Question about Samsung RB195ACBP
Door on top off hinges dinging sound no lnside light cannot put item on side of door
Rent to buy and they refuse to fix it say yes then no on fix income hate to lose money i payed but i need it fixed and i am not sure of warranty but this is last attempt before i return it
2 Suggested Answers
  • 87 Answers
SOURCE: Door Handle
If you enter the make and model no. then people may be able to direct you to a suitable website. Alternatively enter your make of cabinet and add freezer spares and Google search it. Hope this is of some help.
Posted on Sep 11, 2007
Item comes with right hinged door...I need left hinged door.
On some models you can move the hinges and door pull to the opposite side. On the side without a hinge, you would see plugged holes (plastic plugs covering the holes). You may have to move the top right hinge to the bottom left and bottom right to the top left (opposite of this for a left-hinged refrigerator/freezer).
You may need help to do this, and be careful.
Donald
Jan 27, 2016 | Refrigerators
Do the door hinges ever wear out
I did my own search for the same problem and saw Dougs question and lack of a solution. I have the same sagging door problem and was looking for a fix.
First, when I removed the weight of the items from inside the door, the door closes properly. This means that the door is not very sturdy and cannot hold the weight of items placed on door shelving. There are NO adjustment mechanisms on the door hinges either. Bad on Amana. The GOOD NEWS is that I fixed the problem.
Take out all items from the door shelves. I removed the top hinge with the door closed to keep it from falling. I took the door off and placed it on the floor. The lower hinge has a plastic pivot over a steel pin - remove that for a moment. Place steel washers over the steel pin - about .080" or so thickness. Replace the plastic pivot. Replace the door. Add the normal weight of items back on the door shelves. The door closes perfectly. At least until the door sags again and I'll need to add another shim.
Jun 21, 2010 | Amana ABB2524DE Bottom Freezer...
Can the door swing be changed?
Yes the door can be changed to open from the opposite side, there are removal plugs that need to be removed from the opposite side and just change all the hardware from one side to the other, change the middle hinge first and put on the bottom door first, after its is mounted you can put the bottom part of the top door on the hinge and last the top hinge, and just make a few minor adjustments.
Apr 16, 2010 | Amana ARB1917CSR Bottom Freezer...
Lights dont come on when i open the doors
THE BUTTON ON THE THRESH HOLD OF DOOR BY HINDGES IS STUCK IN .OR CHECK FUSES MYBE BULB
Feb 21, 2010 | 2003 Ford Mustang
Hi! I have a 2002 Cadillac Deville and yesterday I unlock the door with key pad and opened it and when I did I heard the chiming sound that it makes when you have the keys in the ignition with the door...
It may be trying to get your attention for an open door, trunk lid or other item requiring attention. Check your owner's manual for items that can cause it to chime.
Aug 03, 2009 | 2002 Cadillac Deville
Door locks, windows don't operate from driver's side
Sounds like the wiring from the door to the main part of the car have been severed. Check by the hinges of the door the condition of the wires as the door sensor, controls for driver door windows and locks all pass through this gap to the vehicle.
Apr 03, 2009 | 2005 Chevrolet TrailBlazer
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Side by Side refridgerator loud pop noise.
Lower door cam is probably damaged. That is where your noise is coming from. either it was never reinstalled after the doors were removed or it was broken or damaged when the doors were removed. One cam attaches to the door and one attaches to the hinge. they should mesh together smoothly. if they don't. Bang Clank, Very Noisy.
Thank you, Hope this helps you out.
May 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung RB195ACBP Logo
16 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
