss. also on back of receiver you want to make sure that sat in cable has a little copper wire sticking straight up and that its getting a good connection on the back of the receiver.
Posted on Apr 28, 2009
SOURCE: Resetting my TECHNIKA STB9007LE Freeview Receiver
Hi there
It appears that somebody at Technika thought it would be a wonderful wheeze to the box ask for a PIN when retuned. My daughter had the brainwave of putting in four zeros and voila!!!
Hope that solves your problem
Posted on Oct 02, 2009
Vizio LED TV E48-C2 keeps turning on by itself.
Turn it off and on using the power point. You will also save power as equipment still uses power in standby mode.
Aug 01, 2016 | Vizio Televison & Video
My pioneer sx 203 stopped working. It no longer powers up. It was playing fine then I turned the volume up from 3 to 5 and it totally shut down. Doesn't work at all now.
If it shuts down after turning up you have a speaker and or speaker wire issue, Try disconnectiong all speakers and see if it shuts down then, If it shuts down with no speakers connected then you do have a receiver problem
Feb 18, 2015 | Pioneer Audio Players & Recorders
How do I stop my toshiba tv from instantly turning off
That sadly is a power supply failure of some kind, most likely. It is shutting down to prevent more problems.
Jan 15, 2015 | Toshiba Televison & Video
Power light keeps flashing with no picture
What are you using for receiving a picture, cable, satellite, or direct off the air broadcast? If you use either of the first two make sure that those two devices are "ON" first or turning your set on will result in receiving no input from the receiver. Also be certain that in the menu for your flat screen that you have the correct receiver selected as the input to your tv or once again you will receive no picture.
Jan 26, 2012 | JVC Televison & Video
Does Dish Network VIP722K have a removable smart card
They have smart card slots, but don't use them for standard satellite usage.
Jul 06, 2011 | DISH Network ViP722 DTV Receiver /...
I have a problem with my new ViP722k DVR that results in no recordings taking place. I thought originally it may have been only when the power has been turned off by my ESPN universal remote control, due...
Hello! Daniel Busa with Dish Network here. A problem like that would either be a glitch or hard drive issue try cancelling and recreating the timers. if it persists perform a hard reset and keep us posted. You can follow us on twitter or call us at. 1-800-333-3474
Aug 29, 2010 | DISH Network ViP722 DTV Receiver /...
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Feb 01, 2009 | Hitachi 50FX30B 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
