Question about Bowflex TreadClimber TC10
How do I correct the error message ESLP on my TC10 treadclimber
Error message ESLP appears when I press start button
4 Suggested Answers
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link  download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS” or “err OS” is displayed Calibration Re-calibrate machine using Owner’s Manual calibration procedure. Speed sensor 1. Cycle power off and on. 2. Put the machine in calibration mode (see Calibration procedure in Owner’s Manual) but do not start the calibration routine. 3. Remove right rear plastic cover to view LED diagnostics on control board. Caution: Machine is on. Current is active!! 4. Locate LED D on the motor controller board. LED may be lit or unlit. 5. Manually advance the treadle with your foot, and check if LED D is blinking. 6. If LED D is not blinking, then the speed sensor is not supplying a signal. Check that the speed sensor wire is plugged into the motor controller board, to the connection labeled “P1”. Check connection of speed sensor to jumper wire. Check speed sensor adjustment (use business card to set gap between sensor and pulley). If LED D still does not flash replace sensor. I/O cables If LED D is flashing when the belts are turning but err LS or OS persists check connections and for signs of visible damage to any of the three I/O cables. If no damage, check continuity using a multi-meter. If a multi-meter is not available contact customer service for replacement cables and further assistance.
Mike
Posted on May 30, 2009
  • 3 Answers
SOURCE: i have a treadclimber 1000 and it will not start.
call bowflex and get a return authorization fast
Posted on Jul 20, 2009
  • 6 Answers
SOURCE: calibration fail message on bowflex treadclimber.....help
Unplug your machine, restart it and try to calibrate it one more time. I had to do this with mine and it did take more than one try to get it to recalibrate again.
Posted on Jul 29, 2009
I have a Singer 7285Q sewing machine that comes up with a "E-7" message and the machine won't work. It only happens when I use "back stitch" button. My instruction manual has no mention of an
E7 means
The start/stop button, reverse/reinforcement stitch button
or the thread cutter button was pressed while no thread
cassette was installed. If the start/stop button is pressed before the sewing machine is correctly set up or if an operation is performed
incorrectly, an error message appears in the stitch indicator. Follow the instructions that appear.
If you press (Stitch selection key) or do the operation correctly while the error message is displayed, the
message disappears
Oct 30, 2014 | Singer Sewing Machines
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
Mar 23, 2014 | Singer 7258 Sewing Machine
PLO5 error message on Quinton Clubtrack treadmill
Try to clear the error message. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Jan 25, 2013 | Quinton Stairmaster Clubtrack 3.0 GymTough...
Printer comes up with (caution! aps size error) error message after i press the start button in the control to make copies.
1-Press "Tray" button or "Paper" button from the panel.
2-Select the paper size from the menu shown.
3-Now press the start button. No caution will appear.Next time use the same procedure for making copies.
Dec 28, 2010 | Konica Minolta bizhub 180 All-In-One...
My Xerox Workcentre-5020 machine showing U4 error. How can I solve this problem ?
@basanta711, Press 0 for 5 seconds then press green (start) then 50, green, 20 green, 0, green then on/Off the printer........... problem is solved
Nov 07, 2010 | Cell Phones
What does error Oxc05d0281 mean
This error message means" ink system failure " and to resolve this issue please follow these troubleshooting steps:
Unplug the printer and wait 30 seconds for power to discharge.
2. Plug in the printer.
3. Hold the CANCEL and OK buttons simultaneously, and keep them depressed while you hit the ON button. This resets the printer.
4. When the printer turns on, if you still get the error message, it's OK. Then perform the steps listed
1?Press and hold the “*” key
2?Press the “#” key and release both keys,Display should say “Enter Special Key Combo”
3?Press and release in sequence the “1”, “2” and “3” buttons
4?Press and release the right arrow button until the display says “System Configuration Menu”.
5?Press and release the “OK” button.
6?Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure
7?Press and release the “OK” button.
8?Display should say “Hardware failure status: Clear. Press OK to clear”.
9?Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
10?Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
11?Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
12?Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
13?Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
After you perform the steps listed above, when you are at the step at the end where you are pressing the cancel button until you get to the WELCOME screen, if at some point you see a message, “Inproper shutdown, hit OK”, go ahead and hit OK and the Welcome screen should appear.
One thing that is nice about this method is that it doesn't use up all your ink doing a recalibration.
The error message should not pop up so try to print a self test Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
all the best
Jun 04, 2010 | HP Photosmart 3210 Printer
When i go to press the start button it comes up with a ERR message i have a zj1218
what error message do you get? normally the error message appears when someof the component is jammed and not able to function or is gone faulty.this can be detected by the error message it shows.
Dec 28, 2009 | Zanussi Washing Machines
49.4401 service error on start up
Solution or Workaround:
1) TRY to flash the firmware.
2) Try cold reset and disk initializations.
3) Replace firmware dimm.
If you have a hard disk:
To resolve the issue it may be necessary to perform the Disk Init procedure.
Disk Init Procedure
1. Turn the printer off, then on
2. When the memory count starts on the control Panel, press and hold the Menu button until all 3 lights on the control panel are lid
3. Press the < button. The message “INITIALIZE DISK” appears in the display
4. Press the Check button. The printer will initialize the User space on the Compact flash and will continue it’s power-on sequence.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 19, 2009 | HP LaserJet 4650dn Printer
Error message
OK guys quite a simple one....
with the printer on press & hold both the small red button ( far right ) and the green, colour copy button. Whilst still holding press the power button wait till the unit powers off. Press the power button again, shortly after the unit powers on, the lights flash, let go of the two buttons your holding. The screen shoul dnow say "Init EEPROM" if it doesn't repeat procedure till it does. Now press the green colour copy button once, screen should now say "Push power sw" Press and hold the power button, the unit will power off and on again, now release the power button and your printer should be working again. Now you should change your waste pads......
Dec 05, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Bowflex TreadClimber TC10 Logo
650 people viewed this question
Top Bowflex Exercise & Fitness Experts
Howard
Howard
Glenn Mayer
Glenn Mayer
ka4iup
ka4iup
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
