Question about Nintendo Wii Console
No picture but sound is ok
We connected our wii to our tv through our DVD player. when everything is connected correctly and turned on, the tv screen remains blue although we have perfect sound. HELP!
My dreamcast console has sound but no video, it will go to the time setting scream but no responding after that point
Posted on Jan 22, 2009
Samsung cs21m40mj no picture
I don't know if this helps, but I had the same problem in reverse. Great picture - no audio. I finally unplugged the TV and all devices connected to it (DVD player, cable box, etc.) waited 3 minutes and plug everything in. The audio was restored.
May 19, 2012 | Televison & Video
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to...
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Apr 04, 2011 | Sony DVP-NS575P DVD Player
Trying to hook up a dvd and wii with direct tv and can"t get sound out of wii! HELP Can you show me where to plug cords in?
Your TV has two sets of AV inputs. One on the side and one at the back. The Wii has a 3RCA cable ( Yellow / Red & White ) . Connect these jacks to the corresponding color sockets on the side input of your TV. Select that input on the TV and your Wii sound and picture should come on.
For the DVD player you have to get a 5 RCA component cable. This cable will have 5 colored jacks, connect the White & Red to the Audio in of the TV and then connect the Red/Blue/Green jacks to the component video input of the TV.Do the same at the DVD's end also. Setect that source on the TV and you should hear the DVD sound and picture.bobhifi_31.jpg
Apr 03, 2011 | RCA L32HD41 LCD TV
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
I cannot get a picture. Sound is OK. Everything is fine when viewed on the TV but the DVD screen is just white.
there is a problem with the audio video cable.try a new cable and also go for display options both on dvd and screen.
Dec 04, 2009 | Hitachi PDV-302 Portable DVD Player
Wii playback on games etc is only green and blue ..no other colours
Sounds like a faulty cable or a loose connection. Check to make sure everything is connected snugly from your Wii to your television. Also try plugging the cables coming from your Wii into another available connector on your television if you have one available. Otherwise it's most likely the cord that connects the two if your tv displays other systems, such as your cable/satellite or dvd player, correctly.
Dec 01, 2009 | Nintendo Wii Console
I can't get a picture on tv when turn on dvd player why? brand new, never used before.
have you connected the DVD into the right plugs, also are you using the correct AV channel on the TV?
RED WHITE YELLOW yellow is video red is L sound White is r sound. check both TV input and DVD output
Aug 14, 2009 | RCA DRC8335
Whenm i hooked up my wii the sound works but i
connect a dvd up instead to see if the tv is working.if it does not work wih a dvd player you will need to replace the digital main pcb.
Jul 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Lights up screen, has sound, but no picture on the units screen!
has good sound--but no picture. the hookup cables are correctly installed
May 05, 2009 | Televison & Video
CANT GET ANY SOUND AFTER CONNECTING THE DVD PLAYER.
have you plugged the leads to audio in on the tv? if it as front sockets us them they are input only some on the back are output.good luck .farr64
Apr 29, 2009 | JVC TH-C3 System
Nintendo Wii Console Logo
557 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
