Question about Ovens
The oven and the grill dont work
Hi There
I have got smeg sp680mfd built in oven and hob.
Last year i replaced the selecton switch due wear and trear the knob came of and snapping the steam of the selecton switch.
The oven and the grill were working fine and now you need to mess arround with the timer and it does come on for a second then switchs off. As you know i can`t set the time on the clock.
Can you tell me what can be wrong as i can`t make food in the oven or the grill another thing is i think the oven bulb is gone and i think the fan is not working.
Please advice as i want to get this fix
  • Ovens Master
  • 19,396 Answers
It can be the control board, the thermal fuse at the back of the unit, or a lose contact on the wiring harness.
You need to test parts before replacement.
By entering model number Here you find all diagrams and parts for your appliance.
Need help finding the model number on your appliance?
Posted on Jan 23, 2009
  • 1,800 Answers
The electronic borad on the oven is faulty in this case.
its the responsible part of everything electronic in the oven such as clock.
you can take apart the oven and locate where the board is.most likely its located where the clock is located.
bring medical alcohol and a brush and clean the whole board then test it that would fix the prob.
Posted on Jan 22, 2009
    Genius:
  • 1,199 Answers
First try resetting by unplugging for ten min and try again!
let us know if that works!
My SMEG oven will not work, when I try to turn on the oven the whole thing powers down (the clock timer dies) The only way I csn reset this is to switch the power at the isolation switch off and on several...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 20, 2013 | Smeg Ovens
Smeg oven UK80MFX1 troubleshooting
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 30, 2011 | Smeg Ovens
Hi, we have a se280x oven and its about 4-5 years old and inherited this when we moved in 2 years ago. But the oven seems to heat sometimes or not constantly and especially seems like e the upper and...
Apr 15, 2011 | Smeg SE280X Stainless Steel Electric...
My smeg willl only work on the grill setting,. when I use the oven switch everything comes on but it does not heat up
Mar 13, 2011 | Smeg SE280X Stainless Steel Electric...
Hi, I am in the process of installing a new kitchen. I was recommended to buy Smeg appliances- an oven and ceramic hotplate by a salesperson stating they are very good aplliances, however another...
From experience I have found Smeg appliances to be very reliable.
It is difficult to judge reliability of appliances but generally these days NO appliance will last without some form of brake down. They are not made to the same quality as appliances of a few years ago.
If you stick to german made appliances (Bosch, Neff, inc Smeg ) then they tend to be built to a higher spec.
Regards
Aardvark Repairs
Nov 16, 2009 | Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
Smeg oven does not turn on - the light and the fan work but
Is the hob seperate from the oven? if it is then I suspect the problem is witb the oven, you need to check the supply to the oven to make sure you have got voltage, if you have then the prob is within the oven, and this could be one of several things
Some single ovens are sometimes plugged into a normal socket, in which case you need to check the fuse in the plug.
Hope this helps.
Plz leave feed back.
Ta.
Dec 09, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven not working
You have a element and or a faulty thermostat
Nov 25, 2008 | Smeg F170 Pyrolytic Stainless Steel...
Hotpoint Double Oven ceramic hob
suspect more than one problem. half grill not working may be due to half the element gone open circuit. the other problems could be due to an installation fault. many ovens have links in the connection box which have to be tightened down. this is often overlooked. look at the connection box or terminal strip to check. there is often a diagram of hoiw it should be done adjacent.
Jun 02, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
