Question about Gateway Nv-55s14u Notebook Pc - Amd A6-3400m 1.4ghz, 4gb Ddr3, 640gb, Windows 7
Error Loading Operating System problem
Ive tried to load from "last good known restore point" and stiill just flashes the windows icon
  • 2,878 Answers
Try Safe Mode by pressing F8 during boot. Then use System Restore to roll back to date prior to problem.
Posted on Jan 14, 2013
Get error loading operating system
Try to enter in Safe Mode or boot from the original Windows CD
and set a system repair. Sometimes, sistem files are corrupted no matter why. So, in my opinion, boot from the original Windows CD
and then set a system repair or check for a Restore Point. Just in case. Good luck !
May 26, 2015 | ASUS Computers & Internet
Tip
How can I restore my PC?
<span><span> <p><span><span>If Windows is running (and you are logged in as administrator), choose <b>Start </b>&gt; <b>Programs</b> &gt; <b>Accessories</b> &gt;<b> System Tools</b> &gt; System Restore. Select "Restore my computer to an earlier time" and click click the Next.Now last checkpoint and click Next. <b>System Restore</b> message may appear - click OK. Now click Next on the confirmation page and the latest Windows XP configuration is restored. If you can not get Windows XP to start, press [F8] at boot and select "Last Known Good Configuration 'to load the latest <b>Windows XP</b> restore point loaded</SPAN><span></SPAN><span></SPAN><span><span></SPAN><span></SPAN>.</SPAN><span></SPAN><br> <P style="TEXT-ALIGN: left; TEXT-INDENT: 90pt; MARGIN: 0cm -16.7pt 0pt 0cm
on Feb 14, 2011 | Computers & Internet
Error 80070005 windows update
Start your computor under safe mode, then try start windows under last known.... If that doesn't work. Again Start under safe mode and use system restore point. Go to a point before that update happened, start from there.
Jun 30, 2012 | Microsoft Computers & Internet
When booting desktop doesn't load
There are a couple of quick fixes you can do.
First, boot into Safe Mode (Repeatedly tap the F8 key while the system is booting, before the windows logo appears) A Menu will pop up, press Boot Into Safe Mode. From there you can try a System Restore to a known good date.
System Restore - Click Start -> Control Panel -> On the top right, type "System Restore" without the quotes. Click on "Restore system files and settings from a restore point". You can choose the recommended restore or a specific date.
The other option is to boot into "Last Known Good Configuration". To do this, use the F8 trick again while booting, but instead of Safe Mode choose "Last Known Good Configuration".
Please note that either of these run a risk of some data being lost from the time the restore point was made. You "shouldn't" lose anything but just want to make you aware.
If this helps please give a good rating. Thanks.
Jun 30, 2011 | Gateway Computers & Internet
Whats the problem when computer boots, the loading progress bar og windows XP is displayed, but as soon as the computer goes into Windows XP, the screen turns black and stays black?
you coform the problem comes only when printer connected.
detach the printer cable from system and boot the system.
the problem still persist then reload the Win XP
re install the printer driver.
the problem will be solved
alexander
Apr 15, 2011 | HP LaserJet 1320 Printer
MY LAPTOP WENT OFF DURING UPDATES NOW IT WONT FINISH LOADING, it comes up update 3 of 3 then restarts and says same again keeps doing it not letting me in to lap top anymore seems stuck on updates
Hold F8 while booting to go into safe mode, or last known good configuration. Then, preform the update from there, and that should fix your problem.
Feb 28, 2011 | Acer Computers & Internet
Most of the services on my vista have been disabled and i am unable to start them again . this happened after my laptop hanged and i had to start it by the last best known settings option .
You must have logged into safe mode before running last known good configuration, that is the reason why it has loaded safe mode settings when you chose last known good configuration.
You can be trying to do a system restore (start - type system restore - right click on system restore and click on run as administrator) and choose a restore point when you know your computer was working fine (before 2 or 3 days) and this should take care of your problem.
Dec 25, 2010 | Computers & Internet
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
My laptop cant use in noraml mode and it turns to white
resetart the laptop and choose "Debugging mode". This will show the list of files that loads during the initial boot up and OS starting. Reply with the last file listed before the BSOD.
If the BSOD occurs after the logging, list where it occurs (during the "Starting Windows XP window" or "after the desktop appears but no desktop icons".
Also, provide what OS is on the laptop.
Nov 18, 2009 | Sony Computers & Internet
"error loading operating system"
Sounds like your Windows XP installation failed. Run the XP install again making sure to delete the existing partition and then create a new partition. You could also have a bad drive out of the box.
Sep 15, 2009 | Dell Latitude D600 Notebook
Gateway Nv-55s14u Notebook Pc - Amd A6-3400m 1.4ghz, 4gb Ddr3, 640gb, Windows 7 Logo
23 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
