Question about Sony 8GB Micro Drive (SUD8G) -24419 USB 2.0 Hard Drive
Problem with Sony 8GB Micro Drive (SUD8G) - Sony 8GB Micro Drive (SUD8G) -24419 USB 2.0 Hard Drive
  • Sony Master
  • 27,725 Answers
Since you have neglected to post a problem detail ??
A few important bits of information about using faults and fixes on usb drives w7 First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X you will need to update/reinstall drivers right click to reinstall drivers if you can see your usb drive but its not working ports (com&lpt) right click update driver if this fails to fix the problem Check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts Click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box (I have found better results ticking the first box then reurn and tick the second box) you should not do anything while the chkdsk utility is in progress any input may damage this drive also you might need to do this Click start click to open on my computer you should see your usb drive F: right click select properties there will be an array of options select the sharing tab option then advanced sharing permissions make sure you have a tick in the share this folder box then click permissions make sure all three boxes are ticked you full control change and read in windows 7 Click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
also
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Flash Drive (It should be F: / E: or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
you might have restore it to its defaults Right click on usb drive select properties you will have an array of options Select the hardware option then select your drive properties policies restore defaults In XP Right click on your drive select properties then on customize restore Default in W 7 If you need more help with this post a reply Hope this helps.
Posted on Jan 12, 2013
Wish ro remove mesagge " this disc is write protected" , so i can use usb memory!
Right click the drive and uncheck the read-only option. If there is a hardware switch, move it to the unlocked position.
Nov 03, 2012 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
What's your problemthe disk in drive h cannot be formatted software?
When are you getting this message? Do you have something in the drive h?
May 29, 2012 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
My removeable flash dosnt read
i had this my pc just wouldent do it till i updated the drivers try it in another pc
Jan 17, 2011 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
PLEASE INSERT A DISK INTO DRIVE(H):(Card Reader)
I think your problem is nothing but to replace with a new card reader
Aug 20, 2010 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Pen drive problem
when you connect your pen drive then he gave you pen drive symbol on your pc? if he give the symbol then try to open it explolar .if that also it not open then format pen drive.
Mar 30, 2010 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
My usb is not recognized by my pc
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Mar 04, 2010 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Cannot burn cd, keeps asking me to insert blank into drive (H;) which i do?
it may be a problem in your disk writer or changing your writing software
can solve problem.
try ........burnon cd/dvd
Feb 24, 2010 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Sony 8 gbpen drive not formatted
can it be made to work on a win box? if it cannot then i suggest it may be fuct ! (failed under continuous testing)
Aug 28, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
"insert a disk into drive" even when pen drive is attached!
Sounds like a failed circuit either in the USB adapter or in the drive itself. You will most likely require the help of a pro with this one if you need to get your files back.
If there's nothing crucial on it, recycle it and grab a new one, if there is important data on it, reply back with your Country, Sate, City and I will refer you to a nearby Pro.
Chris
Jul 17, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Sony 8GB Micro Drive (SUD8G) -24419 USB 2.0 Hard Drive Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
