Haier bwh18a Air Conditioner/heater burning Element
Whyis the heater keep burning heating elements
  • 18 Answers
SOURCE: Heater blowing out cold air
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Posted on Dec 23, 2007
edgz
  • 26 Answers
SOURCE: motel style heat and air
HI,
Meaning not function of heating,pls apply this the following 1) Possible loose connection to reversing valve pls check this wiring connection.
2) Pls check the sensor to thermostat if this a loose connection.
3) Check the Compressor if this not function or loose compression.( Function but not heating )
4) Check if have a Leakage.
Pls go to the nearest repair shop if not solve,
Thanks & best regards,
Edgz
Posted on Jan 19, 2008
yalmer
  • 549 Answers
SOURCE: Carrier Thru-Wall Heater and Air Conditioner won't heat
http://www.residential.carrier.com/support/troubleshooting.shtml
Here is some troubleshooting tips.
Also service available.
Posted on Feb 25, 2008
  • 1122 Answers
SOURCE: Cabrio Electric Dryer Heating Element
have you checked the high temp thermostat?
Posted on Sep 05, 2008
SOURCE: My Haier 5,200-BTU Window Air Conditioner keeps freezing up.
You need to clean the unit outside(take it out of the window) with a water hose because it is dirty inside( you have to remove screws on cover and take cover off), be sure to cover the electronic control board with plastic so you don't get it wet.Clean fins on front and back with water hose and inside .
Posted on Sep 24, 2008
Heat strip keeps tripping breaker after running for a few minutes
Breaker must be 2 to 3 times of running amps of a/c or heater whichever is higher. If breaker fixed minimum3 years back, better to replace. In heater, clean heater strips by a blower and also check for loose contacts. Sometimes weak strip element, it may happens. Replace heater element. Thanks.
Jan 29, 2011 | Goodman GPH1324H21A WallWindow Air...
The unit dosn't heat
Check heater element has power. And also setting temp must be minimum 3 degree + than room temp, with heat mode. If RV system, check power to RV. If not PCB problem. If power to heating element, still no heat, replace heating element. Thanks.
Jan 27, 2011 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
The Heater is not working! It has been on for about an hour and is still blowing cold air!
To get proper heat, keep your temp setting at +5 degree than your temp and also mode in "heat "position. If still noheat, check your heating sensor for closed circuit by an OHMs metre.It it'swith RV, check power to RV.Ifit's with heating element check power to element. If power is there but stillno heat means element defective. Replace new heating element. Thanks.
Jan 24, 2011 | GE Built-In Room Air Heat Cool Air...
How to put the heat on the aircondition
Jan 14, 2011 | Haier HEATER CPN10XH9 Air Conditioner
Heater not working when switched on
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 11, 2011 | Amana PTH073E35 Air Conditioner
Heater not working on Mr Slim
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.If it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks.
Jan 11, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Heater only blows cold air. I have a Weather King Heater and it only blows cold air the burners will fire for about 2-10 seconds and then it goes . ...
Jan 09, 2011 | Weather King 10AJA3001AH Air Conditioner
Need to turn on heater
Jan 08, 2011 | LG L1004R Air Conditioner
Heater dont work
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV. If it's with heating element check power to element. If power is there but still no heat means element defective. Replace new heating element. Thanks.
Dec 31, 2010 | LG LWHD1807HR Thru-Wall/Window Air...
Blwoing cold air
Possibly, A thermal fuse located in the heater element circut could burn out. the CIrcut would show full voltage to the element but no heat out. Often there is also an auto reset high limit swich this could be out also opr instead of the fuse. THE FUSE IS ALWAYS LOCATED WHERE IT CAN "SEE" the elements. I E Inside the case where the elements are.
Dec 16, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
