Question about Water Heaters
My ideal isar boiler is making a banging noise at the same time the pressure needle is going crazy then it overheats with L9 on the display.what is wrong with it.
3 Suggested Answers
  • 234 Answers
SOURCE: I need an Instuction manual free to download for
http://www.screwfix.com/talk/thread.jspa?forumID=25&threadID=27577&messageID=268842
I hope this help you.
Posted on Mar 19, 2009
peterrance19
  • 399 Answers
SOURCE: swich on heating the pilot lights up then the
hi you could be drawing air into the system try bleeding the system check all seals and if ok tighten all connections
Posted on Nov 17, 2009
Ideal mexico boiler HE 36
Check Gas Pressure, make sure you have correct pressure.
Apr 06, 2014 | Water Heaters
Glow worm 45-60 standing boiler making banging noises when in operation
The noise you refer to is called Kettling, it is caused by the hot water in your boiler not being able to leave the boiler quick enough, if the problem developed quickly and your system is a "fully pumped " system this would generally point to your pump either has failed or is on its way out, i.e . your radiators would not heat up as the hot water is stuck in the boiler hence the banging......( if you know where the pump is you can generally feel if it is running by a small vibration ) if you have gravity hot water and pumped heating circuit then I would assume that it is noisy when just doing HW, and the banging is a problem that has gradually got worse it can indicate that the boiler is scaling up (are you in a hard water area). if this is correct there are various additives that can be put in the system to help quieten it down, I suggest you really need a heating engineer to diagnose fully.
Feb 07, 2014 | Water Heaters
Boiler bangs when hot tap turned on
Hello,You need to install a domestic/high pressure extrol/expansion tank on your cold water pipe.Should slove noise.
Apr 09, 2010 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Water dripping out of external pipe from ideal classic fxff boiler hwta is how do i fix it
Do you find that the boiler water pressure drops over time?
Then replace the pressure relief valve. You'll find it in the lower part of the boiler connected to that external pipe.
Close off the water pipes to & from the boiler and then replace
On some you can dismantle the valve and clean the scale from the inside and it works again - but not always 100%
It's either this or the fill tap/valve is not turned off fully
Mar 15, 2010 | Jason Natural Cosmetics Jason Forma...
I have an ideal standard he30 boiler instaled about 6 weeks ago. the boiler keeps losing presure about half a bar every 2 days if i dont top it up it will trip the fuse on the fuse board acording to the...
All the combis I've come across merely fail to fire if the pressure is not up. not only do they not fire, nothing else works including the pump and in any event the pump should not overheat just on low pressure.
water loss - try turning off the valves on the flow & return pipes [3/4 inch ones] 1 valve per pipe . This will isolate the rest of the system - rads etc Note pressure over a time period. In this mode the hot water circuit will still work but do NOT use the heating circuit
1/2 bar over 2 days is not serious but it should be found
Once you have either mended the leak in the rest of the system or found there is not one, insist on a replacement boiler
In any event having looked at the reasons given for the fuse blowing, I would definitely get a replacement.
These problems should not happen on a new boiler
I list Worcester.-Ariston-GlowWorm-Ideal- and many others who would confirm this
Dec 24, 2009 | Water Heaters
Swich on heating the pilot lights up then the boiler starts making banging noises the pressure gauge starts fluctuating and the boiler cuts out
Nov 17, 2009 | Water Heaters
On the ideal c95ff the boiler the red neon lockout
overheat stat , does it come back on with reset ?best of luck
Jul 23, 2009 | Water Heaters
Boiler overheating
the problem there a relay stuck or thermostat bring on the pump & you can lower your high limit aquastat!! also the flow valves can bypass hot hot water risers time to put in a seperate water heater domestic coil are not energy efficient !!!! aquastat high limit set @ 180f deg low limit set @ 140f deg!!!
good luck!!! tim
Oct 08, 2008 | Water Heaters
Water Heaters Logo
73 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
