Question about Hunter Fan Company 5/1/1 Programmable Thermostat
The heat comes on then goes off and it blows cold air the fan won't stop i tried to turn fan off and it wont now the heat wont blow please help
Ok i turned on the heat and it blows cold air it takes for every to get it to blow heat then it stops
2 Suggested Answers
SOURCE: hunter thermostat 44860
Hit just to the left of the temperature and you will see a fan symbol pop up. Make sure the fan is set to the correct setting. Refresh means the fan will come on every 15 minutes or so no matter what the tempurature. Auto is usually the normal setting I think. Program mode - depends if you have programs. On mode means the fan is always on.
Posted on Oct 22, 2008
I have a 1999 Caddac DeVille . The AC works fine during the summer but in the winter it won't blow out hot air unless I'm driving. I've let the car run in the morning to warm up but the inside...
your heater core is possibly stopped up if there has been a radiator leak and stop leak has been poured its definetly clogged or could be a faulty thermostat
Jan 07, 2013 | Cars & Trucks
Vents blow out cold air instead of heat.
Check for a vaccumn line in the engine compartment that may have come loose or has a cracked rubber connector. The a/c system depends on vaccumn line to open and shut the dampers
Oct 06, 2012 | 2002 Saturn L-Series
Amana BR22VL refrigerator section stopped cooling.
is there any frost on your food packages or on the ceiling where the light is?if so the door was left open and the air vents are froze up or you have a bad damper or evaporator fan motor,open the freezer door,do you hear the fan blowing?if so the fan motor is good,check for ice on the ceiling and packages,if that checks good look at the back inside wall of the freezer,if that's covered with like snow or frost you have a defrost problem or also you have a damper in your model,it's closed and won't open to let the cold air in from the freezer.
http://www.repairclinic.com/PartDetail/Damper/R0161050/223353
go here,this is the part,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer up into the fridge section,in your model the damper door opens to let the cold air in,when it gets cold enough the damper closes and that's it,so if the door wasn't left open and the fan is blowing in the freezer you have a bad damper.
Aug 10, 2012 | Refrigerators
Car blows warm air when idling
It sounds like your AC unit could be overheating or even damaged.
AC units have a sensor that will turn them off automatically to prevent damage from overheating. If there is an insufficient amount of air flow, the unit will heat up, and then eventually turn off.
When the car is moving, more air is forced over the unit, likely keeping it cool enough to run, however, when the car come to a stop, it loses that air flow, and quickly heats up. Thus, the AC would work while the vehicle is in motion, and overheat and stop when the car is stopped and idling.
However, the AC unit could be completely blown. The cold air while moving could be just a case of air being forced into the car. Think of a house fan, the fast the wind blows on you, the cooler it gets.... Thus, it could be an illusion that the AC is working when car is in motion, when it really isn't.
Hope this helps.
Jun 09, 2012 | 2004 Lincoln LS
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
I'm looking for the fuse that goes to me heater. the fan comes on but it blows cold air.
Hello
the fan priveds air circulation, not heat. If you have power to the fan, you're good in the fuse department.
As for no heat - did you check the coolant level?
Any check engine lights on?
Have you added anything to the radiator to prevent leakage? (If so the heater core could be clogged or other obstruction in the supply lines to/ from the engine cooling system.)
Best regards
Ck
Nov 14, 2011 | Cars & Trucks
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
I have a Rudd Achiever 90 plus Premium Efficiency Model# UGRA09EZAJS Serial# Y5D707F460504955 mfd date 11/2005, It blow a cold air after turn the heat on and set it on position instead of auto, temp set...
When you set the the switch to ON, I'm assuming that is the fan control? You should leave that on AUTO. The furnace will turn the fan on when the heat exchanger reaches a preset temperature. Which will prevent COLD air from coming out of your vents.
Nov 04, 2010 | Ruud UBHC Air Conditioner
LAST NIGHT WORKING FINE ~ THIS MORNING NOT BLOWING COLD AIR
check one of the following stop the cooling
a- condenser need cleaning
b- condenser fan not operating
1 -check correct voltage comes to the fan motor if ok
2- check capacitor if ok
3-check motor winding
c-low suction pressure
need check for leak before charging.
Sep 12, 2009 | Dometic Rooftop RV Air Conditioner
Hunter Fan Company 5/1/1 Programmable Thermostat Logo
19 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
